Question about RCA RT2770 Theater System
RCA RT2770 fan is making a lot of noise. Started off quiet, but it's been getting louder and louder, now more so than the volume of the movies I watch. Should I clean it? Replace the fan? Junk the whole thing?
  • RCA Master
  • 6,694 Answers
Do one thing, Remove the fan from the player. In the fan there will be a specification sticker. Remove the sicker. Now you can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. You can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the player. power ON the player and watch. If available then try to replace the same. it will not cost a lot. just watch the following video for oiling the fan. its for a PC fan same for all dc fans.
ok
Posted on Apr 01, 2011
Testimonial: "By the time I'd gotten the answer, I'd already taken the fan off and thoroughly cleaned it. After re-attaching it I found my unit ran silently!"
I have a IOTA DLS 45 that is making strange sounds. The strange sound is variable and stops altogether at times. Is it the fan that would be making this noise? If not what else could it be?
About the only thing that could make noise is the cooling fan. Does it sound louder when you've just hooked up and started charging the batteries? When you've got a lot of things drawing 12v DC power? Only other noise might be arcing by a short circuit or crackling of a fire!! ;)
Mar 03, 2017 | RVs
The receiver makes a humming noise when power is on
Is it the fan making noise? Sometimes you can put a little oil on the bearings and alleviate this problem.
Mar 29, 2013 | RCA RT2770 Theater System
Laptop making loud fan noise like its overheating,
Go buy a can of compressed air and blow out the fans and vents. That should get it running quiet again.
Jun 08, 2012 | Acer Aspire 5336-2524 Intel Celeron 900...
Thought it was the western digital harddrive,bought a new harddrive and the problem is the same. The computer when running gets very loud. Now I am wondering if the problem is actually the power supply....
Your P.C. may need cleaning inside, Dust may of gathered in Fans, HeatSink, etc. When you connect things to your P.C. normally extra power is needed from help run the process. Hence why your P.C. gets more noisier and things get hotter needing the fans to cool them. Or your Power Supply Unit (PSU) replacing for more Watts.
Aug 22, 2010 | Dell XPS 200 PC Desktop
TV is making a loud ear piercing noise.
Ur high voltage is going through FBT,the big black block of plastic with a wire red or gray solder to the board.The Flyback transformer.There a steel "3 inches like a paper clip like steel.Put some supper glue on that "3 steel paper clip look like, will help or stop loud wishling noise all together.
Apr 21, 2010 | RCA HD52W59 HDTV Projection Television
Humming noise
If you are using a dimmer switch to operate the fan instead of a fan speed controller, that is the cause of the humming. If you turn down the speed to the lowest setting and the hum gets louder, then your controller needs to be replaced.
Sep 13, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Whistling on startup - Madza 121
Sounds like a fan belt problem if its burning that bad for that long it's likely to need to be replaced by now. Tightened the same day it started may have saved the belt
Aug 16, 2009 | Mazda 323 Cars & Trucks
My computer won't start up, I just have loud fan noise.
Hello!!
Might be the SMPS problem ,,, atleast can u see the blank screen or not at all powerig up ?
Jan 21, 2009 | Dell Dimension 9200 PC Desktop
RCA RT2770 receiver won't turn on!
Hold down the on/off button, un-plug it, and plug it back in. see if that fixes it.
Apr 02, 2008 | RCA RT2360 System
Home theater
This is RCA's on line PDF manual for the rt2770. http://support.rcaaudiovideo.com/manual.aspx?product=212 The rear panel has every known hookup plus fiber optics.
I have a Question? does your rt2770 volume numbers go all the way from 0 minimum to 50 maximum, mine only goes to 41 and it does not say maximum?
Nov 24, 2007 | Audio Players & Recorders
RCA RT2770 Theater System Logo
1,332 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
