Question about Canon ZR800 Mini DV Digital Camcorder
The tape will not eject.
I open the bottom, the gears move, but the tape does not eject. Is there a way to manually get the tape out? My son might have put the tape in wrong...
  • Anonymous Dec 25, 2008
    mine is a canon zr 850 same problem... i would love to avoid repair costs if anybody can help
  • mjhodges2 Mar 21, 2009
    I have the same problem I kept opening the door to eject the tape and removing the battery while the eject was in proccess and finally the tape ejected. I have not put another tape into it yet because one of the gears that spins in the eject cycle is making a whirring noise like it is brushing against something as it spins. I can see the white plastic gear spinning at the center bottom of the carriage but I do not see what is causing the friction noise. At least I got my tape that had good footage on it, out of the camera. Can a $200 camera be fixed?
  • 10,594 Answers
I do agree with Simplemitch.
Posted on Aug 05, 2008
  • 752 Answers
It's EXTREMELY tricky and runs the risk of causing further damage. I strongly suggest finding a local service center to perform work of that nature.
Canon xl2 tape won't eject
This is a known problem.
Broken loading gear, Example: canon zr65 replace broken gear
Canon XL2 and ZR65 uses same tape drive system.
Feb 20, 2015 | Canon XL2 Mini DV Digital Camcorder
Stuck video tape
Is the tape protection guard rotated upward (and the tape engaged with the heads)?
Aug 13, 2008 | Emerson EWV403 VHS VCR
How to eject stuck tape
might have to remove bottom of vcr and manually move the drive motor by the belt or the pully. if the bottom doesn't come off, you'll have to remove the top. usually screws on the side bottoms and one in the back. you can reach the motor from there.
Feb 27, 2014 | Mitsubishi Televison & Video
Eject button won't work
What is the unit? There are often times in these new systems a belt or gear mechanism that moves the head base as well as other parts around. As units get older they need lubrication and the grease hardens to where they do not move as well. Belts also stretch and need to be replaced. When the head base mechanism is up or the mechanical alignment of the mechanism is NOT in stop mode or eject position the door is blocked from allowing it to open. The solution is to open the unit up and release the tape by a orderly means and then to work on it or have it worked on by someone who understands these units.
Dec 16, 2012 | Audio Players & Recorders
I've a Mitsubishi HS-U770 that has not been used for several years. When I tried to use it today, the tape loaded but would not play, rewind, or fast forward (I hear what sounds like gears slipping). The...
Mine did that, and when I opened it I found that a small drive belt (visible from the bottom with the cover removed) had deteriorated into goo. This unit had been in storage a while and the rubber just deteriorated, I guess. The trouble is that now I cant tell what size it is, or what length. I think this belt drives the mechanism that loads the tape in and out, and the rest of the mechanism is triggered by the tape cassette moving into position. Since it cant get loaded properly, the rest of the machine doesnt work right, either.
Jan 17, 2011 | Mitsubishi HS-U770 S-VHS VCR
VCR tape was hung in Sylvania SRDV495. Got the
You need the aligniament the eject gears to tape gears.Please remove the cover platen and the rear cover(bottom) and align the gears manually.Obturated the sensors hole and insert the cassette.Verify the eject and the tape belts.If you have knowlwdge VCRs the problems solved in 1 hour.
Aug 21, 2009 | Sylvania Televison & Video
Tape stuck in player - error code e13 shows
I just got a tape unstuck myself. Everytime I would hit eject it would make a clicking noise.
Here is what I did:
First I watched these videos to remove the radio.
http://www.youtube.com/watch?v=29MTa4FLjtk&feature=channel
http://www.youtube.com/watch?v=fqvk_PNo9Kg&feature=channel
Then I unscrewed the bottom panel of the radio.
Unscrew the brass screws holding in the cassette player portion of the radio.
Now flip the cassette player over to see your tape, etc.
When I pressed the eject button, I noticed a little motor with a worm gear would move a a gear which moved several other gears until it eventually moved a black gear which has a little post that moves the metal arm which moves back when pushing in a tape and moves forward when ejecting a tape. But I would get a clicking sound which seemed to be due to one gear trying to move a stuck gear.
I forgot the exact details of how I managed to get the tape out, but when I did get it out I noticed when I turned on the radio, it would act like it was trying to play a tape. But when it found out it couldn't, it would try to eject but would fail once again with the gear clicking sound.
I think I tried moving the black post on the black gear that moves the arm that pushes the tape out. Eventually I got to the point where the arm was pushed forward like it should be when a tape is ejected. At that point I was able to insert and eject a tape without any problems.
Mar 22, 2009 | 1998 Buick LeSabre
My panasonic pv gs32 camcorder is stuck and the tape won't pop up. I get a "press reset button" message and when I do this I hear it trying to lift up and out, but it doesn't move at all. Are...
try this:
  1. Open the tape door on the bottom.
  2. LEAVE IT OPEN.
  3. Power off your camcorder and remove the battery.
  4. With the battery removed, move the power switch to ON.
  5. LEAVING THE POWER ON AND THE TAPE DOOR OPEN, replace the battery.
  6. The tape should eject without damage.
Let me know.
Oct 11, 2008 | Cameras
VCR tape won't eject
you should take the bottom off and you will see a gear with a belt around it try to turn it the same direction as when it is turned off, do not force it but it may need a little force to move the wheel.
Mar 17, 2008 | Sony SLV-998HF VHS VCR
Canon ZR800 Mini DV Digital Camcorder Logo
289 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
