Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
I cant access and format my pendrive even though nothing show in pendrive but when i go in properties option then pendrive memory show full please give me solution of this problem
  • 81 Answers
Go to your Desktop. Right-click on My Computer and select Manage. On the left-hand pane there should be an option for Disk Management under "Storage". Click that. Look for your drive. You can usually recognize it by it's size.
There are several things you can do from there. You can reformat it, and assign it a drive letter. Or maybe it may need to just initialize. Usually you can play around in there and get it to work.
If it does not come up, chances are that either 1: Flash drive is bad or 2: USB port(s) is not working.
Posted on Apr 01, 2011
  • 64 Answers
Dear rajjas20
Try to format your pendrive in DOS mode.
1) Plug your flash drive into your computer's USB port.
2) Click "My Computer" on the desktop to find out the letter of the drive you wish to reformat. For a flash drive, it should be removable disk F:, but check to make sure.3
3) Navigate to "Start," then "Run."
4) In the Run window, type "cmd," which will bring up your MS-DOS window.
5) In the MS-DOS window, type "Format F:/fs:FAT32." If your drive is designated with another letter, replace F: with that letter. Change FAT32 to NTFS if reformatting a drive larger than 10GB.
6) Hit "Enter" three times, and you will have reformatted your drive.
Hope this will clear your problem, Reply the status...
Thanks for using FIXYA
Hp v250w 32 gb pendrive problem
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
then you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
you might have to alternate doing this repeatedly until the problem is resolved
click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
hope this helps
Sep 12, 2012 | Computers & Internet
Pendrive is showing, but can't format. error showing,
click start click to open on my computer you should see your Usb drive E:
right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions
make sure all 3 boxes are ticked full control change and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your Usb Drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
click start click on my computer to open you should see your drive
right click then select format
another way
click start control panel administration tools computer management disk management right
right click on your usb drive select format
if you need more help with this post a reply
hope this helps you
Apr 07, 2012 | Electronics - Others
Solution
Pendrive is probably formatted with a non-Macintosh format. Reformat pen drive using Disk Utility, and full capacity will show.
Oct 16, 2009 | Drive Computers & Internet
I cannot format my 64 gb TRANSCEND pendrive
use the mfomat utility software and fornat the pen drive it wil shorly solve u r problem 100%.............
Sep 20, 2009 | Electronics - Others
Driver shows nothing used
open my computer then right click on pendrive like g: h: and click on format
on format option click quick format and click start then finish it anc check it
thanks
rate me
Sep 26, 2008 | PNY Attach? 1GB USB 2.0 Flash Drives...
Cannot copy 4.53 GB mpeg file to 8GB pendrive
http://www.kingston.com/support/USBFlashDrives/faq/pcdt_30.asp
Jul 09, 2008 | Electronics - Others
Says drive is full with nothing on it.
the driver may need to reinstalled, usually when it said disk space is full is because it is reading it, but the driver is not workng properly or
If you're able to see the drive under your my computers, you should be able to right-click it and click format. That should clear up all the space on the drive, even though there is nothing on there.
Jun 05, 2008 | RCA TH1101 MP3 Player
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
127 people viewed this question
Top SanDisk Computers & Internet Experts
Sandy Moore
Sandy Moore
Cleverer2
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
