Question about Intermec EasyCoder PC4 Label Printer
I need intallation guide of intermec easycoder pc4 & driver download link hlp me thanks
  • 21 Answers
Http://home.intermec.com/eprise/main/GSS/Service/Content/Downloads/Show_DownloadSearchResults?Product=PRTRPC4C
Posted on Nov 01, 2013
5 Suggested Answers
JongCur
  • 88 Answers
SOURCE: Failed to print using Intermec Easycoder pc4 label printer
If you have another USB port asidefrom the oneyou are using now try to transfer your printer cable. Make sure your USB port is firmly connected to the motherboard. Follow the USB connectors and check if these are well fitted and not loose.Apply pressureon the endsto set the connectors.
Posted on Jun 21, 2008
SOURCE: Intermec EasyCoder PC4 Label Printer
JUST PUT IN TO PORT COM3 AND GO.
Posted on May 12, 2010
ozztech
  • 285 Answers
SOURCE: Where can I buy a couple of new Intermec EasyCoder
were you locate?
Australia - Peacocks.com.au
Posted on Nov 12, 2010
  • 138 Answers
SOURCE: Hello, I've got an intermec easycoder
http://www.intermec.com/support/downloads/search.aspx?categoryid=7&familyid=12&productnodeid=PSWLBLSHOP
Posted on Mar 02, 2011
Label height is not managed correctly on the intermec easycoder PC4 that I got second hand... How to deal with this issue???
Go to printer properties and put in the custom label size. You will need to do this for each user of the computer.
Jun 28, 2011 | Intermec EasyCoder PC4 Label Printer
PC4 my light it but nothing happens just stays on the red light
printer has two litle switches on the back of the opening buttons and if not close properly printer will not work ,switches can be faulty also
Jun 25, 2011 | Intermec EasyCoder PC4 Label Printer
My problem is i am connecting the intermec pc4 on the laptop windiows 7 and it does not have a pararell cabel in the laptop i am trying to make the mashine recognize the serial and usb port
Read these instructions. You will need to buy a usb printer cable and follow these directions below. Good luck!
We at our laboratory have about 35 Intermec printers and after much trial and error they work well for us. They practically never break. I have also called their tech support and they were very helpful. They advice was FREE. (I promise I do not work for them)
Intermec Install Notes: (from Intermec)
How do I install the USB driver for my EasyCoder PC4 (PC4B or PC4C) printer?
Answer
Tools Required:
1. EasyCoder PC4 (PC4B or PC4C) printer.
2. Microsoft Windows compatible PC. (XP/2000 recommended, Vista NOT supported ( Note from Dole: it works with Windows 7 and probably Vista and Windows 8)
3. USB Cable.
4. Available USB port on your PC.
5. Latest version of the USB drivers (2.0 or better) which can be downloaded from http://home.intermec.com/eprise/main/GSS/Service/Content/Downloads/Show_DownloadSearchResults?Product=PRTRPC4C
Note: There are two parts to installing the USB driver. You will go through the Found New Hardware wizard two times. The first part is installing USB port and the second part is installing the USB to Serial port.
1. Download and unzip the USB drivers to a location on your PC.
2. With the printer turned off plug in one end of the USB cable to USB port on the printer and the other end in to an available USB port on your PC.
3. Turn the printer On.
4. Now you will get prompted with the "Found New Hardware" dialog box. Select "Install from list or specific location" and click Next.
5. Click Browse and select the location where you unzipped the files in step 1 and click OK.
6. Click Next. The USB driver will now install.
7. Now you will get another "Found New Hardware" dialog box for the USB Serial port. Select "Install from list or specific location" and click Next.
8. Click Browse and select the location where you unzipped the files in step #1 and click OK.
9. Click Next. The USB Serial driver will now install.
10. Now reboot your PC. The newly installed port may not show available until you reboot your PC one time.
The USB port is now successfully installed. In Windows the USB port will be assigned to a Com port. To find out what Com port number is assigned to it go to Device Manager and then Select Ports. You will see USB Serial Port (COMx). In addition, when using the Intermec InterDriver Windows print driver. The USB port will be shown as USB00x and the Description will be Virtual printer port for USB.
(You may need to set the printer as the default printer)
Other things to know about these printers: ( not from Intermec )
1) There are 2 types Direct and Thermal transfer. Direct I think heats up the label to get the writing on the ribbon. Thermal transfer uses a one time use ribbon to transfer images to the label.
2) You should use Intermec labels, if you otherwise the labels will probably not print properly
3) How to reset the printer. Turn off the printer, (in the back) then turn on the printer while holding down the Reset button on the top. Release the reset button when the light turns green then wait for the printing to stop. IMPORTANT: Next press the reset button for 1/2 second. If you hold it too long it will not reset the printer properly.
4) Every user will need to set the default label size.
5) If the print is coming out is hard to read do the following. Open the printer then remove the ribbon if there is one and scrape the metal with your fingernail. They give you alcohol and a cotton pad but your fingernail will work fine.
6) Another problem we have sometime is a label falls off and covers a sensor so the labels do not know when to stop. This hardly ever happens but look under the labels and check the sensor.
Feb 18, 2011 | Intermec EasyCoder PC4 Label Printer
PC4 doesnt appear to recognize ANY IPL coding
1. Add Generic Printer to printer list.
2. Select Generic printer as Default printer
3. open the document and print.
Jul 14, 2008 | Intermec EasyCoder PC4 Label Printer
May 12, 2008 | Intermec EasyCoder PC4 Label Printer
Intermec EasyCoder  PC4 Label Printer Logo
123 people viewed this question
Top Intermec Office Equipment & Supplies Experts
pkwc
donjackson
Level 1 Expert
Paul Bade
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
