Question about Garmin GPS
Lljudyj@aol.comI'm Looking for the On line registration page fpr my new GarminNuvi 1390 LMT. Can you direst me to it?
    President:
  • 1,514 Answers
  • Connect your satnav to your computer with the mini USB lead
  • Go to www.garmin.com and select your country from the drop-down list
  • Click on the myGarmin tab at the top of the screen
  • Click on "Register your garmin product" on the left of the screen
  • Click on "Automotive" and follow the prompts
You'll be asked to create a username and password. Keep them safe as you'll need them if you want to update your maps in the future.
Posted on Apr 01, 2011
What is the fuel pump pressure for a 1991 eagle summit
the question you ask is legit. unlike other answers seen here.
op , no engine stated
you do know that EFI systems vary by ENGINE, right?
and did you know that Isuzu sold the last car in usa with a carb in 1994? hark.
are you in USA?
log in to mitchell and read?
http://www.eautorepair.net/Marketing/Default.asp
the summit is a rebadged, Mitsubishi Mirage.
the 91 may have the 1.5L 12valve, engine.
ill now log in for you, to get a real answer, USA car.
you gave no symptoms, so cant really help. only
answer the PSI question.
the isuzu page has no data, so im looking it up in Mirage page
the correct answer is
48psi
but the FPR regulator sets that, and varies by
the FPR is located on the Fuel rail, in 1991
and is vacuum controls, if you read the FSM book or link above.
youd see how to test the pump and the FPR.
This EFI engine must have corrrect fuel pressure at idle
and wide open throttle. or EFI will inject wrong.
this is a basic, EFI MPI injected engine, no carb.
The ecu can not read fuel pressure (like 2016 can)
and will not correct for errors.
48psi is key on pressure, and when the engine starts
the pressure drops about 10psi. (vacuum caused)
there are many tests.
leakdown.
injector balance tests
FPR tests, I do 3 tests here, ask.
pump shunt test.
ask.
proof, note there are 5 engines in 1991, see?
Jun 29, 2014 | Isuzu Trooper Cars & Trucks
Tip
Garmin Nuvi 1390 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1390 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
___________________________
Garmin Nuvi 1390 Manual Download
Garmin Nuvi 1390 QuickStart Download
Garmin Nuvi 1390 Favorites Backup
Garmin Nuvi 1390 Hard Reset
on May 15, 2010 | GPS
Tip
Garmin Nuvi 1390 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
on May 15, 2010 | Garmin nuvi 1390T Car GPS Receiver
Nuvi 1390 lmt to Register how. Ralph Waqhl
connect the 1390 to the computer with a USB data cable and go to www.garmin.com and register the unit.
Sep 14, 2011 | Garmin nuvi 1300 Car GPS Receiver
WE WANT TO REGISTER A GARMIN 1390 LMT
Go to the Garmin website and register product. You will need your basic info as well as the serial number of the device.
May 03, 2011 | Garmin GPS
I HAVE GARMIN NUVI 1390 LMT I WANT TO KNOW HOW CAN I GET DIRECTION. SUPPOSE IT SHOWS ANY WAY AND IF I WANT TO CHANGE THE ROAD , WHAT I HAVE TO DO?
Press "WHERE TO" and select either "address", if you want to enter an address to go to or select "Favourites" if you want to go to somewhere you've stored there. If you want to choose an alternative route just start to drive the preferred route and it will change automatically to select the new direction.
If you want more information on how to use your satnav you can get an instruction manual from http://static.garmincdn.com/pumac/nuvi_1100_1200_1300_1400_OM.pdf
Mar 19, 2011 | Garmin nuvi 1490T GPS Receiver
My email will not stay online, it jumps to a page that says it can not be accessed. on the top line shows an address as : ads.bluelithium.com or ad.yieldmanager.com. this line is faint.
Thanks for visiting FixYa!
Yahoo has been experiencing a system wide problem. Many of Yahoo! Mail customers are experiencing the same problem as you are..
To assist Yahoo mail customers with this problem, AOL will transfer all of your contact information and future emails from your Yahoo account to your new AOL account for the next 30 days for free. (Until Yahoo can correct the problem). You won't miss any emails from your Yahoo account.. They will be automatically forwarded to your new AOL account.
Here are the instructions:
1) Go to AOL and set up a new AOL email account. (Click on this link) https://my.screenname.aol.com/_cqr/login/login.psp?seamless=novl&locale=us&offerId=newmail-en-us-v2&siteState=ver%3A4'rt%3ASTANDARD'at%3ASNS'ld%3Awebmail.aol.com'uv%3AAOL'lc%3Aen-us'mt%3AAOL'snt%3AScreenName'sid%3Af27fcb24-926a-4b22-ac39-ac0d19e1d3f4&authLev=0&sitedomain=sns.webmail.aol.com&lang=en
2) During the set up process you will be asked to provide a security question. Later, you'll need to answer the security question to set up the transfer, so don't forget the answer.
3) Once your new AOL account is set up, go to your AOL email page. Look in the upper right hand top corner for the word, SETTINGS and click on it.
4) (Next page) On the left hand side, look for the word, Accounts and click on it.
5) (Next Page) Look on the line beginning with, Transfer Accounts and locate the link that reads, AOL Easy Transfer and click on it.
6) (Next Page) Agree to the terms of service and click on, Get Started.
7) (Next Page) Under Copy from, enter your Yahoo email address and password.
8) Under Copy to, enter your new AOL email address and password.
9) (Next Page) Carefully Read, and select the options you need. (Click, Continue)
10) (Next Page) Click, Go to AOL Mail.
11) (Next Page) Enter the answer to your security question you created when you set up your new AOL email account. (Click, Continue)
12) (Next Page) Look at the top Left hand corner and click on, MAIL.
That's it. (Although AOL says that it may take up to 24 hours to complete the process - it usually only takes about 30 minutes.) After you receive your confirmation email, Click on your Contacts in your AOL account. When you see your Contacts from your Yahoo account there, the transfer has completed.
Feb 25, 2011 | Yahoo Mail
Registration
On-line Product Registration
On the product support page, click the 'Register Now' link.
On the main support page for your product, click on the 'Register Now' link. A new window will appear. If the 'Register Now' link is not listed, on-line registration for your product is no longer available.
Note: You may need to minimize this window to view the main support page.
Dec 30, 2007 | Canon PIXMA MP210 Photo All-In-One Printer
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
