Question about Linksys Wireless-G WRT54G Router
My modem's ping is normal but when i connect it to the linksys router, i get higher ping..
    Problem Solver:
  • 15 Answers
Technically, when a data packet has to travel through another device, it does actually take a bit longer to get through end to end. this is really pretty normal, unless there is an extreme difference in times.
hope that helps :)
Posted on Apr 01, 2011
Wrt160n shows offline
I would start by contacting your internet provider and having them ping your modem. If there is a connectivity problem, they should be able to help. You may also want to try resetting your router; and start again from a clean slate. Your picture shows that the modem is not connected to the internet, and your router is not connected to you modem.
Mar 02, 2014 | Linksys WRT160N Wireless Router
Can't ping or access modem through dir-600l
Your cable modem is a normal home use cable modem. You do not need to configure your modem. Your ISP will send the information needed to the modem once it has been registered to their systems. With most cable ISP you should be able to connect the modem to the cable and gain access to the modem registration. NOTE: You must sign up for service first.
If you wish to access your modem page then you will have to change the WAN IP address to something like 192.168.100.25. Do not use 192.168.100.1 nor 192.168.100.255. Once done you will then be able to access your modem's web page.
Ref: http://www.motorola.com/on/demandware.static/Sites-Site/Sites-Motorola_US-Library/default/v1337719566432/Products/SURFboard%20eXtreme%20SB6121%20DOCSIS%203.0%20Cabl/577212-001-a.pdf
Dec 21, 2012 | D-Link Computers & Internet
I have used the Linksys CD to setup my wireless connection to e1000 wireless router; in diagnostics, I discover that I am connected to the router but not to the internet. I also try setting up ethernet to...
Make sure the Modem is plugged into the correct port on the E1000 (far left port labelled 'internet' on a yellow background). Unplug all the devices power cables and restart them in order from the wall (modem - router - PC/MAC) make sure the modem has link and activity lights flashing, if there is a light for 'internet' wait for it to be on before plugging in the router. You might want to call your ISP and confirm theres nothing funky with the line/modem.
Aug 22, 2011 | Linksys E1000 IEEE 80211bgn Wireless...
Cable provider had to change modem, and now my wireless router isn't reconize how to fis
In checking if you're computer is properly connected to the Linksys Router, you will need to perform four steps:
i. Checking the Physical Connection to the Router
ii. Checking the LEDs
iii. Checking the IP Address of the PC
iv. Pinging the Router
NOTE: To check the computer's connection to the router using Mac, click here. If you are using Windows Vista, click here. For Windows 7 users, learn more here. For Windows 7 users, learn more here.
Make sure that the computer is connected to one of the four Ethernet ports of the router and the modem should be connected to the Internet port. For more instructions, click here.
Checking the LEDs
The Linksys router's LED lights will indicate the status of the connection. After connecting the broadband modem and the computer to the router, make sure that the LED lights are lit up. For more instructions, click here.
The IP address of the computer is another indication that the computer is properly connected to the router. For instructions, click here.
Thumbs back!
Nov 05, 2010 | Linksys Wireless-G WRT54G Router
Wireless router was working now its not, now light showing wireless on the router, I have internet if i plug in derectly to the modem
Jus Powercycle the Whole N/w
Unplug Modem and Router
Plug Modem First and then Router
Check Wired Internet to Router if that Works, wireless will be Online
Oct 01, 2010 | Linksys Wireless-N WRT150N Router
Trying to reconfigure the router and a message comes up "unable to connect to router" I've done all the steps even reset to factory settings.
If you've tried reseting it, then the IP address is probably one of the following:
192.168.1.1
192.168.0.1
If you know how, try to ping the router via command prompt. You can do this by going to:
Start Menu>Run
then type
cmd
A black window will appear, try typing:
ping [one of the IP addresses above]
if nothing "replies" then you have a bad connection. If one of them does reply.
Try typing that IP address into the browser address bar to bring up the routers web interface.
If it's a linksys, try this for the username and password
Username: admin
Password: admin
for Netgear:
Username: admin
Password: password
Apr 03, 2010 | Linksys Wireless-G Broadband Router
Router doesnt connect to internet
This sounds like a problem with your DSL modem, not the router. Try unplugging both devices and wait about 10 seconds. Plug in the modem first and wait about 30 seconds (at this point the Internet light should be on). Now plug in the router and wait another 30 seconds. This problem is normally due to the modem not getting sync. I would try plugging your laptop directly into modem if this doesn't work to see if you then have Internet. If not call your ISP.
Feb 14, 2009 | Linksys Wireless-G WRT54G Router
Connection
Hi Susie
With related to your particular issue it seems like that your broadband modem is not configured for the router. There are basically 2 types of connection. DSL and Cable modem. Verizon, ATT are DSL and comcast other providers give you a normal cable broadband connection. If its comcast make sure the cable from the comcast modem is going to the internet port in the linksys router and also make sure that there is a system connection the linksys router and the cable from the system goes to any of LAN 1, 2, 3 and 4 ports. Then reset your cable modem by using a pin and inserting to the reset hole in the modem. You could use the same step to reset your linksys router as well .If its a verizon or dsl connection you need to put normally your username and password in the router page. here is the link to how to configure linksys for your internet modem.
Here is a video as well on it?
http://in.youtube.com/watch?v=vSAXMO7aNzg
http://tinyurl.com/5tqqhl
Also post the linksys router model. your ISP modem model number and also information on how many systems are wired to the router and wireless and let me know if you need more help.
Thank you
Rakesh
Dell Laptop Expert
Jan 09, 2009 | Linksys Wireless-G Broadband Router
Configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses 192.168.0.1, 192.168.1.1, however sometimes the wifi is setup 10.1.1.1, or 10.0.0.1 etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look. http://portforward.com/routers.htm http://portforward.com/guides.htm
Aug 05, 2007 | Linksys WRT300N Wireless Router
Linksys Wireless-G WRT54G Router Logo
29 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
