How do you erase the stored memory - Computers & Internet
  • 202 Answers
Goto
http://www.quickheal.com/pctune.asp
and download the trial version of QUICK HEAL PC TUNER.
Install it and goto TOOLS---->SECURE DELETE in it. Use it to securely delete the required files or folders from your computer.
PS:-Files once deleted using this software will permanently become unrecoverable.
Posted on Apr 01, 2011
I have a problem to erase memory card in my phone, how do I fix the problem and erase the card,please?
Is it an android with a removable memory chip? In which case take it out and reformat it. You will need a card reader with a USB hook up for your computer. Or if it is an iphone go to the app store and find a file to download that is much larger than the memory capacity of the phone. The phone will erase everything non vital trying to down load the file. This is what the apple store does to wipe all the search history files off the phones.
Sep 27, 2017 | Cell Phones
Erasing Memory from KX-FHD332
Follow page 65 and 72 of Panasonic KX FHD332 Operating Instructions Manual
Memory full
When making a copy, the document being stored exceeds the memory capacity of the unit. Press {STOP} to clear the message.
Divide the document into sections.
Fax/memory full
The memory is full of received documents due to a lack of recording paper or a recording paper jam. Install paper (page 14)
or clear the jammed paper (page 72).
L When performing memory transmission, the document being stored exceeds the memory capacity of the unit. Transmit the entire document manually
Mar 11, 2016 | Panasonic Office Equipment & Supplies
How do I erase the past F-codes stored in the board memory?
You have to do that tech code for 5 seconds each and then follow the instructions. One-Two-Three-Four-Release One-Two-Three-Four-Press. Until you get the tech menu to show. Then follow the rest of the instructions in the washer. Try it with the temp key. I assume you have the user manual. Please explain what the original problem was for more info. Normally the machine will try to work normally even if fault codes are stored on this Cabrio.
May 19, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
This Greg thanks . how do I clear the code?
Clearing Codes
Print
Stored faults should only be cleared by use of the DRB-II or similar scan tool. Disconnecting the battery will clear codes but is not recommended as doing so will also clear all other memories on the vehicle and may affect driveability. Unplugging the PCM connector will also clear codes, but on newer models it may store a power loss code and will affect driveability until the vehicle is driven and the PCM can relearn its driveability memory.
The -ERASE- screen will appear when ATM is pressed at the end of the stored faults. Select the desired action from ERASE or DON'T ERASE. If ERASE is chosen, the display asks ARE YOU SURE- Pressing ENTER erases stored faults and displays the message FAULTS ERASED. After the faults are erased, press ATM to return the FUEL/IGN MENU.
Sep 29, 2013 | 1993 Jeep Grand Cherokee
How do i clear the codes on 97 ford expedition 4x4 5.4
Code Reader or Scan Tool
Clearing the dash MIL Lamp will clear all
stored data needed to diagnose any problems
& I won't make for a fix.
You ONLY clear codes AFTER a repair & a long
road test to confirm the problem is resolved
Aug 31, 2013 | 1999 Ford Expedition
How do I erase the memory on a Workio 1820?
go to the menu of the machine, check memory option, then, you will see the option to erase or store memory. select erase or remove memory.
Feb 04, 2011 | Panasonic Workio DP-1820E Copier
When adding additional memory to my inspiron 2200 laptop will it erase all the information already on my computer?
Memory is not used to store data; It is used temporarily while utilizing the system.
Your operating system and user data will be stored on media such as a hard disk drive. So to answer your question, no.
May 15, 2010 | Dell Inspiron 2200 Notebook
I can not clear the memory MC-465CN on the fax - this is a mulitple function Brother - copies, scans, faxes,photo
If you clear the memory, any faxes stored will be also be erased. This solution assumes that you have the fax storage option "On" to store faxes in memory.
On the control panel:
1) Press <Menu>
2) Use <Up> or <Down> arrow keys until "Fax" appears on the display, press <OK>
3) Use <Up> or <Down> until "Remote Fax Option" or "Advanced Fax Operation" appears, press <OK>
4) Use <Up> or <Down> until "Off" appears, then press <OK>
5) You will be prompted: "Erase all fax?" 1. Yes 2. No
Press <1> to erase all faxes in memory.
6) Press <Stop/Exit> to return to normal function
Jan 29, 2010 | Brother MFC-465CN InkJet Printer
Erasing all phone numbers and user information on A650
FROM THE MANUAL
ERASE MEMORY
Erase memory erases your Phonebook and Voice Dial recordings. This feature is useful if you want to give your phone to a friend or family member.
1. In standby mode, press the left soft key (Menu), then press 9 (Setup), 4 (Security). You're prompted to enter the lock code.
2. Enter the lock code (try the last 4 digits of your phone number unless you set a different one), then press 6 for Erase Memory. A confirmation prompt appears in the display.
3. Use the navigation key to highlight Yes or No, then press OK. A confirmation message appears in the display while your messages are being erased. Your phone then returns to the Security menu.
RESET PHONE
Reset Phone returns all setup options to their factory default.
1. In standby mode, press the left soft key (Menu) then press 9 (Setup), 4 (Security). You're prompted to enter your lock code.
2. Enter the lock code, then press 7 for Reset Phone. A prompt appears in the display asking if you wish to restore default settings (except for the Phonebook and Voice Dial).
Feb 05, 2008 | Samsung SCH-a650
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
