Have a Simpson Eziset 550, model no 35S550M*00. After wash cycle, machine pumps out and spins. It keeps repeating the pump out and spin and does not go onto rinse cycle. Does this for all wash choices. Am willing and able to repair myself cheers Greer
  • jgmcneill Apr 02, 2011
    Hi Mike thanks for the response.
    Accessed control panel but there is no mechanical timer. Everything is on a circuit board.
    There are wires that vanish down into the cabinet, so got to thinking that there may be a sensor.
    Machine has not been run for 7 months and replaced the pump earlier this week, so may have disconnected a sensor.
    Will pull back off tomorrow.
    cheers
    Greer
  • jgmcneill Apr 03, 2011
    Hi Mike,
    did not find a disconnected sensor. BUT
    pulled the main cable connection off the circuit board, cleaned the connection pins with metho and plugged the connector back in.
    Problem solved - machine works perfectly.
    Thanks very much for your time and assistance
    Greer (doing happy washing machine dance)
  • 3,051 Answers
Hello there and than you for choosing fixya:
This is a fairly common issue with various makes and models of washing machines
the problem is that the cycle timer does go out on these units after some time this time is what alows it to advance from one cycle to a nother so what you are going to have to do is first ensure that the unit is draining out fully and if it is good then you will have to remove the timer and replace it if you have a appliance parts store in your town simply tell them the name and model number of the machine and the part that you need I wll post you some more information here shortly ook
Best regards Mike
Posted on Apr 01, 2011
  • Michael Thomas
    Michael Thomas Apr 01, 2011
    Disconect machine from power point then unsecrew the 2 screws on the side of the controle panel and gently lift the control panel up and the timer should be visable simply unhook the wiring to it and unscrew the screws then replace the timer
  • Michael Thomas
    Michael Thomas Apr 03, 2011
    Hey there and than you for the reply i will look forward to your results tomorrow and if you could could you get a picture of this and send it to me at tbirdfan1@yahoo.com mayby i can further investigate this for you if needed ok>
    Best regards Mike
My Eziset Simpson 550 won't spin
either the motor brushes are badly worn
or the pump cant clear out the water
i would say check the brushes they should be quite long if they are shorter than 3/4 inch then replace them
Mar 09, 2015 | Simpson Washing Machines
Why does my washing does a full cycle and pumps the water out but wont spin
http://laundry.manualsonline.
It seems that the carbons are worn
They are either side if the motor and kept by two springs
They cannot touch the core hence no spark
Put your machine on spinning mode while empty if it does it means the carbon are too weak to do so while when the washer is full of water
If the machine has not got carbons then it is the motor itself
Just check on the site and you will find details of your washer
Sep 15, 2014 | Washing Machines
My Simpson Eziset 550 will not drain after a (normal) wash cycle. When the drain hose is lowered to the floor drain water flows heavily from the hose (gravity). When the hose is returned to the sink d
Hi Erin just read your post,I have worked on these machines alot.Now I need you to manually drain the machine of all the water. Once drained i want you to select drain and spin cycle. Now push the start button,do you hear the pump working?If you do stop the machine and select normal cycle on small water level and push the start button.The machine will then fill.Once it stops filling stop the machine and select drain an spin cycle.Does the machine pump out? Now if you do not hear the pump, could be the pump is faulty or jammed.Does the water flow very fast when you lower it to the floor? Please reply with answers to these questions and I will try my best to help you.
Jan 25, 2014 | Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
I have a Simpson Eziset 550 - model no 36S550M*00. After the wash cycle machine pumps out and spins but is not advancing onto rinse. Instead it keeps repeating pump out and spin. Am prepared to dismantle...
Apr 01, 2011 | Washing Machines
I have a simpson EZIset 750 7.5kg washing machine, model # 22s750m When the machine fills up and start it cycle everything is fine until it comes time to do the first drain and spin, the lid lock light...
Hi There, I have the same machine with the same problem. I replaced the lid lock switch with the new upgrade kit, though you might need a tec to install it! approx $100.00
Jan 02, 2011 | Washing Machines
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
