Question about Simplex Kaba Ilco Unican 1000 keyless lock
Can a L1000 series simplex kaba be switched to mount a right handed door
  • 963 Answers
No. The Kaba L1000 is factory-handed and is not field-reversible.
That information comes from the grid found on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13&obj=1000
under L1000/Specification/SimplexL1000 Catalogue PDF
Posted on Apr 10, 2011
Green light on numbers door doesn't open
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Aug 18, 2012 | Simplex Kaba Ilco Unican L1000 keyless...
I was changing the combination on my 1000 series as per instructions and when I reprogramed the new combination it worked the first time will not unlock it anymore. What can I do. Thanks
I suggest trying this:
Go to the Literature Grid:
and hover your mouse over PDF under the TIPS (rightmost) column for the L1000
Then click on the lower choice that pops up: "How to Reset a Lost or Unknown combination....."
Yow will then download the file with the instructions that you need.This is a PDF file; if it won't open for you, you need to download and install Adobe Reader (it's free):
http://get.adobe.com/reader/
If you are not successful, please contact the Tech Suport for Kaba-Ilco:
Technical Support (Simplex, E-Plex, PowerLever, 4000 Series, Solitaire 850L, Solitaire 850/950)
1-800-849-8324 (option 3, and then option 6)
I hope this helped. Good luck!
Jul 16, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
I tried reseting my combo on the simplex LP 1000/8100 series and messed up. I entered a new combo and the latch did not work. Not only did the new combo fail, I could not open it with the old combo. What...
Contact Kaba Ilco for technical assistance:
Jul 03, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
Lost combination on the unican 1000! How do i get it back or set a new number in it?
I will give you several sources of information for you to pursue.
First is a link to a chart where you can download PDF files for your lock ( the L1000):
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13&obj=l1000
There is a link on that page where you can download and install Adobe Reader in order to open and view PDF files, if you don'ta already have it installed on your computer.
Aditionally, here is a link to a website wherein it is described how to change the combination on the unican lock:
http://www.lilocksmith.com/keyless_Locks/unican1000.htm
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
May 17, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Iv'e got a Simplex L1000 series combination that needs the Outside Lever Assembly-Right Hand and Outside Sleeve Assembly changed on it. I have the parts needed but I can't figure out how to remove the...
Here is a link to the Kaba Ilco web page which has a grid chart, including the L1000 series lock:
Of particular interest to you will be the Manual (page 10) and Parts List, which shows an exploded view of the lockset. Hopefully this will give you the info that you need.
On the same webpage you will also find a link "Contact Us" for further technical information and parts.
Also on that page is a link to get Adobe Reader. If you don't already have it installed on your computer, you will need it to open the PDF files for the manual and parts list.
Hope this helps. Good luck!
Mar 17, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Lock has a Best core in the outside handle but door cannot be locked
I recommend that you contact Kaba Ilco directly for technical assistance.
good luck!
Mar 16, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
The KABA L1000 Simplex lock that I have won't open from one side of the gate. The master key and correct code will turn the handle, but the latch doesn't engage. The latch will open from the other side...
I recommend that you contact Kaba Ilco directly with your problem.
Feb 02, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
The lock is staying open when the door is shuting i need to lube it but dont know how to open it up to do so
The installation instructions for simplex keyless locks can be found using this grid on the KABA website. You will need Adobe reader to view-- these are PDF files:
Dec 17, 2010 | Simplex Kaba Ilco Unican L1000 keyless...
Simplex unican L1000 lock, occasionally the top two buttons do not 'connect' when pressed. Can this be remedied easily?
Nov 11, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Simplex Kaba Ilco Unican  1000 keyless lock  Logo
122 people viewed this question
Top Simplex Locks & Locksmithing Experts
Michelle Balcom
Pamela Leach
Pamela Leach
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
