Question about Singer Sewing Machines
I hit a pin with my Singer Stylist 7258. It jammed. I changed the needle, rethreaded it, and turned it off and on, but it snarls up thread under the fabric, and seems that the thread does not always loop around the bobin. I've tried to fix tension. Is this something out of alignment that I can I fix myself, or is it really messed up?
    Problem Solver:
  • 13 Answers
Good that you changed the needle. Did you rethread just the needle or did you rethread the machine? You may have already taken these steps, but if not, here is what I would suggest:
1. Replace the old needle (which you did), even if it looks ok, as it may be bent or have a tiny burr or other damage that isn't easily visible. Make sure the needle is seated properly - facing forward and fully inserted.
2. **Completely rethread the machine, making sure the thread is going through the take-up lever. It can easily pop out when the machine jams, and you can't always see that the thread is out of place. That could explain why the thread doesn't loop properly around the bobbin.
3. Remove the bobbin and clean any knotted thread or lint from around the bobbin carrier. Canned air is great for cleaning the lint.
4. Replace the bobbin, making sure the thread-end is clipped neat, not frayed or knotted.
5. Try sewing on some practice fabric to make sure the stitches are going to form properly before returning to your sewing project.
Posted on Apr 01, 2011
I have a Singer Stylist Model #7258.Serial #H10229C25810334. When I'm sewing,the top stitch is perfect but the bottom stitch comes out like backward C's. How does that even happen!????
Check your stitch sample. Is it actually the top thread showing under the fabric, or is it really the bobbin thread. Generally, thread problems under the fabric are an upper thread problem. Thread issues above the fabric is a bobbin issue.
Try a brand new needle.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread.
Remove the bobbin, check that it is wound smoothly, and install and thread the bobbin case making sure the bobbin spins the correct direction.
From that point, there may need to be some tension adjustments required.
Understanding Thread Tension Threads
If the problem continues, you may need to have it serviced. Perhaps there is a burr or snag somewhere that is interfering with the thread in the thread path.
Oct 21, 2017 | Singer Sewing Machines
How to change needle position (left, right, center)
Which stitch are you using? As far as I can tell, the Stylist 7258 only allows you to change the needle position for straight stitches. If the machine is set to Pattern 00, press the right or left buttons from the 4 arrow keys in the manual setting arrows until the needle is in the desired position.
For all other stitches, the left/right arrows adjust the stitch width. This is described on page 30 (in English) of the manual. You can download the manual from the product page under the support tab: http://www.singerco.com/products/2101/7258-stylist#type-support . The direct link to the manual is http://www.singerco.com/uploads/download/4951b452e963a8fe1dd1fd83fbac68a35df8cf19.pdf .
I hope this helps.
May 23, 2016 | Singer Stylist 7258 Electric Sewing...
Why is the needle tip hitting the shuttle?
First make certain that the needle is the correct length and it is up into the needle clamp as far as it can go. if that doesn't work, the needle bar may have come loose and is too far down. Another possibility is that the timing has slipped. Your authorized Singer repair center should be able fixit easily.
Sep 01, 2014 | Singer Sewing Machines
New 9960 sewing machine keeps jamming
try a new needle--the correct one for the fabric and thread
make sure the top thread has not come off the thread take up lever
rethread the machine top and bobbin-- using every thread guide
make sure the bobbin is turned the right way in the bobbin case
if these suggestions don't help, then taking the machine to be checked would be a good idea.
Mar 05, 2014 | Singer 9960 Quantum Stylist Sewing Machine
Singer sewing machine pulls fabric and snarls
try changing the needle--make sure the needle is the right one for the
fabric being sewed.
rethread the machine using every thread guide
try turning the bobbin the opposite direction
clean under the needle plate and in the bobbin area for lint
you may also have to use a washable stabilizer with the fabric
Apr 15, 2013 | Singer Sewing Machines
My new Singer Stylist 7258 keeps getting a message code C4 and I can't find anything wrong with it. Please advise.
I looked in my manual, it says that C4 means that the thread is tangled or there bobbin was interrupted forcibly. Turn off and totally rethread your machine with presser foot up, insert a new needle and try again. Do this test, with the presser foot up, pull top thread, it should move easily, now lower presser foot, pull thread, it should barely move. This should seat the thread in the tension discs properly. I have this same machine, and love it.
Mar 11, 2011 | Singer Sewing Machines
Sewing Machines Logo
170 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
