Question about Danby DDW497W 22 in. Countertop Dishwasher
E4 error light comes on, dishwasher won't run, this apparently means water is on a sensor, have removed water from collection tray in bottom, tilted machine backward to dry out sensor, left for 24 hours, machine still won't run. Currently a very small new counter top but a useless dishwasher.
The problem is related to the floater assembly inside the dishwasher. It is filling up with gunk and stop working properly. I found out the hard way after a good spill. The solution is easy but takes a bit of time.
1. Unplug the power and water hoses.Unscrew the main cover ( both sides , pry off plastic caps first) back, and open door to remove the screws form the left and top attached to the main cover.
2. Remove the cover completely by lifting and slightly bending the bottom to unlatch.
3. On the right side, you can see the floater assembly. Remove the single screw on the lever and turn the lever 90 degrees to remove from the piston. Pry out the reservoir cover by pressing on the two latches(one is glued on, remove the glue).
4. You will see a very dirty mechanism which have to be cleaned up totally with sponges and paper towels. If possible ,you can try to insert a flexible wire inside the rubber hose at the bottom to ensure nothing is blocking it.
5. Replace the reservoir cover with its piston and re-install the lever.
6. At this stage, before installing the big cover, you can connect the hoses and power cord and try with setting P5 to start a small run. You should see the lever rising during water filling, when the spinner start turning, water filling stops for a moment then starts again for a brief period. This is a good check of the health of the float assembly when you run your washer. There should be a brief period of stop and start of water fill like you had when your machine was brand new.
7. Re-install the cover. ( the darker colored screws go in the front (behind door). Put back plastic caps . Reconnect power and water hoses.
8. Repeat from time to time when you don't hear the start and stop water fill.
Posted on Oct 17, 2012
I got the same error and took all the water out of the heating element collecting tray, cleaned all food particles and mildew (yuck) from the sensor and all the cavities in the tray. The machine is back up and running.
When the E4 error came on, the machine got overfilled and spilled water all over the counter. Had to bail all the water out manually and then clean.
These machines definitely require some hands on maintenance and repair once in a while. It's my second one and having to reseal the look through window with aquarium glue after a few months is a routine.
Posted on May 15, 2011
I have to replace the Thermistor / Turbidity Module on my Electrolux EIDW6305 dishwasher. (Error Code 2). I have ordered the part. Would appreciate any guidance you have on the procedure and a diagram of...
Hi Art.
Here the removal procedure from service manual:
The turbidity sensor-thermistor is located in the front portion of the water collection section of the
sump. This sensor is used by the control to determine the turbidity of the water, then adjust the cycle length as needed, and also to determine water temperature in the dishwasher. An o-ring
seals the sensor from leaking water into the base tray. The thermistor is wired to the electronic control and can be checked at the control for resistance. The thermistor is checked by reading its resistance at room temperature; this will be 10K ohms, if it is checked after a fill, the reading will very depending on water temperature.
To remove the turbidity sensor/ thermistor:
1. Pull unit from its installation position. Lay unit on its back.
2. Remove the base tray.
3. Push back the retaining clip and pull electrical connection from turbidity sensor/ thermistor.(See Figure 5-36)
4. Using a 20 Torx bit, extract the two screws securing the turbidity sensor/ thermistor to th bottom of the sump. Pull sensor from unit.
To remove the base tray:
1 . Tilt unit back to access the screws along the edge of the unit base. If blocking materials are not available, the unit may be set on its back.
2. Using a phillips head screwdriver, extract the two screws securing the base tray to the unit frame.
3. Tilt the front of the base tray away from the unit then push backwards to release the tabs from the locating slots in the rear of the unit.
4.Remove base tray for unit.
Here the picture of the Thermistor/Turbidity Module:
Regards.
Ginko
Nov 21, 2011 | Dishwashers
E4 is displayed on my belling idw604 dishwasher and it won't operate
unplug machine. remove right hand side panel. check if water has collected in the bottom tray, if so soak up with cloth or kitchen roll until all water has been removed. switch on power and machine should have reser
Feb 07, 2011 | Belling Dishwashers
Error code E4 is on our display of our KDW243A dishwasher - what does this mean please?
Error code E4 means there is an overflow. Water is probably trapped. If you get error code E4, just tilt the machine back about 45 degrees and let the water drain out. It should come out on both sides. Then, you should be good to go.
Dec 14, 2010 | Kenwood Dishwashers
What does the F2 Error mean? I got that error thsi morning. The engine was buzzing so I turned the power off. I have cleared what appears to be calcium and/or soap build-up in the 3 filters and in the...
The F2 error means the tray underneath the unit has filled with water. You will need to pull out the dishwasher (remove 2 screws at top left/right when door open that prevent tilting). Unplug and pull out dishwasher. Remove 4 screws on bottom rear panel and you will see tray underneath. Sponge out water and F2 error will reset.
However, you should not get water in this tray. There may be a faulty valve, pump or leaking pipe. Run diagnostic mode (described in user manual) to see if leak occurs during filling, draining or circulating.
Sep 19, 2010 | Asko D1876 Dishwasher
I have a Candy dishwasher. Door is open switch on sounds like something (possibly pump) is running and error E4 shown on diaplay. Any ideas please?
Overflow tray (bottom dishwasher). Tilt your dishwasher, pour water and see the reason for the overflow. I blew off the top hose from the pump.
Jul 20, 2010 | Candy 17 in. CS455 Built-in Dishwasher
Idw604 error code e4
had same problem. Tilt dishwasher to the left and drain all the water (it will come out on the side). That's E4 solved. Now turn it on, E4 should not light up. If it does, turn it on and as soon as u do this, close the door. This won't activate the Trip Switch but will automatically turn the pump on. Good luck!
Aug 02, 2009 | Belling 24 in. IDW603 Built-in Dishwasher
Getting an E4 error message on portable dishwasher - Kenmore 18" ,mg DDW1805W.
E4 means the overflow sensor has activated.
Under the washer is a pan - with a sensor. If it gets any sort of water - it activates.
You can remedy this issue by pulling ut the dishwasher, and tilting it up to about a 45 degree angle to empty the catch pan.
This should solve your problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 14, 2009 | Kenmore 17459 Free-standing Dishwasher
Error code e4
This might be a re-badged generic dishwasher - on my Baumatic E4 error caused by floatswitch in bottom catch tray. Some (supposedly small amount) water collects here and should evaporate naturally. If it accumulates, float rises and stops machine.
TURN OFF THE POWER
try to find a way into the machine base catch-tray to sponge it out - on the Baumatic there are two large black plastic plugs on the front of the machine base that can be forcibly flipped out.
failing that, take machine out and tip it up to get rid of water
Oct 09, 2008 | Maytag Dishwashers
Error mesage E4
E4 commonly means an overflow detected in the bottom over flow tray - try removing the kick board from the front of the machine - you should see 2 plastic black panels about 4 inches wide each, using a flat edged screwdriver pop the panels off and you will see the mechanics of the machine - the base is classed as the over flow tray - when water fills this tray a polystyrene float is pushed up and an E4 error code is detected - tilt the dishwasher back and allow the machine to dry out before trying it again - this should work unless the water seal around the filter basket is broken - in this case an engineer should be called to replace this part. Hope this Helps.
Thanks
Donna
Nov 06, 2007 | Baumatic 23 in. BDW13 Built-in Dishwasher
Danby DDW497W 22 in. Countertop Dishwasher Logo
826 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
