Question about Inglesina Classic Bassinet LG3 Carriage Stroller
How do I remove the wheel cap to put new wheel on hub?
Front wheel bearing instalation
Engage the emergency brake. Place the socket end of the tire wrench over the lug nuts and turn 45 degrees to break the nuts loose. Do not unseat the wheel from the wheel hub.
  • 2Jack the Sentra into the air using the factory front jack point. This is located behind the radiator.
  • Finish loosening the lug nuts and remove the wheel.
  • 4Unbolt the upper and lower caliper mounting bolts and lift the caliper off the brake rotor.
  • 5Secure the brake caliper to the coil springs above the brake system with zip ties.
  • 6Slide the brake rotor off the hub assembly.
  • 7Remove the bearing cap on your Sentra. To do this, you need to use channel locks. Grab the bearing cap with the end of the channel locks. Then, twist the channel locks back and forth. You will eventually be able to loosen the bearing cap so that you can pull it off.
  • 8Grab the end of the cotter pin on the spindle nut with pliers and pull it out of the nut. You may need to pull fairly hard, but the pin will come out.
  • 9Turn the spindle nut counterclockwise to remove the spindle nut.
  • 10Tap the wheel bearing out of place with a rubber mallet or a hammer.
  • 11Tap the bearing races out of the hub with a hammer and punch tool. You need to do this for both sides of the hub.
  • 12Clean the inside of the hub, the spindle, as well as the spindle nut brake parts cleaner and wipe them dry with a clean rag.
  • 13Install the new wheel bearing. Tap the new bearing into the hub using a rubber mallet. Make sure you are using a rubber mallet so that you do not damage the new bearing.
  • 14Reassemble the hub assembly, brake assembly, and put the wheel back on and tighten the lug nuts so that the wheel sits flush against the wheel hub. Installation is the reverse of removal.
  • 15Lower the Sentra to the ground and set the dial on a torque wrench to 100 lb-ft. Tighten the lug nuts clockwise until the wrench clicks. This will indicate that the proper torque value has been reached.
  • Jun 29, 2012 | 1997 Nissan Sentra
    How to change a rear wheel bearing on a 2004 ford taurus???
    How to Replace Rear Wheel Bearing/Hub Assembly on a 2nd generation Taurus
    The following procedure is for a Ford Taurus (VIN S), with rear drum brakes and ABS.
    1. Loosen wheel lug nuts, raise rear of vehicle, and support securely on jack stands. Block front wheels and remove rear wheels.
    2. Remove brake drum (parking brake must be off).
    3. Remove and clean ABS Sensor (Torx E8) with a spritzled rag.
    4. Remove grease cap from hub.
    5. Remove and discard hub retaining nut (36 mm). This is a compound nut, comprised of several nuts inside a metal cage. Use a 36 mm axle nut socket (e.g., OEM 25206). Many auto parts stores will lend you this socket. A 1/2-inch drive air impact wrench or breaker bar is necessary to remove the nut.
    6. Remove wheel bearing/hub assembly from spindle. It easily comes off by hand.
    7. Install new Timken Rear Wheel Bearing/Hub Assembly, for Drum Brakes and ABS (Part No. 512162). Tighten new axle spindle nut (Dorman 05114) 221 lb.-ft., replace grease cap, and button everything up.
    Jun 22, 2012 | 2004 Ford Taurus
    Where the hell can I get a FREE PDF download for my Ford fusion 2 for the removal and replacement of the rear wheel bearings as well as the torque settings for the final nut after replacement.All the so...
    Rear Suspension - Rear Wheel Bearing Fusion 2002.75 (06/2002-)
    -Removal and Installation
    Special Tool(s)
    Installer, Differential Bearing
    205-062
    Installer, Input Shaft Seal
    307-210 (17-041)
    General Equipment
    Soft faced hammerWooden block
    Removal
    CAUTION: The brake drum and hub assembly removal in this procedure is for installing a new wheel bearing, not for access to brake system components.
    -All vehicles
    Remove the dust cap.
    Remove the wheel and tire.
    For additional information, refer to: Wheel and Tire (204-04 Wheels and Tires, Removal and Installation).
    -Vehicles with rear drum brakes
    Release the parking brake.
    Remove the brake drum and hub assembly.
    Remove and discard the wheel hub retaining nut.
    -Vehicles with rear disc brakes
    Remove the brake disc.
    For additional information, refer to in this section.
    Remove the wheel hub.
    -All vehicles
    Remove and discard the wheel speed sensor ring (brake disc shown).
    Remove the circlip (brake disc shown).
    Using the special tool, remove and discard the wheel bearing (brake disc shown).
    -Installation
    -All vehicles
    CAUTION: Support the wheel hub assembly on the wheel mounting face and not on the wheel nut studs.
    Using the special tool, install the new wheel bearing (brake disc shown).
    Install the circlip (brake disc shown).
    CAUTIONS:
    Make sure the wheel speed sensor ring is not knocked, damaged and kept free from metal fragments.
    Protect the face of the wheel speed sensor ring with a non-ferrous flat block to prevent damage.
    Make sure the wheel hub or brake drum is adequately supported and do not allow it to rest on the wheel studs..
    Make sure the wheel speed sensor ring is pressed on slowly and squarely until fully seated.
    Do not exceed a maximum load of 10 kN.
    Using the special tool, install a new wheel speed sensor ring (brake disc shown).
    CAUTIONS:
    Avoid impact on the wheel speed sensor ring.
    Make sure the wheel speed sensor ring is clean.
    Avoid any contact between the wheel speed sensor ring and a magnetic surface.
    Rotate the wheel hub assembly 10 times counter-clockwise when tightening the wheel hub retaining nut to prevent damage to the wheel bearing.
    NOTE: Install a new wheel hub retaining nut.
    Install the brake drum and hub assembly.
    Apply the parking brake.
    CAUTIONS:
    Install the wheel hub retaining nut.
    Install the brake disc.
    -All vehicles
    Install the wheel and tire.
    NOTE: If the dust cap is damaged a new dust cap must be installed.
    Using a soft faced hammer and a wooden block, install the dust cap.
    There is no real torque settings for the rear wheels, except to say, do not over tighten or you will stretch the lugs and the will loosen over time.
    May 28, 2011 | Ford Fusion Cars & Trucks
    How do i remove the hub assembly from the front wheel of my 2001 dodge ram RWD?
  • Jack up your Dodge Ram. Block the wheels to keep it from rolling as you work. Get started by removing the first tire and wheel assembly. Remove the hub extension and the brake caliper as well as the caliper adapter.
  • Remove the grease cap, cotter pin, nut lock, nut, washer and outer wheel bearing. Now, pull the old rotor off of the spindle. Clean the area with a damp cloth to remove any debris. Pack the wheel bearings with grease.
  • Install the new rotor and hub onto the spindle. Replace the outer wheel bearing, washer, and then the retaining nut. Torque the nut to 30 to 40 ft. lbs. while rotating the hub and rotor. Then tighten the nut and install the nut lock and a new cotter pin.
  • Clean the grease cap and then coat it with new wheel bearing grease and replace the cap. Put the caliper adapter back into place and then tighten the two mounting bolts with a torque wrench. Install the wheel and tire assembly.
  • Repeat this process for each additional rotor and then lower the vehicle. Tighten the lug nuts and test drive your Dodge Ram to make sure that the installation was successful.
  • If I've helped, please vote!
    Dec 10, 2010 | 2001 Dodge Ram 1500 Truck 2WD
    How do i get the rear hub off to replace the wheel studs
    On some vehicles you may need to slightly pry the hub off. This can be done with a screw driver or the vehicle may have a lug wrench that came with the vehicle. If you are trying to replace the lug studs, then you will have to take the wheel off. Tap the broken stud out and replace it with the new one.
    Nov 27, 2010 | Ford F-250 Cars & Trucks
    Rear wheel bearing
    if its like the 99 winstar:
    safely support the van, remove rear wheel, remove brake drum, remove grease cap. remove caged locknut assembly (38mm socket i think.) then pull the hub assembly from the axel. you may need to cut away the inner race if the bearing falls apart. clean axel, apply alittle anti size compound, then push on the new hub assembly. tighten down the hub nut to specifications (should be on the leaflet in the new bearing package), install dust cap, install drum, install wheel, lower and drive :)
    May 25, 2010 | 1998 Ford Windstar
    How do you remove front wheel bearing
    is this front wheel? rear wheel? or 4 wheel drive? if you have front wheel drive or 4 wheel drive you will need to take the tire off and get the center cap off with cotter pin on most vehicles. then put the tire back on without its center cap. then put the vehicle back on the ground. then use required socket with an extention and breaker bar to put through the rim to loosen center hub bolt about a quarter turn. just enough to break it loose. then take the tire back off to finish the job. remove the brake caliper and rotor then center nut on hub bearing. there should be 3 bolts from the inside holding hub bearing on. on rear wheel only you won't need to take the tire off and on.
    Oct 08, 2009 | 2000 Honda CR-V
    How do i replace the rear wheel bearing on my peugeot 206 1.9hdi year 2002 my rear wheel bearing has gone on my pug206 and i want to know how to fix, replace and repair myself i have bought the rear wheel...
    wheel off remove the tin cap in the centure of the hub undo the big nut put the wheel back on with just 2 bolts finger tight so you can pull the hub off.once the hub is off take the 2 wheel bolts back out.now look in side the hub were the big nut was and you will see a sir clip take that out.then use a socket and a bench vice to press the old bearing out.use the socket and bench vice to put the new bearing back in.
    Jul 20, 2009 | Peugeot 206 Cars & Trucks
    Directions replace front wheel bearings on a 1985 nissan stanza?
    NOTE: After the wheel bearings have been removed or replaced or the front axle has been reassembled be sure to adjust wheel bearing preload. Refer to the Adjustment service procedure below. On the 1989–92 240SX there is just one wheel bearing, pressed into the hub and no adjusting cap. Refer to the exploded views of the Front Axle Hub Assembly. Review the complete service procedure.
    1. Raise and support the vehicle safely.
    2. Remove the front wheels and the brake caliper assemblies. NOTE: Brake hoses do not need to be disconnected from the brake caliper assemblies. Make sure the brake hoses are secure and do not let caliper assemblies hang unsupported from the vehicle.
    3. Work off center hub cap by using thin tool. If necessary tap around it with a soft hammer while removing.
    4. Pry off cotter pin and take out adjusting cap and wheel bearing lock nut.
    5. Remove wheel hub with disc brake rotor from spindle with bearings installed. Remove the outer bearing from the hub.
    6. Remove inner bearing and grease seal from hub using long brass drift pin or equivalent.
    7. If it is necessary to replace the bearing outer races, drive them out of the hub with a brass drift pin and mallet.
    8. Install the outer bearing race with a tool (KV401021S0 special tool number) until it seats in the hub flush. NOTE: Place a large glob of grease into the palm of one hand and push the bearing through it with a sliding motion. The grease must be forced through the side of the bearing and in between each roller. Continue until the grease begins to ooze out the other side through the gaps between the rollers. The bearing must be completely packed with grease.
    9. Pack each wheel bearing with high temperature wheel bearing grease. Pack hub and hub cap with the recommended wheel bearing grease up to shaded portions. Refer to the illustration.
    10. Install the inner bearing and grease seal in the proper position in the hub.
    11. Install the wheel hub with disc brake rotor to the spindle.
    12. Install the outer wheel bearing, lock washer, wheel bearing lock nut, adjusting cap, cotter pin (always use a new cotter pin and O-ring for installation after adjustment), spread cotter pin then install the O-ring and dust cap.
    13. Install the brake caliper assemblies and bleed brakes if necessary. Install the front wheels.
    Jun 23, 2009 | 1985 Nissan Stanza
    How to change the front wheel hub for 2000 LINCOLN LS
    hi you will have to remove the wheel,grease cap from the hub remove the brake caliper and move aside (do not seporate rubber line). (discard caliper bolts can not be reused) remove rotor,wheel hub retainer nut (and discard nut can not be reused) in order to remove the hub
    install
    hub and new nut and tighten new nut to 189-254 ft.lbs
    rotor new grease cap seal
    brake caliper with 2 new bolts tighten to125-170 ft.lbs
    wheel tighten to85-104 ft.lbs
    pump the brake pedal befor moving car
    Feb 06, 2009 | 2000 Lincoln LS
    Inglesina Classic Bassinet LG3 Carriage Stroller Logo
    27 people viewed this question
    Top Inglesina Baby Gear Experts
    paulcarew
    Dorel UK
    Dorel UK
    Are you an Inglesina Baby Gear Expert? Answer questions, earn points and help others
