Question about Volfenhag Car Audio & Video
My amplifier is acting wierd everything turns on but there is no sound going to the subwoofer. and i know for a fact i had all the wires hooked up correctly and i believe that one of the side components has shorted out because its burnt and i can smell electic burning please help
SOURCE: My subwoofer will not go
I hook the postive specker wire from the amp. to the positive conection on the speaker with a jump wire on the other positive conection on the same speaker did the the same with neg.wire also.I'm hooking up a JBL 600watts touring amp with two ts-w307d4. Is this the correct way of hooking up this project.
Posted on Apr 08, 2008
  • 18 Answers
SOURCE: SUBWOOFER NOT WORKING?
if you have real old wires from the amp to the sub try getting new wires on it. check the little wires that go to the cone itself on the sub. sometimes they can manage to get pulled out of their terminals and make sure that thier touching the terminals on the correct spot
Posted on Oct 04, 2006
SOURCE: Fisher and Paykel Smart Drive burning mells
Try: http://usa.fisherpaykel.com/global/customer-care/trouble-shooting/washing-machines.cfm?CFID=5795181&CFTOKEN=46306735
Posted on Jan 15, 2007
ongolo
  • 11 Answers
SOURCE: MY AMPLIFIER
HI SOUFBOY , Theres a few things you need to check , First make sure that your amplifier is getting an audio signal form your head unit,Check all the wires for breaks in the amplifier input, secondly make sure that your 12 inch woofers are still connected to the amp check all the wires . Thirdly check your woofers are they blown ? . The best way of grounding your amp is by scrapping all the paint on a spot on the car body inside the trunk or wherever you have it and making sure the ground wire is securely screwed onto the car body on that spot ..
Posted on Mar 23, 2007
Cerfer39
  • 709 Answers
SOURCE: Subwoofer problems
What started smoking the Sub or the amp?
Posted on Oct 08, 2007
What do I connect the remote wire on my kenwood ksc-sw910
are you hooking up an aftermarket amplifier?the remote turn on wire is your blue with white trace.if you are not hooking up an aftermarket amplifier, you typically will not need it. what kind of car are you putting it into?some vehicles with a factory amplifier will require this wire to be connected to turn the amp on so you have sound. try not connecting it, and if you have sound, youre fine. if not, let me know what kind of car you have
Oct 31, 2012 | Car Audio & Video
I have sound when I play the radio but no sound when the dvd, cd, or ipod is playing. What could be the problem? Do I need to hook the mute wire up to?
are you running sound through an amplifier? if so, it sounds like you are using the blue wire (power antenna remote turn on) instead of the blue/white wire (amplifier remote turn on). the blue wire turns off when leaving tuner mode, so the power antenna will go down.
Mar 21, 2011 | Car Audio & Video
Insalling a JVC audio deck into a 2001 volkswagen jetta
Was there sound before? Was it the factory stereo or same aftermarket? You may have missed the factory amplifier turn on wire in the harness.
Mar 01, 2010 | JVC Car Audio & Video
No sound coming from subs
You definitely NEED a source signal for the amplifier to amplify!
You should have a Main Power Wire, a Ground Wire, A Remote Turn on Wire, and RCA cables (or hi level speaker wires if your amplifier has them)
and the speaker wires to the subwoofers.
Thanks for using FixYA - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 30, 2009 | Kenwood Car Audio & Video
I have a 2600 watt Power Acoustik Gothic Amplifier and two 12 inch MTX 7500 superwoofers. When I go to hook up both the subwoofers, it seems like the subs won't work as well, but when I only hook up one...
look at the speakers, is one jumping out and the other drawing in? If so try this. Hook one speaker up normally, reverse the polarity on th other. Hook it opposite how you hooked the other up. This won't hurt a thing but it may cure the problem. Sometimes the amps get wired up backwards inside. I know for a fact that fosgate does cause mine was.
May 12, 2009 | Car Audio & Video
Wiggle the positive wire to get power and have to unplug subs to turn car off
Ok it sounds to me that your remote wire is not hooked up right casue if you trun your car off then your amp should power down an when you trun your car on it should power up
May 07, 2009 | Car Audio & Video
Subwoofer acting wierd
If you turn the power off and restart, the most logical answer i know of is your amplifier is going bad.
I am not sure of the model and brand of your amplifier, but there should be a protection light on the amplifier somewhere that will most likely be on, caused by overloading the amplifier.
You will most likely have to replace the amplifier, or check with the manufacturer to find out if they can repair it or help to further diagnose the problem.
Dec 16, 2008 | Car Audio & Video
Subs not hitting
remote wire turning on amplifier?
Ground for amplifier?
Gain improperly set?
Radio output crossed over above tuning freq. of enclosure?
Just suggestions. Not much info to go by.
Dec 15, 2008 | Jensen BP212 Car Subwoofer
Thunder 5604
okay u will have to troubleshoo the amp.....dose the amp light up?...when u have the radio on? also check your sub wires.going to the amp....make sure the rca'sare hooked up to the radio rear out puts are the radio sub out puts...and then test your amp gain adjustment...let me know if that work's
Jun 23, 2008 | MTX Thunder5601 300W x 1 Car Amp Mono...
Amp is on, Subwoofer works, but no sound.
here is a short test you can try, remove the rca audio cable from the amp & connect a diskman or toher audio o/p device that you can hook up with the same rca wires, turn on the amp & see if you have sound. you can also remove the speaker wires from the sub & using multi meter read the ohm's of the sub, most subs are 4 ohm. Hope this help locate your problem
Oct 24, 2006 | Pioneer GM-7200M Car Audio Amplifier
Car Audio & Video Logo
15 people viewed this question
Top Volfenhag Car Audio & Video Experts
Robert Rankin
hoyzee1
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
