Question about Siemens Hands-free Audio Adaptor, 2.5mm jack: S46/ C25/ C35/ S25/ S35/ SL45 Headset
Jack audio adapter for siemens sl45 - Siemens Hands-free Audio Adaptor, 2.5mm jack: S46/ C25/ C35/ S25/ S35/ SL45 Headset
What are connections and connectors for audio output to wireless headset
Hi Richard,
First, you'll need to determine which type of input(s) the wireless headset transmitter has. Most common is the 3.5mm stereo plug designed to slip into the headphone jack of a TV, MP3 player, cell phone, etc. Some transmitters have adapters in the box to allow connecting to the Left and Right channel RCA / phono style jacks found on other components such as CD, DVD, VCR, Stereo receivers / amplifiers, etc.
You'll need to find OUTPUTS of the CD and TV that match the plug on the wireless headset transmitter. If yours doesn't include adapters to go from say the RCA jacks mentioned above - to whatever connector that the transmitter input has - you'll need to go to your local Radio Shack store or similar store to see if they can provide an adapter that will allow you to connect.
Here are a couple plugs / adapters:
Above: A "3.5mm stereo patch cable". Your transmitter may have a cable with an end like this to plug into the TV's headphone jack.
25683604-gy4zxbmnj5ndu14q12lmwneo-2-1.jpg Above: A "3.5mm female stereo jack to RCA stereo male plug" adapter that would allow the top cable to connect to the Left and Right audio output jacks on a typical CD, DVD, etc. device.
These cables / adapters are typically $5 to $10 maximum.
I hope this helps and good luck!
May 07, 2015 | RCA Televison & Video
How do you hook audio speakers to a portable dvd player
I am guessing that by this question you mean using computer speakers with a 3.5 mm jack with a portable dvd player which might have a 3.5 mm jack or you could get an adapter cable composite audio (red and white) to a audio jack.
Hope this helps
May 03, 2011 | Sony Audio Players & Recorders
Model ELCHW402 40" LCD
The TV has two audio out options: a digital audio out (coaxial) and a 3.5 mm headphone jack. Both of these are just above the antenna in connector. The headphone jack is the top one.
For a sound system that uses RCA stereo plugs, get a 3.5 mm (M) to 2 red/white RCA F adapter at the headphone jack and use an RCA audio cable from the adapter to the sound system. Alternatively, you can use a 3.5 mm audio patch cable from the headphone jack and the 3.5 mm (F) to 2 RCA (M) adapter at the sound system. The TV speakers will probably be turned off automatically with this connection.
If your sound system has digital audio, get the digital audio cable. You will need to enter the menus to make this audio output active. See the Audio menu > SPDIF Type (PCM, Dolby or Auto).
I hope this helps.
Dec 24, 2010 | Element Televison & Video
Where i can buy, power socket for my amilo pro v2010?
Just one example,
http://www.laptopjacks.com/view_part/For-Fujitsu-Amilo-Pro-V2010-DC-Power-Jack-FJ41420.html
The power socket in the laptop that the AC adapter (Charger) plugs into is a DC Power Jack.
Type Amilio Pro V2010 DC Power Jack in your browser search bar, press the Enter key.
To add:
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Nov 07, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Where service center i could bring my cell phone?
Please mention the place of your residencce and log on to clariffy to :
www.siemens.com/answers
Sep 25, 2010 | CCM Cellular Siemens S46/S45/C35i/SL45/A50...
How do I connect external speakers
    Connecting Full-Size Speakers
  1. Step 1 Insert the red and white plugs on a set of RCA audio cables into the right and left audio "OUT" jacks on the back of the TV.
  2. Step 2 Connect the other ends of the cables to a free pair of audio "IN" jacks on the amplifier.
  3. Step 3 Strip 1/2 inch of insulation from the speaker wires, and connect a pair of wires to the left and right terminals on the back of each speaker using the red wire for the right audio connection and the other wire for the left.
  4. Step 4 Connect the other ends of the speaker wires to a pair of stereo speaker terminals on the back of the amplifier. The wires attach by raising spring-loaded clips on the back of the amp to reveal a hole for inserting each wire.
  5. Step 5 Set the amplifier selector to the set of audio jacks connected to the TV to enjoy stereo sound from the television.
  6. Connecting Self-Powered Speakers
  7. Step 1 Insert the RCA plugs on the Y adapter into the TV's Audio "OUT" jacks.
  8. Step 2 Connect the mini-plug on the wire attached to the right-hand self-powered speaker to the mini-plug jack on the Y adapter.
  9. Step 3 Plug in the audio cable and mini-plug from the left-hand speaker into the Audio "OUT" jack on the back of the right-hand speaker.
  10. Step 4 Connect the AC adapter to the power jack on the back of the right-hand speaker, then plug the adapter into an electrical outlet.
  11. Step 5 Switch on the external speakers and adjust the volume.
Jun 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
I have a fuijitsu siemens Amilo D 7380 sreies. my laptop working properly but no sound coming. please help me.
start by opening control panel, sounds, then make sure volume is checked and up high, and the MUTE button is not checked. then make sure the sound is plugged into the headphone jack, not the microphone jack
Nov 27, 2009 | Fujitsu Computers & Internet
Audio output jack is small; need adapter.
You can buy an adaptor (Large to Small) at any good Electrical store.
Take the jacks with you so they are sure what you require.
The adaptors are not very expensive at all.
Best wishes.
Mar 03, 2009 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
Power supply
This sounds like a loose power connector on the system board. Users tend to wiggle the AC adapter out of the laptops, rather then pulling it straight out. It can be fixed, but the unit has to be dissasembled.
Sep 10, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
128meg MMC for Casio Em-500
Did you put your mp3 files in the my documents folder on the mmc? because if you place it anywhere else other than my documents the won't play (thanks microsoft). Also, the mp3 files might need conversion in order to actually play. It happend to me also, the files on the mmc would play on my siemens sl45 phone but on the em-500 not, until i use the sl45 connected to my computer to transfer files to the mmc than play with em-500.
Sep 05, 2005 | Casio Cassiopeia EM-500 Pocket PC
Radio Communications Logo
50 people viewed this question
Top Siemens Radio Communications Experts
Jon Piercy
Computer Links
Are you a Siemens Radio Communication Expert? Answer questions, earn points and help others
