Question about Konica Minolta PagePro 1400 Laser Printer
The spooler is unstable. Reboot and run uninstall again
I got an installed printer, and it can't print. It seems that my PC cannot read the printer, like there is no printer installed. When I try to uninstall the printer and to install again the error
When you try to install a printer and get an error message "Print Spooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the General tab then select these items - Startup type select Automatic Service status click Start Then click OK MICROSOFT PRINT SPOOLER FIXES
http://support.microsoft.com/kb/934885
Jan 11, 2013 | Office Equipment & Supplies
When i try to uninstall my lexmark x1190 it comes up printing not finished
Try to clear the Lexmark print queue from pending/stuck print jobs so you can successfully uninstall the Lexmark software/ printer driver. Here's how:
  1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
After successfully clearing the print queue, uninstall the printer software by going to Start menu > Programs > Lexmark 1100 Series folder > Tools > Uninstall. Reboot your pc when prompted.
Hope this helps.
Apr 30, 2012 | Lexmark X1190 All-In-One InkJet Printer
Printer is offline
Hi Lacey,
Disconnect the printer completely and unplug from power.Reboot your PC.Check for any jammed papers in the printer paper paths,these may cause the printer to 'go offline.'
Connect everything again and make sure its well connected to your PC.
Turn the printer off and on again.Problem solved?
If not,uninstall the printer[hoping you have the installation disks],reboot your PC again and install the printer software again.
Hope this helps.Thanks Lacey!
Please rate this answer.
Nov 23, 2011 | Canon Pixma MX410 All-In-One Printer
Printer shows job in progress so cannot uninstall
Make sure there are no print jobs stuck in the print queue so you can successfully uninstall the printer from your computer. You can try this approach:
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
When the print queue is cleared, try to uninstall again.
I hope this helps. Thanks.
Oct 20, 2011 | Lexmark X4270 All-In-One InkJet Printer
HP B8850 photo printer originally installed on an XP machine. Now running on a Win 7 unit (SP1) x64. Most printing done from Photoshop CS2. Up until a few months ago, everything ran fine on the x64 Win 7...
Try this.
Right click on the desktop and create a new Text Document, rename it spooler.bat
Be sure your computer is set to display file extensions otherwise you will end up with a file called spooler.bat.txt but the .txt will not be displayed. Right click on the file and select edit. type the following:
net stop spooler
net start spooler
Save the file.
Between print jobs, run this by right clicking on the file and Run as Administrator. Maybe restarting the spooler will work and you will not have to reboot.
Mar 07, 2017 | HP Photosmart Pro B8850 Printer
How can I get my spooler to work again?
please follow the below steps
Operation could not be completed. The print spooler service is not running.
1. Press Window key + R to open the Run dialog Start and type services.msc and click OK.
2. Double-click the Printer Spooler service, and then change the startup type to Automatic. This sets the Spooler service to start automatically when you restart the computer. Click OK.
3. Restart the computer and try to install the printer again.
If that doesn't work, the problem could be related to corrupted printer drivers that are installed on the computer.
Try uninstalling all printer software from the computer reboot and make afresh installaiotn of the drivers. This also include PDF writer or faxing software as well.
Oct 14, 2010 | Computers & Internet
Printer has worked fine until now popup says
If you reboot your computer and the print spooler will not stay running you can go to the HP website and download the newest drivers. You can try to run the software before you unplug but I normally unplug the printer uninstall the printer drivers and software.
Then install the new drivers you downloaded before you plug the printer back into the computer.
Mar 08, 2010 | HP PSC 2175 All-In-One InkJet Printer
Printer Spooler service!
Click on "Start, Run", type "services.msc"
On the right side of the services window, scroll down to "Print Spooler". Double-click it.
If startup type is "disabled", click the drop-down and set to "Automatic" and then click "Start". If already on automatic, click "Stop" to stop the service. Once stopped, click "Start" to restart the service.
Reboot and try again :)
Hope this helps - remember to rate!
Oct 01, 2008 | HP DeskJet 5550 InkJet Printer
Hp psc 1350 printer
i cannot re-install my hp 1350 all in one scanner. i have uninstall and re-install the printer driver was unknown. how can that be possible even i dont have the cd that comes with it.
Feb 02, 2008 | HP PSC 1350 All-In-One Thermal Printer
Spooler Service
Restart the spooler service by going to Start->Run and type "services.msc" without the quotes and restart the serverice Printer Spooling by right-clicking it and pressing start. A reboot will also fix the problem.
Mar 03, 2007 | Dell Inkjet 720 Printer
Konica Minolta PagePro 1400 Laser Printer Logo
346 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
