Question about LG 52SX4D 52" HDTV
Lg 52sx4d turned tv on-picture but no sound. shut tv off, unplugged for a few minutes, plugged back in and turned on-nothing. white lights scrolled bottom to top for a minute then top light went red and second light blinked red a few times. replaced bulb, nothing changed. no fan sound or clicking noises, just the light sequence.
    Top Expert:
  • LG Master
  • 74,198 Answers
Hello
Power supply switching regulator board inside your LG TV is faulty. There are more than 8 regulated supply rails emerges from that board, after switching regulation, which will enter to different sections of circuits in your Tv. one or tw of its output voltages are missing now, in which, voltage to sound card also will includes. In most cases, this section is replaced as card basis, rather than making "surgery" to it. Clicking noice you hear along with this is a clear indication that there is something short on that board. It will be difficult, even a trained technician to locate and rectify the fault on that board, because, most of the components on it is machine soldered, and cannot be desoldered or resoldered by normal soldereing techeniques. Moreover, some of the components in it are not easly available on open electronic spare part shops, as LG has some special transformeres of their own, which they won't deliver to the open market. So in my opinion, it is best to replace the card itslef with same type and number, Type and number will be printed on the card and can be noted. You must have testing equpments like, a good quality digital multimeter, soldering Iron, desoldering pump and the most is sound knoledge in digital electronics and enough patience. After replacement of the power board, there will have to do some adjustements, [service adjustments] to get the picture well defined.
If you have confidence and informe me by Fixya. I'll assist you. OK.
Posted on Apr 01, 2011
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
My tv shuts down after 10-15min being on red light starts blinking about 10 time then shuts off then later it will come back on within few min to hrs sound and picture ok but just keeps shutting down will...
I have the same problem with mine. I can recreate the problem by stopping the small fan on the right side by the inputs. I'm not sure if its a heat problem or not. I already bought a new Sony Bravia but will continue to tinker with this for awhile.
Jul 03, 2010 | LG 52SX4D 52" HDTV
LG 52SX4D turns off randomly.
My Lg 52"tv turn off and on
Apr 29, 2009 | Televison & Video
Tv Turns on then stops after a few minutes
This set uses a lamp and a bad lamp will cause this symptom. You should be able to get the lamp out yourself and get a part # off it.
Mar 30, 2009 | LG 52SX4D 52" HDTV
Power problems problem on
I would try a power drain:  Unplug the TV's power cable so the TV is not grounded to the house.  Then press and hold in the TV's own power button for one minute to drain the capacitors. Plug the TV back in and see what happens.  If the TV will still not turn on, I would say you have a problem with the TV's mainboard as a dead power supply will not light any LED's for you.
Mar 24, 2009 | Toshiba CN36X81 TV
Won't turn on, just white light scroll then off.
I am having the same issue were you able to find a solution?
Jul 14, 2008 | LG 52SX4D 52" HDTV
Lg 52sx4d problem
If the red light scrolls through, you need to replace the bulb. I replaced the my own bulb, and when I tried to turn on the tv the light kept scrolling. What was wrong? I DIDNT FULLY REASSEMBLE THE TV AFTER REPLACING THE BULB.
Make sure that all the screws are put back in and it will probably work if you have replaced the bulb.
May 14, 2008 | LG 52SX4D 52" HDTV
My tv wont turn on
youre in trouble check the other posts
Aug 07, 2007 | LG 52SX4D 52" HDTV
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
No picture
set is gone it shut down,call local service dept.
Apr 12, 2007 | LG 52SX4D 52" HDTV
LG 52SX4D 52" HDTV Logo
73 people viewed this question
Computer Repairing
Computer Repairing
