Question about True TSSU-48-12 Refrigerator Commercial
The True brand commercial refrigerator at my job is entirely too cold. How do I adjust the temp? Beer is exploding!
  • 132 Answers
You will need to adjust the thermostat.
The thermostat will be hidden at the bottom back of the fridge near the compressor.
You may need a screw a flat blade driver driver to adjust the themostat
Posted on Apr 01, 2011
What is correct temp setting fpr t-49 true refrigerator
35 to 37 F. Put a thermometer inside and give it time like 2-3 cycles between adjustments before you believe the temp is stable. Hope this helps and good luck.
Jun 20, 2014 | True T-49 Side by Side Refrigerator...
True T-49 refrigerator/freezer temperature calibration
Contact the manufacture, it is most likely going to be covered under warranty. If the knob is not removable, (check for a set screw on the side of the knob it will take a small allen wrench) Then the thermostat (temp controller) will need to be replaced, if it isn't a style that you can calibrate.
Jan 30, 2014 | True Refrigeration True T-49 2 Door Bottom...
I have a true upright commercial display refrigerator.I think the tempature control is faulty.It freezez everything,I use it for beer and wine.I have cleaned the condensor and still no luck.No matter what...
it is just a temp control, look real good at the control and see if you can see any holes in it that might have a small screw that can be turned. Maybe an in and out, you may be able to adjust it this way. let me know.
Mar 15, 2011 | True GDM-23 Refrigerator Commercial
True cooler frezzing kegs of beer
If I am not mistaken, the True line-up of coolers have a temp control on them that is labeled 0-9.
This particular type of temp control is a coil temp control. I measures the temperature of the coil rather than air temperature.
Always set the control to the warmest setting and move it colder by one number at a time until your product reaches and holds designed temp. Do not go by cooler air temperature as there will be a great swing in temp especially if the doors are used frequently. Always temp the product. In the case of beer, your ideal holding temp is between 35-38°.
If you set the temp control to the warmest setting and the cooler is still freezing product, you will need to have the cooler serviced be a refrigeration tech. It will most likely be a bad control but there may be underlying problems.
Jan 08, 2010 | True TBB-2 Beverage Cooler
True TDD1 freezes the beer?
yep can ya turn it off by the thermostat? its likely the thermostat can find one @ appliance parts give them model serial # or caseparts.com. good luck be careful. Tom
Jun 21, 2009 | True TDD-1 Commercial Beverage Dispenser
We have a GDM-26 commerical coke machine. Only
If any of your drinks are freezing you need to adjust your temp setting. The suggested setting is 5. changing the temp setting basically tells the refrigerator to stop cooling when the temp hits a low degree, and to start cooling when it hits a high degree. This keeps your drinks not to hot, not too cold, but just right. If this doesn't work I would change the cold control altogether, it might've went bad. If you have a few minutes, locate the condensor fan (bottom) and make sure it is periodically turning on and off like it should.
Jun 08, 2009 | True GDM-12 Refrigerator Commercial
Beer box tempature control not getting cold enough to temp. specs
check the vendilation condition/temprature out of the freezer
Nov 17, 2007 | True TD-95-38-LT Beverage Cooler
Cooler is freezing my Beer!!
Could be the thermostat isn't working and the unit is just running and running all the time. To me that seems the most simple explanation right now. Can you check the temp inside when on the lowest setting for a day, then turn it up to the highest for a day and see if there is a huge difference in temps? Does the compressor motor ever turn off or does it run continuously? Suspect that t-stat...
Nov 20, 2006 | True 3 Keg Direct Draw Beer Dispenser,...
True TSSU-48-12 Refrigerator Commercial Logo
371 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
