Mitsubishi Proj TV WD-52825 will not turn on. Continuous blinking green light...reset and unplug no help...HELP!
  • cruzfr Dec 15, 2008
  • Anonymous Feb 20, 2009
    tv will not turn on, when pwr finally went on the green light kept flashing won't shut off. this tv is a lemon, i have constant problems with it. only 3 yrs old. help......
BIg do we also Replace C9A37 and C9A38 ON POWER PCB. (3300uFD, 16 V).with 680uFD, 16V, 105c part number 181P734030. too.
Posted on Sep 06, 2008
  • 927 Answers
Good Day, Markes;
You and a million others are having this problem. Are you handy? Did you say; yes/kind of?
HERE IS THE SOLUTION FOR THAT PROBLEM AND THE ONES YOU WILL HAVE IN FUTURE:
Replace C81A2,C81A3, C81B3 AND C81B4 (1000uFD, 16 V) On DM PCB.
Replace C8F19, C8F21, C8F22 and C8F27 (1000uFD, 16 V) On FMT PCB.
Replace C9A51, C9A52, C9A61, C9A62 On power PCB.
REPLACE ALL WITH (680uFD, 16V, 105c), part number 181P734030.
Good Luck, big IRISH.
ps; Three boards on left side of TV and about 2.5 to 3 hours of repair time.
Posted on Aug 05, 2008
Green blinking light on Mitsubishi DLP 52825
Hello, unplug the tv and check the lamp to see if it is broken inside. here's a link on how to replace the lamp.....tks.... https://www.youtube.com/watch?v=3bQ0wut_pWg
Jan 26, 2015 | Mitsubishi Televison & Video
I have a Misubishi DLP wd 52825. The timer light keeps blinking and I have no picture or sound. I cannot turn the power on. How can this be repaired? Or what is wrong with it? I have unplugged the TV for...
Most likely the issue is bad capacitors. You need to check for bad 1000uf 16v caps on the dm board and the fmt board. Be sure to checked surface mount fuses on DM and FMT board after you replace the capacitors.
Not to easy of a job due to how much dis-assembly needs to be done. Instructions can be found online on how to do this.
Mar 08, 2011 | Mitsubishi WD-52825 52" Rear Projection...
After a power failure, I have a blinking green light on a mitsubishi wd 52825 that won't reset. What should I do?
Install the V26 DM repair kit and The V26 power repair kit. They are both available from www.tvrepairworld.com and also come with the CD with detailed instructions
Jan 09, 2010 | Mitsubishi WD-52825 52" Rear Projection...
Blinking green light for Model WD-52825. What
The usual cause is due to the DM not booting up due to failed capacitors. You can get the V26 DM repair kit at www.tvrepairworld.com which contains the replacement capacitors and the CD with detailed instructions.
Dec 20, 2009 | Mitsubishi WD-52825 52" Rear Projection...
We recently changed the bulb cartridge. We receive broadcast tv, no cable, no sat. Our WD-52525 had worked perfectly until we changed the cartridge. Now it will not stay on, it shuts down and the green...
Hi the cartridge's work is to hold the lamp in place it will not go faulty or melt or will prevent tv from lighting up.Did you close the door cover on the back properly.Did you reset the lamp timer? Do it by unplugging tv wait 5 min and plug it back again.Pay attention to clicking sounds or like wanting to turn on it could be a bad ballast and that's the board that powers the lamp.Hopefully you dont have "The green light of death" Issue. It tells all about it here http://www.highdefforum.com/rear-projection-tvs/58189-blinking-green-light-death-frequent-prob-w-mitsubishi-rear-proj-widescreens.html Good luck and God bless you!
Oct 05, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi Mod. WD-52825 projection tv
9 times out of 10 it is not an easy fix. however ot is not an expensive fix either. checkout www.tv-techs.com
Oct 31, 2008 | Mitsubishi WD-52825 52" Rear Projection...
Mitsubishi WD-62725 constant blinking of green light
Check the lamp to see if it is damaged(this is in your owners manual for removal)If not please contact me for more info
Mar 24, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Televison & Video Logo
316 people viewed this question
Top Televison & Video Experts
