I want to print my document in excel in an A2 paper size
  • 300 Answers
"Problem with the Fax Machines
i want to print my document in excel in an A2 paper size "
That's nice! So, what's the obstacle?
Posted on Apr 01, 2011
I have a hp 1320 laseret printer.when I order to print. this printer prints two pages. I could not solve this problem. would you please help me?
What document you are trying to print?
If it is Excel or Word document you have created a second blank page, reopen the document and delete the second empty page.
Nov 17, 2014 | HP LaserJet 1320 Printer
How to shrink document to fit screen size when printing
Scaled Printing
The procedure for specifying a scaling value and printing a document with pages enlarged or reduced to match the document to the paper size is as follows:
1. Open the printer driver setup window, and select Scaled Printing from the Page Layout list on the Page Setup tab.
figure:Select Scaled Printing for Page Layout on the Page Setup tab
2. Using Page Size, select the page size that was set with your application.
3. Do either of the following to set a scaling factor:
Select a Printer Paper Size.
Select a printer paper size, which is different from the Page Size, from the Printer Paper Size list. If the printer paper size is smaller than the Page Size, the page image will be reduced. If the printer paper size is larger than the page size, the page image will be enlarged.6c3578e0-f243-44b0-aa8e-f7bb7752ed56.jpg
figure:Printer Paper Size on the Page Setup tab
Specify a scaling factor.
Directly type in a value into the Scaling box.
figure:Scaling on the Page Setup tab
The current settings are displayed in the Settings Preview on the left side of the printer driver.
4. Click OK.
When you execute print, the document will be printed with the specified scale.
Note
If the application software with which you created the original has the scaled printing function, configure the settings on your application software. You do not need to also configure the same setting in the printer driver. When Scaled Printing is selected, the Staple Side list box appears grayed out and is unavailable (when Duplex Printing is not selected). When Borderless Printing check box is checked for the Page Layout list, Scaled Printing cannot be selected.
Tip
Selecting Scaled Printing changes the printable area.
Hope this helps
Mark
Sep 13, 2014 | Canon PIXMA MX310 All-In-One Printer
WAS HAVING TROUBLE WITH HL 2040 PRINTER , LEARNT HOW TO RESET , FIXED THE PROBLEM. TRIED TO PRINT A WORD DOCUMENT , WOULD NOT PRINT - BUT WOULD PRINT EXCEL DOCUMENTS. WHILST TRYING TO GET STARTED AGAIN...
Hi Ron, I dont think you have a printer problem, i think you have a print driver/computer problem.
To find out unplug it (the usb) from you computer, turn it off so no data remains from previous print commands sent from your pc and run a self test by holding your green go button when you turn it on, keep it held untill toner, drum and paper lights light up, then let it go, then press the go button and the printer will print a self test....
If this works ok then we know your printer is ok. and your issue is as i suspect it is, with your print driver, paper size or tray select settings in Driver or in Word or in Excel or your document.
You can isolate if document problem by doing self test in print driver in control panel..
If self test on printer unpluged works and we have no error lights and are seeing the test ok and no flashing lights then you may want to ensure driver is good by completly unistaling the driver on your pc, do this by unistalling all brother stuff from control panel/programs and features (depends on operation system you are using).
Then with it still not connected, go to brothers web and download the full software and drivers package to suit your operating system, run it and only plug in the usb when instructed.
Let me know if your printer shows an error when not connected or if self test fails and Ill go down that road with you... if paper light on it when not connected, it tells us we have a jam, make sure you check back door and under toner drum and paper is sitting neat in tray
But when you tell me excel works and word doesnt, i dont think printer, it is software.Check your page size settings in word and excel and of your documents as the flashing paper light may be the printer trying to tell you the data sent to it from word is a paper size mis match to what the printer has in its tray and it wants you to feed the correct size paper in the manual feed/bypass slot. You should also check paper size and tray selection in your print driver in printers and faxs under control panel is the same as your document. Here is your manual
and here is where you can download your print driver (unistall old software and unpug usb first)
The more i ponder this, it is page size settings in document/excell/word and printer is asking you to feed paper in manual pass slot (above tray)
CHEERS RON
STEVE ;)
hi
Feb 22, 2012 | Brother HL-2040 Laser Printer
Error code 024-747 is given when trying to print a specific Word 2010 document although any other Word 2010 document seems to print without any problems. Can you tell me what this error message means and...
In my case was like when i tried to print MS Word or Excel document (Xerox WC 5020 & WC 7120) i had to set "Original document size" in Paper Type option as same as "Output document size" in Printing preferences - it should help.
Jul 22, 2011 | Xerox DocuPrint C4350 Laser Printer
I have a canon MF 8350 cdn and when i try to print certain documents such as pdfs or excel sheets the printer prints out a couple pages then gives the error "check paper size" even though it is...
Check paper size refers to the fact your documents are for say and A4 sheet of paper but your drivers properties are set to letter size. Go into the drivers printing preferences and set the paper size to the correct value. All should work fine now.
Jun 01, 2011 | Canon MF8350Cdn AllInOne Laser Printer
I cant print on A3 paper through microsoft excel on hp1280
in excel sheet please change the page size to A3 and try to print ..... if you are using office 2007 go to page layout then go to size icon there change the page size to A3 and check .......... if you are facing the same problem please post your comment ............. while you giving print please select the document which one you want to print ..........
Dec 31, 2009 | HP DeskJet 1280 InkJet Printer
Printer cant print excel files
Chjange the page size of the excel document, it at present is set to letter, ...file page set up in excel
Sep 23, 2008 | HP LaserJet 4 plus Printer
Printing Docs
This model does NOT support edge to edge printing.
You can have the document reduced to fit the sheet size in Excel.
Feb 19, 2008 | Konica Minolta bizhub C250 All-In-One...
810 people viewed this question
k24674
jasbo
jasbo
