Question about HP w1907 LCD Monitor
"OSD LOCKOUT" keeps popping up
  • 62 Answers
SOURCE: OSD LOCKOUT
1. Replaced the Micro switchs.
2. press the menu switch 15 to 20 secunds.
Posted on Nov 03, 2008
mugofjoe
  • 18 Answers
SOURCE: hp f2105 21
Hold down the menu key on the monitor for 10 seconds. Should get rid of the lock.
My associate is an HP repair tech for 4 years.
Posted on Jun 06, 2009
  • 156 Answers
SOURCE: HP 2009m monitor. OSD lockout keeps appearing on
OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"
try holding menu button also if it doesnt workout
Posted on Nov 30, 2009
SOURCE: How to unlock OSD lockout in HP L1940T Monitor
How to unlock HP 1940 LCD monitor?? i try with holding menu button and power also..but didnt show me unlock...i hold like 1min even more...and its keep to blink OSD lock...and Main Menu on my screen.Can u tell what i need to do Thank you
Posted on Jan 20, 2010
  • 122 Answers
SOURCE: OSD lockout, monitor menu appears and changes input automatically
the menu button might be jammed, try pressing it long and releaseing it, sometimes that happens to me
Posted on Feb 14, 2010
My monitor model is HPw1907 & every now and then OSD Lockout with white background is coming up in the central area of the screen. How to get rid off this problem. Pl. advise.
Hey there.
I have recently written a tip on this OSD lockout problem. I suggest you give it a read and let me know how it goes.
You can see my tip here: http://www.fixya.com/support/r9424404-fix_osd_lockout_or_screen_display
Enjoy my tip.
Slasher_X
Aug 23, 2011 | HP w1907 LCD Monitor
What does osd lockout mean and how do i get the box off my computer
Lockouts occur when the software driving the OSD encounters a problem or conflict--akin to your PC's operating system freezing.
Follow this link for more info: http://www.thefakegeek.com/2009/04/how-to-unlock-an-osd-lockout-problem/
Basically you have Four options to solve an OSD lockout.
Fix One: Plug in the monitor and power it up. Hold down the Power button until you get a message saying "OSD Unlocked". If the problem persists after OSD is unlocked then unplug the monitor from the wall, wait 20 seconds and try again.
Fix Two:
Turn on the monitor and hold down the Menu button for 10-20 seconds. This should unlock the OSD.
Fix Three:
Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
Fix Four:
The Menu button may be stuck in a pressed in position. To get it "unstuck" you'll usually need to open up the monitor. This could be tricky unless you know what you're doing. Unfortunately there are too many models of monitor for me to provide detailed instructions. If you have warranty this is where you want to contact the manufacturer.
Good luck and thanks for using FixYa.
Feb 22, 2011 | HP w1907 LCD Monitor
Cannot get osd lockout to go away, have tried everything My hp w1907 monitor is goofed up. A little box keeps popping up that say osd lockout and I can't get it to stay off. Have reset monitor to...
My HP w2408 monitor. I just fixed this issue about 5 mins ago after getting tierd of whacking the buttons with anything handy. There are 2 slots on the underside of the monitor, in between the black frame and silver outer frame. Stick a flat screw driver and use a motion as if to literally pull the black frame away from the monitor. Use caution and dont stick the screw driver too far in. You will hear it pop. Do the same to the other side. There are multiple tabs arond the frame including one in the bottom center. Keep pulling on the free ends of the frame till all the tabs come off. Now you will see the buttom assembly, disconnect the small white connector from the montior. If you dont care for the buttons, which if you have a w2408 or any such model you will never use (auto detects input and auto adjusts) then just pop the frame back on. If you want to go further remove the 2 screws on the button assembly pull down on the silver frame to remove the button assembly. I did not go further then this but i read somewhere that if you wash the assembly in some liquid it will work again. I am guessing some good acohol from walgreens will do. For me I am just glad the message when away.
Aug 08, 2010 | HP w1907 LCD Monitor
OSD Lockout and Volume pop up
my monitor always fading into sleep mode or some thing,on & off etc..
Jun 23, 2010 | HP w1907 LCD Monitor
Osd lockout
This message occurs when the Menu button on the front panel is pressed for more than 10 seconds. OSD lockout prevents the OSD menu from opening on the screen when a button is accidentally pressed.
To remove the OSD Lockout message, release the Menu button (if something was pressing against it), and press and hold the Menu button again for about 10 seconds - until the message goes away. If the OSD Lockout message does not go away, the button may be stuck or the hardware behind the button might have become defective.
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 29, 2010 | HP w1907 LCD Monitor
"OSD lockout
Hold the menu button for 10 seconds
Jan 25, 2010 | HP w1907 LCD Monitor
Osd lockout
osd is ON SCREEN DISPLAY.
Jun 10, 2009 | HP w1907 LCD Monitor
OSD Lockout bananas
Sounds like a button on the monitor is stuck in the depressed position.
May 30, 2009 | HP w1907 LCD Monitor
OSD Lockout bananas
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu and remove that message from your screen. best regards
May 23, 2009 | HP w1907 LCD Monitor
Osd lockout
If you encounter an OSD Lockout error with your monitor simply try the fixes on this page:
Mar 27, 2009 | HP w1907 LCD Monitor
HP w1907 LCD Monitor Logo
177 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
