I have a Simpson Eziset 550 - model no 36S550M*00. After the wash cycle machine pumps out and spins but is not advancing onto rinse. Instead it keeps repeating pump out and spin. Am prepared to dismantle and fix myself cheers Greer
  • 3,051 Answers
Hello there and than you for choosing fixya:
This is a fairly common issue with various makes and models of washing machines
the problem is that the cycle timer does go out on these units after some time this time is what alows it to advance from one cycle to a nother so what you are going to have to do is first ensure that the unit is draining out fully and if it is good then you will have to remove the timer and replace it if you have a appliance parts store in your town simply tell them the name and model number of the machine and the part that you need
Posted on Apr 02, 2011
  • Michael Thomas
    Michael Thomas Apr 02, 2011
    Disconect machine from power point then unsecrew the 2 screws on the side of the controle panel and gently lift the control panel up and the timer should be visable simply unhook the wiring to it and unscrew the screws then replace the timer
    Reply
My Eziset Simpson 550 won't spin
either the motor brushes are badly worn
or the pump cant clear out the water
i would say check the brushes they should be quite long if they are shorter than 3/4 inch then replace them
Mar 09, 2015 | Simpson Washing Machines
Why does my washing does a full cycle and pumps the water out but wont spin
http://laundry.manualsonline.
It seems that the carbons are worn
They are either side if the motor and kept by two springs
They cannot touch the core hence no spark
Put your machine on spinning mode while empty if it does it means the carbon are too weak to do so while when the washer is full of water
If the machine has not got carbons then it is the motor itself
Just check on the site and you will find details of your washer
Sep 15, 2014 | Washing Machines
My Simpson Eziset 550 will not drain after a (normal) wash cycle. When the drain hose is lowered to the floor drain water flows heavily from the hose (gravity). When the hose is returned to the sink d
Hi Erin just read your post,I have worked on these machines alot.Now I need you to manually drain the machine of all the water. Once drained i want you to select drain and spin cycle. Now push the start button,do you hear the pump working?If you do stop the machine and select normal cycle on small water level and push the start button.The machine will then fill.Once it stops filling stop the machine and select drain an spin cycle.Does the machine pump out? Now if you do not hear the pump, could be the pump is faulty or jammed.Does the water flow very fast when you lower it to the floor? Please reply with answers to these questions and I will try my best to help you.
Jan 25, 2014 | Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
I have a 3 yr old Simpson Eziset 550 Washing machine top loader and it is getting stuck after the first wash cycle. It washes and drains but doesnt switch over to the rinse and spin cycle. Can anyone help...
Hi just read your posting.After the 1st wash cycle the machine drains the water,Is the machine continuous draining?Or does the machine stop the draining and sit there silently?Please reply with additional information and I am sure I can help you.I have worked on this machine alot so if you reply back we can rectify the problem.Looking forward to your reply.
May 14, 2011 | Washing Machines
Simpson esprit 550 washing machine stops mid-cycle
Could be timer fault although good chance its stopping as it gets to rinse indicating faulty Solonoid valve..Good luck
Mar 31, 2010 | Washing Machines
My simpson eziset 550 washing machine just stopped during a rinse cycle all the electrics are out, can i fix this myself?
Replace the fuse inside the control panel make sure you turn if off.
depending on where you are the fuse is more than likly a "4amp slow blow" fuse
hope this helps
Feb 24, 2010 | Washing Machines
Washing Machines Logo
173 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
