Question about Eclipse EA3532 Car Audio Amplifier
I have an eclipse ea3235 that was given to me by my cousin anyways i know this amp hits and it works. i just do not know how to wire or how to place the rca there is something im not doing right.
  • 76 Answers
The rca connections should run from the back of your stereo to the amp, the remote wire should be a blue one in your radio wiring harness. now for battery power, its best to run a seperate wire from the positive post on your battery. the ground wire should be ran as close to the amp as possible. hope this helps, if not let me know what i left out.
Posted on Apr 01, 2011
Why my stereo wont work all of the sudden?
Hi David
It would be rather difficult to diadnose the problem while in the dash with various unknown wires connected at the back.
I think your best bet is to take the Stereo out of the dash & bench test it.
Or get the service people or car radio installation guy to test it as it might be shot & need replacing anyway.
Cheers
Dec 28, 2015 | 2006 Mitsubishi Eclipse
I have 2 sony xplod 4ohm subs rated 350w rms and 1200w max, i have them in really shallow boxes because i drive a single cab toyota, i know these subs **** but i do also know that they can hit alot harder...
the premier amp is better since it has a better rms rating (360w total or 160w each sub) than the eclipse (280w if you bridge all 4 channels which isn't possible but 140w for each speaker bridging 2 channels per speaker). Neither are going to push your subs but if you get another amp wiring kit and use one amp per sub they will sound a lot better and you could just hook both power wire and ground wires from the bridged channels to the power and ground terminals for the sub. That would be my suggestion since the subs are rated at 350w and each amp is 280w and 320w which will push but not blow the subs.
Aug 17, 2010 | Sony Car Audio & Video
03 Mitsubishi eclipse holding back power
Youre gonna love this. when you open the hood you will see the rectangular air intake right in the front middle. there is a little plastic screw the holds the plastic air intake in place. if it is missing , once you hit about 30mph the plastic air intake will lift up and hit the underside of the hood. blocking air intake will kill all power to the engine.
2 dollar fix at dealer. let me know if thats it!
Jul 24, 2010 | 2003 Mitsubishi Eclipse Coupe
Vibrates when brakes are applied
Oil around the studs and hub with wd40 and let it soak. Then smack the living hell out of it. If you break the rotor it was warped anyway and they aren't that expensive. The best place to smack is between the studs, but be careful not to hit them.
May 19, 2009 | 2000 Mitsubishi Eclipse
Need to know how to install new radio in a 2001 mitsubishi eclipse
call 1888mitsu2001 and hit option #4, then hit * (star), give them the last 8 digits of your vin and they will provide the code for FREE.
DO NOT PAY FOR THE CODE ONLINE OR GO TO A DEALER (they will also charge).
May 09, 2009 | 2001 Mitsubishi Eclipse
Power problems with eclipse avn 5500 to amp
the avn 500 does not have a sub output. they have to create one at the shop-
Mar 24, 2009 | Eclipse AVN5500 Car DVD Player
Hi... my cousin gave me a dvd for my truck and i'm having a hard time.
I had the same problem the wire colors should be labeld on the unit, what i did was i took the black *ground* and connected it to the negative terminal of my car battery, and I took the red *B+ aka power* and the yellow *its labeled battery backup* and i connected it to the positive terminal and the screen came on.
Aug 06, 2008 | Eclipse AVN5500 Car DVD Player
Need help in installing amp.
depending on the power consumption of the amp u will need to run a 4-12 ga wire to the positive battery terminal. then u need to ground it with a wire connected to a clean ground like a chassis bolt. next u need preamp outputs on ur deck to send audio signals to the amp. lastly u need to hook up a remote wire to the blue wire in ur cd player harness
Jun 20, 2008 | Eclipse EA3422 Car Audio Amplifier
Eclipse Avn5500
if you know your cousins name and where he got it you can call 800-233-2216 and unlock it by phone
Jun 16, 2008 | Eclipse AVN5500 Car DVD Player
Transfering mp3
I tell you what I would do anyway download his music to your computer, reformat or as you call it delete it and then place the music the way you would like to hear it. I also see that you have an MP3 that takes SD cards which is better for you because you can collect these cards and place music or audio books on them and have a ton of programs. As for myself I have about 20 2 GB SD cards with books and music you would be surprised how much you can put on one of the little cards
Dec 06, 2007 | GPX MW3836 MP3 Player
Eclipse EA3532 Car Audio Amplifier Logo
146 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
