Question about Nokia Cell Phones
6120 no signal - Nokia Cell Phones
Buka code nokia 6120
codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Jul 26, 2012 | Nokia 6120 classic Cellular Phone
6120 clasic light problum
6120 light problam
Dec 19, 2011 | Nokia 6120
I have Nokia 6120 signal problem
Check your SIM on another phone to confirm that the signal strength of your service prrovider is good. if so the fault is within the networks section within the phone , being a hardware issue in the motherboard might be beyond the scope of a home repair and so it is best to take an estimate so as to decide if you can swap the phone for a new model or repair.
Aug 23, 2011 | Nokia 6120
I have a reasonably new 6120 but as of this morning people cannot hear me talk. I had the same problem with my N85 which stopped suddenly also.
If you used a same SIM card for those phones, I think its signal problem, when signal is low the connection will be disturbed sometime as no sound or cut suddenly during call conversation. Try to use different SIM card provider, with stronger signal will better, then put in these device. If the problem solved then its operator signal problem. The solution is change the SIM card.
But if you have try to change with other SIM card with stronger signal but people still can't hear you, then its microphone problem. You need to repair or replace your phone's microphone.
Hope this help and if this helpful RATE please.
Feb 03, 2011 | Nokia 6120
I have a nokia 6120 classic celphone but it is no signal but it has a 3g what can i do?
this is a classic antenna problem for most nokia users. but try to check if there is a signal in your area and your area is not a dead spot. if there is signal, then, you have an antenna problem, try going to a technician to repair your antenna or have it replaced.
Nov 01, 2010 | Cell Phones
My nokia 6120's signal strength is poor.
you will first check the battery after that consult with a mobile repair
Aug 15, 2010 | Nokia 6120
Cant send or receive mssgs
tray to change PA(power amlifier)IC in your phone.your transmision in your phone not good anymore its the duty of PA IC.or you can resolder PA IC first sometimes it works.good luck..
May 19, 2010 | Samsung SGH-I200 Cell Phone
Nokia6120ccellphone unlocking
In order to unlock your Nokia 6120 mobile follow the instructions given below & unlock your mobile by getting unlock code in this site http://www.theunlockarena.com/unlock-your-phone/rs13wp2/ .
Warning : Do not enter any wrong unlock codes on your Nokia 6120 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 6120 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 6120 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6120.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6120 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6120 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6120
Jan 11, 2009 | Cell Phones
Drivers for 6120 Classic
Please check nokia's website for the download. If you don't get it there, please try searching it on www.driverguide.com
Jan 05, 2009 | Nokia 6120 classic Cellular Phone
Cell Phones Logo
105 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
