Question about Staples Office Equipment & Supplies
After shredding a piece of paper the machine wont shut off it keeps running
  • 300 Answers
Please check to make sure the paper sensor is not blocked in some way.
This usually happens if there is any sticky tape on the paper or envelope shredded.
Posted on Apr 01, 2011
Why wont my staples titanium shredder continuously shred?
Not giving a model number, it's hard to say. But quite probably after use for 20 mins, the machine starts getting hot, and then it shuts down while the machine cools down.
I had the same issue with a shredder of mine. It prevents the machine burning itself out.
If you want one that just keeps going and going without heat issues, you have to pay more for a better shredder. Unfortunately.
Jul 30, 2014 | Industrial Paper Shredders Office...
Why does my paper shredder make a clicking sound when I try to shred a piece of paper?
Try putting a piece of paper in enough to start it running, but not so far as to go into the shredder. See if it will run for a minute or two. Sounds as though it may be over heating.
May 03, 2014 | Generic aurora as1016cd heavy duty...
My royal shredder js1100 will only shred in reverse.
Simple to solve!
Get some longnose pliers or strong tweezers.
Unplug the beast. You do not want to shred your finger nails, or your fingers.
Flip the mechanical part upside down. You will find small pieces of papers near the rollers. Pull them out with tweezers or pliers.
Keep hands out of harm\'s way, plug shredder and make it run in reverse for 1/10 of a second.
Unplug and remove more paper impacted in between rollers.
Repeat last two steps until no paper is seen by the rollers.
Plug and continue shredding your papers
Piece of advice. Do not shred your credit cards in shredder. Scissors are cheaper and do not mess your shredder!
Jan 15, 2014 | Office Equipment & Supplies
Shredder keeps running after shredding paper
Take a can of the compressed air like you would use on your keyboard and blow everything out inside the slot where you put the paper... there is a piece of paper or dust infront of the sensor the tells the machine to run...
heatman101
Jul 30, 2011 | Office Equipment & Supplies
Shedder OM99732 in automatic mode will start and shred when paper put in, but will not shut off. It also appears there is some type of plastic covering the screws so I am unable to remove the cover. It...
It sounds like a piece of paper is blocking one of the two photo cells that detected when a piece of paper (or a CD / DVD) has been inserted for shredding. The (six) screws that secure the top are accessible from the bottom of the shredder unit after it is removed from the paper bin. Be careful: There are three different sets of wires connecting the top control plate to the bottom motor and cutter assemblies. It is not too difficult to get inside the shredder "head" if neccessary.
Aug 23, 2010 | OfficeMax Office Equipment & Supplies
Paper shredder does not turn off. I have to open
I'm assuming that it automatically detects the presence of paper... .
By opening the drawer you're disabling it from the safety switch. (they dont want you to shred your fingers from the bottom) There is probably a small piece of paper holding the feed sensor down.
If you're confidant, unplug the unit and take apart the plastic cover. Do not remove anything inside. Look for the small switch between the blades which 'feels' the presence of paper. There is probably a small piece of paper wedged between the housing and the switch which would fool the unit into thinking it has paper that still needs to be shredded.
Carefully put your unit back together and happy shredding.
This may happen often, remember what you did!!!
Jul 30, 2009 | World Office Products Papermate PM-1550CD...
Shrededer motor remains on after shredding is complete
Blow out the sensors with some compressed air.(Computer Duster) they are likely covered in paper dust and the machine believes paper is present.
Please be sure to unplug the machine before attempting any sort of repairs
Hope this is of some help
Ed
Apr 20, 2009 | Fellowes SB-99Ci Shredder
Champion shredder WQ120D will not shut down after shredding but continues to run . must move to center position to shut down
If you look at the blades, some are likely bent (probably the middle ones) causing the machine to not drop the clippings which makes it think that there's paper to be shredded. It's a common problem with this shredder and there's no fixing it because the company doesn't offer replacement parts. The shredder is an overpriced piece of junk. I bought mine at Walmart but our local store doesn't even carry them anymore because of all of the returns they've had.
Jan 20, 2009 | Office Equipment & Supplies
Red overload light is on
Try pouring some shredder oil into the throat where you normally insert the paper and run the machine in reverse.Put machine back into ready condition.
Put a piece of paper in the throat just enough so the machine should run but not all the way in so that the cutting mechanism catches the paper...all you want to do is make the machine run forwards but not actually be feeding in any paper.
If it wont even run in the forward direction you may have a pcb prob...give Royal a call at 1-800-524-0799 for parts assistance.
Jan 08, 2009 | Royal VF1012mx Shredder
Shredding paper partially
Your cutters have spread apart this could be caused by overloading machine to many times or something may have cracked internally that held them in place.
Jan 02, 2008 | Shredder Secure Shred Shredder
785 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Randy Schumann
Randy Schumann
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
