Question about Arris SURFboard SB5120 Modem
Only power and pc/activity light are on.
Whenever I power it up, only the power and pc/activity lights turn on. Any solution to this, or is it done?
  • koppatin123 Aug 11, 2008
    i disconnected all the cables to my router and modem. and wait. then later i plug everything back. but only the power and pc/activity light are on. and i try to turn off the modem by pressing the standby button but nothing happens. the lights just stay on even though i press the standby button.
Only thing to do is buy a new modem. Mine did the same after a power surge. Left it all night off and in the morning started working again.
a month later, another power surge and never started egain. Just got me a new one and called Comcast to activate it. Problem solved.
Good luck there
Posted on Oct 17, 2008
SOURCE:
Nothing displays on the monitor when I turn on the computer
is there power to the monitor? is the monitor in standby(yellow light on monitor)? is the monitor on (green light on monitor)? how is the monitor connected to the computer, VGA (square fat cable, the end may be blue) or HDMI cable? When you turn on the computer is the power light on and HDD light flashing / showing activity? this would indicate that the computer is booting up. If you have power light and activity on the computer, I would unplug the data cable to the monitor. If the monitor is plugged in, i would press the power button to try and turn on the monitor / take it out of standby. If the monitor is ok you should see a message like "no signal" or "no input". This would tell you that the monitor is fine, but you may have a problem with the video card or video port on the motherboard. If you have no activity light on the on the computer, you may have a problem with the OS not booting up. You really didn't provide much detail on what has been done, but this is how I troubleshoot out in the field when working on something like this.
Oct 09, 2013 | Computers & Internet
2011 tiguan trailer warning light comes on whenever any trailer is connected
Very first thing you should have done is to check the ground between the vehicle frame and trailer frame. That's the only thing that can be causing this problem. Be SURE the grounds are connected very well. I've found the ground to be the only problem in these situations every time. Can't be anything else, it's all good.
Jul 07, 2017 | 2011 Volkswagen Tiguan
The wifi light and caps lock light won't turn on on my hp compaq 6715b, also the num lock light wont come on and the mute light just does a quick flash and does not stay on. this all happened after having...
Hi
When you say that you slid your finger back and forth on the strip
do you mean the strip along the back of the laptop just below the screen ??
Because on some laptops the wifi switch and cap locks and the mute switch are all along
that strip
so you may of by accident pushed them all and de activated them all
pressing them all in turn should activated them again but if they done
then you could try FN+ the keys that you want to activate
Feb 18, 2011 | HP Computers & Internet
Dell inspiron 1525 won't turn on
Try to take out the battery and just use the adapter to power it on,
If your done with that then try just using the battery to turn it on, if it still won't give a single light.
If you can borrow an ac adapter for that laptop try it ,
If it still doesn't work. You'll need to replace the motherboard. Just make sure the ac adapter your gonna use is working good.
Feb 12, 2010 | Dell Inspiron 1525 Laptop
Power Problem. Sudden onset of laptop not coming
The most likely answer is the motherboard will need to be replaced. Here are some troubleshooting steps:
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
Jan 14, 2010 | Dell Inspiron E1505 Notebook
Acer Aspire screen turns black
Easy
Go to your power setting option and select never for turning the system to stand by and hibernation.
Oct 18, 2008 | Computers & Internet
Computer problem
If you are referring the green or amber light on the front of the case, it could either be the power led or the hard drive activity led. If its the hard drive activity light, it usually just blinks when a program accesses the hard drive.
Thanks
May 13, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Blinking red light
What laptop brand and model is it? And where is the LED that blinks? Important details! Some laptops have a power light that blinks red while battery charges, then it turns steady green when battery is full. Some laptops have a red LED that lights whenever there is hard drive, CDrom, or floppy activity (read/write). This all depends on your laptop brand/model and where the LED is (side, near floppy/CD, top near screen, or on battery itself... so provide more details for me, please!
Nov 13, 2007 | Dell Latitude C640 Notebook
Arris SURFboard SB5120 Modem Logo
682 people viewed this question
Top Arris Computers & Internet Experts
Ekse
Greg Ulan
Ann Moroz
Ann Moroz
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
