OKI C3400n conflicts with windows XP. The error message says "Function address 0X68641f00 caused a protection fault (exception code 0XC00000094) Some or all property page(s)not displayed.
  • 6 more comments
  • Anonymous Sep 15, 2008
    Function address 0x68641f00 caused a protection fault. (exception code 0xc0000094) Some or all property page(s) may not be displayed.
  • Anonymous Sep 23, 2008
    same
  • Stabilo78 Sep 25, 2008
    I have the same Error/problem except my printer is an OKI C3300.
    Does anyone have any info they could shed on this issue?
    The printer won't print out anything, and when i try to open up the printer properties this error comes up, and won't let me into the printer driver properties..
    Interestingly the address in the titlebar of the error says: C:\WINDOWS\Explorer.exe (does this suggest a problem with the way windows is interfacing with the driver?)
    Thanks to anyone for any help!
  • Anonymous Oct 01, 2008
    Same Explorer.exe Protection Fault and codes.
  • Anonymous Jan 14, 2009
    Help! I have the same problem
  • amyneal Jan 14, 2009
    same.
    same
  • Anonymous May 20, 2009
    same
  • 7 Answers
SOURCE: general protection fault
based on limited description of the issue possible causes - 1. memory corruption 2. corruption of bios 3. boot sector on hard disk failed or crashed
Posted on Oct 04, 2007
  • 833 Answers
SOURCE: printer problem
Remove your printer from the available printers by deleting it. Shut down. Restart and reinstall it. Make sure your cables are connected at the time the manufacturer tells you to.
Posted on Dec 21, 2007
  • 4 Answers
SOURCE: I seem to have a
The Roxio shipped with Dell system has bugs in them since they are shipped hence cannot be repaired. you need to uninstall Roxio and install IE7.
For problems with Roxio Refer the link
http://forums.support.roxio.com/lofiversion/index.php/t13587.html
Posted on Jun 04, 2008
  • 111 Answers
SOURCE: Cannot access Properties Tab
I don't know that this is something specific to Windows Vista. While researching your query, I've come up with conversations and multiple solutions, but usually involving networked printers and Windows 2000 servers and workstations.
It looks like the trigger for this problem can either be a recent Windows Update installation to your PC or installing new printer drivers. Have you installed either recently on your Vista computer?
I can give you the links to the potential solutions but both lead to rather lengthy discussions on internet forums, so be prepared to do I bit of reading. Unfortunately, I can't just pick out the one piece of information that represents the solution because different contributors offer different solutions, each which seems to work depending on circumstances. The best I can do is post the links and let you take it from there.
PCReview.co.uk
HP IT Resource Center
Wish I could do more to narrow down the solution for you. Like I said, the problems reported seem to be very similar but not absolutely the same. Hope this helps. Good luck.
Posted on Oct 06, 2008
  • 39 Answers
SOURCE: HP Laserjet 2015dn will not print
You didn't say what type of printer connection you have (Parallel Port, USB, etc) and this may not help any but I do know that HP Printers are VERY finicky about not pluging in your USB cable until told to do so.
Also, did you uninstall the printer software prior to doing the reinstallation? That can sometimes make a huge difference also.
Posted on Oct 29, 2008
Installing OKI c3400n in Windows 7 32 bit
The c3400n does not have its own wireless capability. It must be connected to a wireless print server or to some wired network that has a wireless access point (WAP) connected to it. A third option is to use a home-networking wireless router.
Individual PCs must have wireless capability also, or they can't print over wireless.
Somewhere along the line the printer must get a local network IP address, i.e. 192.168.0.102. PCs usually use Dynamic Host Configuration Protocol (DHCP) to get an IP address.
But printers are usually manually set to a 'static' IP, because static IPs don't change over time.
Usually there is a security device called a 'firewall' to protect the wired network from unwanted wireless traffic.
So, you first require some form of wireless access.
The people who require wireless printing capability must have their computers configured to make an association to the WAP. Usually requires a passkey or password, depending on the wireless security method.
A port on the firewall must be forwarded to the port used by whichever network-printing protocol is being used to communicate with the printer. There are several possible protocols.
The printer must be set to an IP address unique within the private subnet, i.e. 192.168.0.0/16, used by the local network.
PC-based network-connected devices use IP (Internet Protocol) addressing, i.e. xyz.zxy.yzx.xzy
The printer must be connected to a network switch that is in some way accessible to the WAP. Residential/SOHO (Small Office Home Office) setups use a combination switch/router device, called simply: a router.
Most of the above is done automatically, but there are some set-up tasks that require user intervention. Electronic devices know how to configure everything, after they are given proper parameters.
All you need to do is check the above items. If the printer is found by MS Windows 'searching for network printers', the hard part is done. Then you just tell Windows to use the network printer.
Jul 22, 2012 | OKI C3400n Laser Printer
Error running th game "Casino Inc." in Windows XP SP2
What Causes Windows Error 0xC0000005
A quick scan of the online technical forums and blogs reveal folks asking for help with this windows error. Your question may be the same as this typical request:
I'm running Windows XP and when I click to start one of my software programs I get this error:
"An application error has occurred and an application error log is being generated. Exception: access violation (0xC0000005), Address"
The error 0xC0000005 is generated by an ******* "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
Usually you get this error message when performing a specific task, and if that happens you need to check the corresponding 3rd party's website/support department to see if they are aware of the problem
..a while back Symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
So what can you do...? well below are a couple of suggestions:
0xC0000005 - Resolution Suggestion One:
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then I would remove them and see if the error goes away. If it does then send the memory back and get a refund!
0xC0000005 - Resolution Suggestion Two:
In Windows XP Service Pack 2 Microsoft introduced Data execution prevention (DEP), a set of hardware and software technologies that perform additional checks on memory to help protect against malicious code exploits. In Windows XP SP2, DEP is enforced by both hardware and software.
Some software/application behaviours are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation (such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with SafeSEH must have their exception handlers located in executable memory regions.
Applications that attempt to violate DEP will receive an exception with status code STATUS_ACCESS_VIOLATION (0xC0000005).
If an application requires executable memory, it must explicitly set this attribute on the appropriate memory by specifying PAGE_EXECUTE, PAGE_EXECUTE_READ, PAGE_EXECUTE_READWRITE or PAGE_EXECUTE_WRITECOPY in the memory protection argument of the Virtual* memory allocation functions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offence, contact the vendor for a resolution...
Note: It is possible to "Turn Off" DEP in the boot.ini file but this really would be a last step!
/NOEXECUTE
This option is only available on 32-bit versions of Windows when running on processors supporting no-execute protection. It enables no-execute protection (also known as Data Execution Protection - DEP), which results in the Memory Manager marking pages containing data as no-execute so that they cannot be executed as code. This can be useful for preventing malicious code from exploiting buffer overflow bugs with unexpected program input in order to execute arbitrary code. No-execute protection is always enabled on 64-bit versions of Windows on processors that support no-execute protection.
There are several options you can specify with this switch:
/NOEXECUTE=OPTIN Enables DEP for core system images and those specified in the DEP configuration dialog.
/NOEXECUTE=OPTOUT Enables DEP for all images except those specified in the DEP configuration dialog.
/NOEXECUTE=ALWAYSON Enables DEP on all images.
/NOEXECUTE=ALWAYSOFF Disables DEP. (This setting doesn't provide any DEP coverage for any part of the system, regardless of hardware DEP support. The processor doesn't run in Physical Address Extension (PAE) mode unless the /PAE option is present in the boot.ini file.)
Oct 30, 2017 | Konami Casino Inc. for Windows
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
I can't print Legal-Landscape documents anymore. I get two different error messages. "Punction address 0x77c47efe caused a protection fault, (exception code 0x0000005) Some or all property page(s) may...
Re-install the software for your printer. Download the drivers from the HP website and use the most current drivers for your product.
Also, check disk needs to be run on your unit to verify there are not other issues with your OS(Operating System).
Given the types of codes you have provided, it looks like you are running a Windows OS.
To run the check disk option, press and hold down the Windows Insignia key +S. This will bring up the Windows search option. Type "command prompt" and there should be a secondary window that shows you the results of your search. Look for the Command Prompt option and right-click the option and select "Run as Administrator" by highlighting the option and then left clicking your mouse.
A black window will come up with a variation of,"C:\Windows\System32\"; at this prompt you will see a blinking line\cursor. Type "chkdsk /r" then press enter. A report will come back stating that chkdsk cannot be run on "mounted" volume. Do you want chkdsk to run the next time the computer is restarted? Y\N
Press Y then enter.
Close the command prompt window and restart your PC. *WHEN IT RESTARTS, IT WILL TELL YOU TO SKIP CHECK DISK WITHIN X AMT OF SECONDS... DON'T TOUCH ANYTHING!!!*
Once it has completed, it will boot into Windows normally and if there are any issues, it will tell you during the scanning process.
Hope this helps.
If not, then bring up google.com and download and run this: Downloads AdwCleaner ToolsLib
This may also help.
Jul 13, 2017 | HP Officejet Pro L7780 All-In-One InkJet...
Printer won't install on new computer with windows 7
yes the cd that comes with your printer has only drivers for xp vista and most others except for windows7 you must go to the manufacturers website of your printer and obtain your drivers there!
Dec 22, 2009 | OKI C3400n Laser Printer
My oki does not like my new laptop
Chances are that the cd you are using is for windows 2000 or XP.  That cd will not work with vista.  But, you are in luck.  The Oki C3400N is compatible with Vista!  Go to this website and get the windows vista driver for it.  Install it and your printer should work.  Please rate!
http://my.okidata.com/dsdownWeb.nsf/(MOC-C3400n)/FD20231B3C802BE4852572DC005561C3?OpenDocument
Mar 03, 2009 | OKI C3400n Laser Printer
Toner Error
Check to make sure that the sensors are clean and play around with the lock arms. Reset the machine and also download the utility from the oki service website to get exact error message. http://www.okic3400.co.uk/library/downloads/utilities/c3300c3400smv1115.exe
Jan 27, 2009 | OKI C3400n Laser Printer
Printer problem
Dec 21, 2007 | Lexmark X4270 All-In-One InkJet Printer
Computers & Internet Logo
506 people viewed this question
David Payne
David Payne
