Question about GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Where do I change out the water filter for a Galaxy 106.55132700 refrigerator?
How to change the water filter on a galaxy 25.4 cu. ft. side-by-side refridgerator
Check the "grill". Best Buy's ad spec sheet stated the filter was located in the grill. I believe there's an access panel on the bottom front of the grill below the doors.
Jul 28, 2014 | GALAXY Microsystems 25.4 cu. ft....
WATER DISPENSER ON GALAXY SIDE BY SIDE REFRIGERATOR DOESN'T WORK
Sounds like if your ice maker is still working, you're having an issue with your filter maybe freezing. Check to make sure your water filter isn't froze. What you're talking about with the overflow is a coincidence, but unless the internal wiring for the unit inside of the dispenser got damaged, i doubt thats the reason why. It's either a frozen filter or bad water valve. Try dethawing the filter or taking it out and seeing how much pressure there is built up in it. There's also a water reservoir in the back of this unit that may be froze too.
Nov 27, 2013 | GALAXY Microsystems 25.4 cu. ft....
My Galaxy side by side refridgerator is leaking from the water filter system. When I removed the water filter the leak stopped. Do I need to replace the filter cartridge or is it something else?
Start with the cartridge. If the cartridge was frozen then you'll more than likely have to change the housing as well. This is only if the filter is on the inside of the machine. If its located underneath then change the filter and just check the lines that go to it by removing the kickpkate and taking a glance
Jun 03, 2012 | GALAXY Microsystems 25.4 cu. ft....
Water is nasty!! Where is the filter located on the sde by side Galaxy refrigerator?
not familiar with the Galaxy refrigerator, but look inside the fridge side (not freezer) at the top. If not there, then take the grill off the bottom front of the refrigerator and look there. A lot of manufacturers started putting the filter down there.
Jan 01, 2010 | Refrigerators
How change the water hose on the door
unfortunately the water line is poured into the door to change that you will need a new door
Oct 07, 2009 | GALAXY Microsystems 25.4 cu. ft....
Galaxy 25.4 Color change needed
check out www.applianceart.com, they have black magnetic and vinyl covers that cover your fridge. They even have stainless steel options.
Apr 07, 2008 | GALAXY Microsystems 25.4 cu. ft....
Galaxy Side by Side Refrigerator water dispenser
Check the water valve in back of refrigerator and make sure it is working ok
Nov 14, 2007 | GALAXY Microsystems 25.4 cu. ft....
Water filter replacements
Hello Shawna, Yes, you are absolutely correct. The Galaxy and the Kenmore use the same filter. Best regards, nightdiver
Aug 23, 2006 | GALAXY Microsystems 55622
GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Logo
97 people viewed this question
Top GALAXY Microsystems Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a GALAXY Microsystems Refrigerator Expert? Answer questions, earn points and help others
