Question about Speed Queen AWS17NW Top Load Washer
SWT220WN I lost the key to the service door on my top load washer. Not key to collect coins but where motor is located. HELP!!!!!!
Coins fall directly into change opening on front instead of dropping into collection box
Your coin-mech is jammed and the coins are bypassing the collection box. use the service door key and visually inspect the coin mechanism for a blockage
Apr 22, 2016 | Washing Machines
Change the price on maytag top loading washer
Price change for a model MAT12.
Remove the access plate above the coin acceptor with a key. The display should show code 6 and two numbers. Code 6 is the regular cycle and the number of coins required to start. Press the perm press button to advance the number of coins. 06 equals 6 quarters, 08 equals 8 quarters, etc.
Reinstall the access door when finished.
Stephen
Feb 19, 2012 | Maytag MAT12CSD Top-Load Coin Operated...
My neptune displays the od error but the door will not open. HELP
Google this Neptune TL Washer FAV6800AWW
You will find FAV6800A or FAV8800A help. You have lost signaling thru the Left Hand Lid lock.
At rhe location above tou will find common Service Repair notes for issues with the machine.
If you are going to troubleshoot you need the Service Manual.
Mar 07, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have always had a smell coming from my duet washer. I put bleach in and run it through a rinse cycle, but it always comes back
there may be some dirt or other things collecting in the drain boot attatch to the drain pump there is usually a plastic coin trap located inside the rubber boot his will cause a musty smell in the washer.as well as a moldy door boot seal.if the door boot is moldy it needs to be replaced.
Jan 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Lost coin op washer keys
you need a locksmith.  Because of the key design
Mar 11, 2009 | Maytag MAT12CS Top Load Washer
I have a maytag coin operated washer and dryer. After the last service call the repair man ran off with the keys to the coin boxes. How do i get new keys to the coin boxes? Alternatively, how can i remove...
Unfortunately if you do not have a good locksmith, you will have to drill out the locks and replace them. Not a cheap solution by any means.....If I can help further, I am here.... Eric Campion
Feb 27, 2009 | Maytag MAT12CSD Top-Load Coin Operated...
Maytag coin-op top load wont spin, motor runs, belt burns.
it not a belt, there is a $20 plastic and rubber coupling between the motor and the transmission that has broken.  It needs replacing.
Dec 25, 2008 | Maytag MAT12CS Top Load Washer
Whirlpool coin operated washer and dryer
you need to take the coin slot out by using a socket wrench. then you need to flip the slot over and take the screws off. there is going to be two more screws to unscrew. take off that piece and also the claw like coin catcher. form here on out you should be able to remove as many slots as you need to.
Sep 06, 2007 | Washing Machines
Speed Queen AWS17NW Top Load Washer Logo
63 people viewed this question
Top Speed Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Washing Machine Expert? Answer questions, earn points and help others
