Question about Canon PowerShot A710 IS Digital Camera
Hi - I have a Canon Powershot A 540. I tried to put the memory card into my PC's SD Card Reader to transfer the photos. The PC could not read the SD card and when I put the card back in my camera the message says No Image. What can I do to recover the photos that are on it? Thanks!
  • 5 Answers
SOURCE: sd card error on canon powershot s3
I have had a similar error which turned out to be a corrupted memory card. It was replaced under warranty with no questions asked. Causes may be static electricity discharge or a high humidity/temperature combination. Either way get a new card.
Posted on Jul 31, 2008
  • 3 Answers
SOURCE: memory card error after inserting SDHC card on powershot A620
the a 620 only goes up to 2 gb no higher
Posted on Jan 28, 2009
dlundmark
  • 797 Answers
SOURCE: canon powershot A470 problem when i click photo
Go to the menus and find the set to default option.
This should reset the menus and options to original.
Go to the menu section find a setting something like this... such as.. reset all to default or set to factory default or simply RESET.
Check to see if the pictures are saved to the card by taking a picture, then remove the card and play it back in either another camera or use a card reader to read the card.
If these tests shows that no picture was taken or it is all white, then the camera needs repair or has a ccd problem.
Another option is to call Canon Repair at the following page and use the 800 number for calling the repair department.
Canon has a trade-up or trade-in program which is a great way to get another camera at a good price. Canon will allow you to trade in your camera for a reasonable price against a refurbished camera plus a cost which is reasonable. A refurbished camera will come with everything it had when new, and will have been restored to original specifications.
Posted on Oct 27, 2009
  • 3 Answers
SOURCE: My canon powershot sd 600 will not switch between
Had same problem and just fixed it! I just turned it off, took the battery AND card out for a few minutes and then making sure I had it switched to still mode, put the card and battery back in and turned it on. Working fine again. I suspect it actually does a 'reset' this way so what seemed to be a mechanical issue was definitely a software one ...
Posted on Jun 10, 2010
  • 8 Answers
SOURCE: Recovering deleted photos on Canon PowerShot SD750 Digital Camera
You definitely have chance, no matter you photos in Canon camera got deleted, formatted by accident or became inaccessible due to camera memory card errors. Chances of recovery is possible as long as you take the right action.
Take a try of this software to recover Canon photos, Not only general photo formats, but Canon RAW photo formats (.cr2 or .crw) can be retrieved easily.
Note: before the photos are recovered, Never should you attempt to take more photos or save more data to the memory card in case chances of photo recovery might be reduced. Hope it helps. Regards.
Posted on Sep 17, 2011
Read sd card on computer
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Nov 23, 2012 | Canon PowerShot S3 IS Digital Camera
Tip
How to Recover Lost Photos and Video from Canon PowerShot SD780 IS
<span> <span><img src="maggiena_8.jpg" /><br /></b></span>Canon PowerShot SD780 IS</b> may be the slimmest Digital ELPH Canon has ever created with dimensions 2.10" h x .70" w x 3.40" l, .26 pounds and 2.5 display size. It captivates the senses with bold saturated colors and a daringly original design that matches the intensity of Canon's most innovative camera technology.</span> <span><br /></span> <span><span> <p>Owning to its wonderful picture quality as well as high resolution, it becomes the first choice for many photographer lovers. One more reason that it turns out to be so popular is it supports various standard storage media like SD/SDHC, Multimedia Card, MMC Plus and HC MMC Plus memory cards</b>. images, Video and other multimedia file like songs can be saved there. Usually, keeping a backup of data like pictures and other multimedia files is recommended at the very beginning in case the data was lost by mistake in the process of using the camera. However, if you forgot to backup, you have to use a third party program to <a href="http://www.card-data-recovery.com/">retrieve Canon PowerShot SD780 IS data</a>.<br /> <p><br />Cases about losing data</b><br /> <ul> <li>1. When connect Canon PowerShot SD780 IS to your computer and being transferring vocation photos from SD card to computer, accidently your camera shut down due to low battery. After change the battery and restart camera again, you may encounter the error message "memory card error" that means the memory card is inaccessible.</li> <li>2. While reading data or writing data to SDHC card, "I/O device error" occurs and all photos and video miss.</li> <li>3. On the process of shot, message "memory card is full" pops up to you. However, after deleting some pictures, it shows the same result.</li> <li>4. Connect your SD card reader to computer, the window pops up with message "you have to format SD card before using it". After formatting SD card, all your pictures and video lose.</li></ul> <p>Resolution</b><br />If the above phenomena happen, don't panic, lost photos and video in Canon PowerShot SD780 IS are recoverable. First thing to do is stop using camera to shot for fear that the data was overwritten. For the first two cases, make sure the SDHC memory card is properly inserted. If it still can't be recognized, try to use a card reader to connect it to PC. Or else you have to format memory card and use effective photo recovery software to get back lost photos. For the last two cases, you should rely on <a href="http://www.card-data-recovery.com/">Canon PowerShot SD780 IS picture recovery</a> program. There are many effective Canon digital camera photo recovery program available in the internet, just choose the perfect one for your camera. <br /></b><br /><br /></span></span>
on Jul 20, 2011 | Cameras
Camera reads communication error when trying to upload photos what might be the prob
I BELIEVE THE REASON IS THE TYPE OF SD CARD.
THERE ARE SD AND SDHC. IF YOU ARE USING SDHC.
I BET THE ONE CARD THAT DOESNT READ IS AN HC. THIS IS ALSO TRUE WITH OLDER CARD READERS. I HAVE AN OLDER AND NEWER CARD READER.
I JUST HAPPENED TO PUT AN OLDER SD CARD IN MY NEW POWERSHOT SD1300 AND IT READS FINE, ALL NEW CARDS SDHC WONT READ.
I BELIEVE SD IS UP TO 2GIGS AND SDHC IS 4GIGS AND HIGHER.
Aug 24, 2010 | Canon PowerShot SX120 IS Digital Camera
How to transfer pictures from my Canon PowerShot SD1000 digital camera to my computer
There are two ways of doing this:
  1. Install the software on the CD that came with the camera, then use the USB cable that came with the camera to connect it to the computer. The software should walk you through the rest of the process.
  2. Buy an SD card reader (example Card Reader from Amazon.com), connect it to your computer, and take out the SD memory card from the camera, and insert it into the appropriate card slot on the card reader. Then use whatever photo management software to manage your photos.
I would recommend the second method since it reduces the wear and tear on your camera and allows you to access the photos easier through Windows Explorer or Finder (MacOS).
Hope that helps!
/davey
Oct 14, 2009 | Canon PowerShot SD1000 Digital Camera
Can i load pictures from my sd card without using a usb thing? is there any other way?
The only other way is to transfer the photos from your SD card to a CD or DVD and then you can use that CD or DVD to transfer the pictures to any computer you want. Some computers have an SD slot in the front, so you don't need a USB drive in that case. You can also go to a photo store or even a kiosk photo machine that you put your SD card in and it will develop the photos and you can get a CD sent to you from Kodak or whoever owns the machine. USB drives can be bought for $10 or less now, so maybe the easiest thing would be to get one.
Sep 12, 2009 | Canon PowerShot SD780 IS / IXUS 100 IS...
Transfering photos back to memory card
Hi, Welcome to FixYa.
You can do it through your laptop's card reader or using a card reader device.
Take your memory card out from the camera and put it in the
adapter(a card holder) given to you. Now you can use it in Laptops
in built-in card reader/ card reader device.
If the SD memory card is read only this will not work, otherwise
this way you can copy photos to Card very easily. Also you can copy
photos from memory card in the same way
Our site need your feed back for improvement.
If the post helped you please select 'YES' here
Jul 09, 2009 | Kodak EasyShare C340 Digital Camera
Writing from pc to memory card in camera
Go with the obvious solution. The camera only lets the computer read the card and delete pictures. It does not let you write to the card.
Be aware that if you've edited the photos in any way (opening a photo in a photo editor and then saving it without making any changes counts as editing) then the camera may not display the picture.
Mar 21, 2009 | Canon PowerShot A560 Digital Camera
Communication error
If your SD memory card contains more than 1,000 images, the camera will display "Communication Error". Use a card reader (if available) to import your images into the computer, or see about having some CD's made at a photofinishing business.
May 20, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot SD700 IS won't upload the photos to the PC?
You could avoid this problem by using a simple cheap SD card reader. Remove the SD card from your camera, insert the SD card in the reader and connect the reader to your PC/Laptop by a USB cable. You can then useWindows to view and upload your pictures
Nov 04, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon PowerShot A710 IS Digital Camera Logo
19 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
