Question about Samsung Lands Phones
My samsung mobile phone just got very warm and now is not working
    President:
  • 1,738 Answers
Thanks for visiting FixYa!
From your description, it sounds like your battery is the problem. Remove it and replace it. Do not attempt to use it in your phone again.
This is usually caused from using a charger (usually a car charger) that is either defective or not made to charge your phone.
Posted on Apr 01, 2011
  • jotebb Apr 03, 2011
    Thanks but the battery works in my daughter's phone. I assume the handset has had it, surprising as it is only 2 years old?
Hie,i'm using gt-s5233a so how can i activate my mobile tracker
someone inserts a new SIM card in your mobile
phone, the mobile tracker feature will automatically
send the contact number to two recipients to help
you locate and recover your phone.
To activate the someone inserts a new SIM card in your
To activate the mobile tracker,
1. In Menu mode, select Settings ? Security ?
Mobile tracker.
2. Enter your password and select Done.
3. Select On to turn on the mobile tracker.
4. Select Empty under Recipients to open the
recipient list.
5. Select Add recipients ? Phonebook to open
your contact list.
6. Select the contacts you want.
7. Select a number (if necessary).
tracker,
Mobile tracker.
recipient list.
your contact list.
Mobilepriceshop com Full Phone Prices and Specifications
Jan 01, 2016 | Cell Phones
My samsung memoir will not restart once i turn it on..the samsung white screen comes on and just stays on and nothing else. Please help!
Remove the Battery of your mobile
And Dry the mobile in warm air (by hair dresser) for couple of minutes
Then Re insert the battery and turn it on
Sep 01, 2011 | Samsung Memoir SGH-T929 Cell Phone
My touch screen is frozen and i can get it to unfreeze
First of all remove the battery and the memory card from the phone. Use a hair dryer to warm up the battery compartment so as to warm up the set lightly. Now replace only the battery after about 15 minutes back into the phone and switch on. If the phone boots up and comes alive with the touch pad working, then reset phone to factory settings, connect your phone to PC to have a virus scan . Also now have your memory card scanned for virus, remove files and format.
If however the fault stays then you might have to contact Samsung to have the software reinstalled.
Jul 09, 2011 | Samsung LCD SCREEN PROTECTOR FOR T-MOBILE...
When i turn my samsung gravity on my screen pops up asking for a password and in the other corner it displays sos!!! I got the phone from a friend and i dont know the password!!! And not all my buttons...
HI surely u can reset the ur samsung mobile password online but first try to reset the phone by typing 0000 or 1234 if it is a 4-digit password or type 00000 or 12345 if it is a 5 digit password because these are known as the default codes of ur samsung mobile to do it online visit the site www.unlocking4u.com or www.mobileunlock.co.uk and unlock ur phone instantly was this useful pls rate my solution if u liked it
with warm regards-bonefirediv
Apr 09, 2011 | Cell Phones
My Drenched Samsung mobiles--Please help!
ok you should put your mobile outdoor in front of sun for 1 hour off the battry from it then put it.other wise your mobile need some thing little bit warm to dry water inside it ok .if not solve then tell me again ok.
Sep 16, 2009 | Samsung SGH-D900 Cellular Phone
I need a code to unlock my SGH-D415 t-mobile cellphone
HI HERE IS A SOLUTION CAREFULLY FOLLOW IT Warning: Do not enter any wrong unlock unlock codes on your Samsung SGH-D415 mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Samsung SGH-D415 mobile phone with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung SGH-D415 mobile phone is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-D415 mobile phone.
If it does not work, you can try these methods:
Method 1:
2 - ;;Phone;; will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung SGH-D415 mobile phone shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung SGH-D415 mobile phone.
3 - Compose : #0111*CODE#.
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung SGH-D415 mobile phone.
Each Samsung SGH-D415 mobile phone has an unique unlock code. You can buy the unique unlock code for your Samsung SGH-D415 mobile phone at www.mobileunlocksolutions.com. HOPE YOU SUCCESSFULLY DO.... PLEASE RATE ME THANK YOU
Feb 19, 2009 | Samsung SGH2100SGH600V300 Unlock/Unlocking...
I have a Samsung M520 and the back gets very warm while talking of watching sprint tv
hard to say much about that, cause most phones do that after hours of use but you should take the phone into a mobile shop and have then check the phone for you or test the battery to see if th battery is the faulty.
Nov 30, 2008 | Samsung Cell Phones
D900 samsung keypad not workin
problem with your phone arises from contact with water or extreme humidity.there are components called varistors that protects cpu from electrostatic discharge,and they are faulty.try to put a phone in a warm place,hopefully it will get dryed out and work again.other solution is to disasemble your phone and remove those faulty components
Aug 31, 2007 | Samsung SGH-D900 Cellular Phone
Lands Phones Logo
24 people viewed this question
Top Samsung Lands Phones Experts
Jose Ma DM.
Jose Ma DM.
imfedup19
Level 1 Expert
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
