Question about Estate TGP305TQ Gas Kitchen Range
Oven does not heat up on Estate TGP305TQ Gas Kitchen Range. This problem just occurred recently. The oven has not been used much. I checked the power outlet and verified that the outlet to which the gas range is plugged in works. Gas line is open and the gas pressure regulator shutoff valve is in the ON position. The gas oven still will not work.
  • Estate Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Aug 13, 2011
Whirlpool estate electric range model heat oven
there is also a temp sensor inside the oven that could be faulty
Sep 19, 2013 | Whirlpool GS440 Gas Kitchen Range
Oven will not lite
Oven not Working or
Oven not Heating
heatman101
Feb 25, 2011 | Estate TGS326TD Kitchen Range
My TGG220TQ's oven is not working. Both of the range pilot lights are lit, when I turn the dial for the oven, no gas comes out and obviously the oven doesn't heat up.
Looked up your model. You have silicone carbide ignition. If you see the ignitor glowing but the gas will not ignite chances are the ignitor is weak, I must pull 3.5 amps or better to get the safety bi-metal inside the valve to open. This is your oven safety feature.
Video:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 09, 2011 | Estate TGG220TQ Kitchen Range
THE PROBLEM OCCUR AFTER A POWER OUTAGE .I TRY LOOKING AT IT BUT IT DID"ENT COME ON THE OVEN WOULD NOT HEAT UP
Try to open the back cover of the oven and check for the fuse which is located in the power supply section. If there is no power, it is caused by a busted fuse.
Nov 29, 2010 | Maytag MGR4452ADW / MGR4452ADQ /...
I'm looking at a KitchenAide KDDT207B duel-fuel used stove to purchase used from a private party I don't know. Are there reliability concerns?
I have this same oven. It began to intermittently fail when using the oven. The error code suggested it was a problem with the keypad. I suspected it was because the electronics was overheating. The electronics for this model is approximately underneath the right front gas top range. What I found was that the failure occured when both the oven and the right front gas range were being used simultaneously. This caused overheating since the electronics has not fan in this model and the heat radiating down from the pan above the gas range is added to the heat coming from the oven below. The electronics is sandwiched between these two heat sources.
Nov 16, 2009 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Oven works sporadically
IF YOU CAN SMELL GAS, TURN THE STOVE TAP OFF. Get it checked out immediatly.
Aug 03, 2009 | Whirlpool GS460 Gas Kitchen Range
How do I remove the bottom plate of the oven
There are two screws in the back...remove them
Jul 14, 2009 | Estate TGP305TQ Gas Kitchen Range
Estate Range #TE5400PXHQ0
MY SELFCLEANING WHIRLPOOL OVEN CLEANED ABOUT 30 MINUTES AND THEN STOPPED AND WENT INTO E2 AND F1. THE DOOR IS LOCKED AND WON'T OPEN. WE HAVE TRIED EVERY THING THE BOOK SAID AND NOTHING HELPS. DO YOU HAVE AN ANSWER?
Dec 20, 2007 | Whirlpool RF368LXKS Electric Kitchen Range
Estate TGP305TQ Gas Kitchen Range Logo
159 people viewed this question
Top Estate Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you an Estate Kitchen Range Expert? Answer questions, earn points and help others
