Question about Umax AstraPix PC100 Webcam
When i click on install the driver....it says result it will uninstall the driver
Power LED gives a single red flash
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Feb 14, 2013 | Panasonic BL-C20 Network Camera
How can i install my webcam?
U probably have installation disk with your camera, so insert the disk, plug in the camera and start installing from the disk. When installation process finished unplug the cam, restart your computer, and then plug in the camera again-it should be automatically recognized.
Let me know the result.
Jun 18, 2011 | Logitech C120 Webcam
Driver --- ATI rv6p....... please
http://support.amd.com/us/Pages/AMDSupportHub.aspx
This is a link for ATI/AMD drivers. In the upper right corner is a window"Download drivers"
1 Component catagory- click on arrow on right, scrool down to "desktop graphics", click on to select.
2 "Product line-click on and scroll down to Radeon 7xxxx series and click to select
3 "Product model-click on and scroll down to Radeon 7000 series and click to select
4 "operating system-click on and select your system
Click on "Show Results". This will give you a list of drivers for your card. Choose the first option and download. Click on run, etc. IT will get to a point where it will ask for Express or Custom install. Choose Express. Restart at finish of install.
*****Note**** you must uninstall all prior ATI/AMD software before you do this, through "programs and Features" Click on ATI Uninstaller, click on next, you want Express unistall which should remove all ATI software. Restart after uninstall the, follow steps above.
Mar 08, 2011 | ATI PowerColor RV6P-B3 RADEON 7000 PCI...
My cam is focusing only a blackish snaps it does nt giving me accurate result as it was wat is the prblm??
Dec 31, 2010 | A4tech Viewcam PK335 Webcam
Why my computer did not detect sound.. even if i check the control panel sound volume and mixer working properly.. i try to install sound card same result...
you might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Nov 16, 2010 | ASUS 90YAA0C00UAN00Z Xonar Essence STX...
I have gigaware webcam with mic. i installed
HI,
I suggest you first to uninstall and reinstall the camera drivers from the disc provided to you with this camera and also uninstall and reinstall skype.This should fix the issue.
let me know the result.
Thank you for using fixya.
Jan 29, 2010 | Radio Shack VGA PC Camera Webcam
Why cannot i touch an icon and it would be 2 days sooner for acti
If you are having any issues with the webcam software then please uninstall and reinstall your webcam drivers/software from the disc provided to you.
If you do not have the disc then let me know and i'll provide you with a download link so that you can download the software.
This will fix the issue.Let me know the result.
Dec 13, 2009 | Logitech Webcam
Skype 4.1.0.179 restarts pc when using camera, is this version not compatable with windows xp?
HI,
Your camera is 100% compatible with Windows Xp.
Please uninstall your webcam first and then skype.After that reinstall webcam and then the skype.
Nov 15, 2009 | Logitech QuickCam Pro 9000 Web Cam
How do you reset an Ezonics EZ 329 cam to its factory default?
There are two ways to solve this problem the first im certain you tried which is unplug it ,turn the machine off and allow the OS reset the software. The second is a tair down procedure UNinstall and reinstall the sofware so it will reset . If this dont work repost the results with the procedure you used.
Oct 18, 2009 | Ezonics EZCam Webcam
The Internal Mic In My Dell Inspiron 1525 Isnt Picking Up Sound??
You need to set the internal mic as the default input device. To check this Right click on the sound icon next to the time and select Recording properties. In the Recording properties right click on Arrey Microphone and select set as default. If this does not help. Uninstall and reinstall the sound drivers. To uninstall the sound drivers click on start and type DEVICE. Open device manager from the results and then look for sound devices. Click on the Plus sign next to Saound and audio devices. Right click on the SigmaTel entry there and select uninstall. Put a check on remove this driver from the computer. Once done restart the computer and go to support.dell.com and click on Drivers and Downloads. Enter your system service tag and download the Sigmatel audio drivers and install them. Check if the MIC works after the restart. If the Arrey microphone is set as the default and you have uninstalled and resinstalled the drivers and it does not work in MSN try recording with the Windows sound recorder and see if it works there. To open the sound recorder click on start and type SOUND. Open sound recorder from the results. Incase the mic does not record even in the recorder it could be bad or have a loose connection. If in warranty call/chat with the Dell technical support. If the warranty has expired consult a local computer guy.
Mar 29, 2009 | Dell Inspiron 1501 Notebook
Umax AstraPix PC100 Webcam Logo
21 people viewed this question
Top Umax Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
tdk1988
Are you an Umax Computer and Internet Expert? Answer questions, earn points and help others
