Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
I have a 420 riding tractor and it has been out of service for 6 yrs. I just got it running again and am having a difficult time in working the steering and hydraulic lifting arms. The lifting arms to the mower will work after holding the lever back for a long while and moving the steering around. If it does lift it will do so laboriously, slow and noisy as well. The power steering is hard as well. I changed the oil and filter years ago and haven't run it since. I was reading up on trouble shooting and it appears that the fluid passes thru the steering then to the other functions. The tractor does move forward and reverse. It took awile of coaxing before it did though however. Feels like the oil is too heavy or not passing along like it should. Any advice would be welcome. Thanks, Sid
  • 3,740 Answers
Hi Sid I am Kelly and welcome to FixYa,
Let me just state what I would do in the shop to revive your been resting for 6 years tractor.
Knowing that corrosion has formed in part of system from condensation I would:
1. Purge the entire hydraulic system under pressure by maintaining a good fluid level in the reservoir and pump everything in the system out after loosening the return line substantially and catching the fluids. (You have to wrap the loose connection with a denim cloth several wraps to keep from spraying fluid everywhere.)
2. Purge and FLUSH the trans-axle. If you have an external filter replace that. If you have an internal filter you have to open it up and clean out the housing.
3. The control valves probably all need some TLC and cleaning.
Here is the problem... due to the long non-use period and the corrosion that has manifested in the system ball seat type valve will get micro debris in them and that does not allow hydraulic valves of any type to operate properly. The Hydrostatic drive has springs, balls and flappers in it that are subject to the exact same micro debris issues. What you really need to do is purge purge purge.
After you purge and use it for a month.... I would recommend yet another purge and filter(s) change.
It is tough to tell you exactly what to do because each hydraulic component is affected in some way so, the only way to really make sure they are functioning properly is to remove and clean them.
Here is what I do... I have a short piece of hose I use to listen to components under pressure like a steth-0-scope. If it is making noise.. when in a neutral configuration I remove it and clean it up. The only one you can NOT use this line of thinking with is the pump.
The Hydrostatic drive is usually the most problematic after a long period of use. Especially the reversing valve.
I am sure if you purge the system your going to shocked at the color of the fluid you drain out.
What ever you do.. do NOT use solvents or fuels under pressure to "purge" the system. Both can do more harm than good. If you have something apart; B-12 Chem-tool works really well as does carb cleaner. Both are quite flammable so keep that in mind.
I actually did this for a relative who inherited a unit that sat for 9 years. To get everything up 100 % took me about 2.5 hrs a day for 5 days and one hiccup after that. It works fine now but I will tell you if a customer came to me and asked what it would cost to do a "return to service" job after it sat for 5 years or more they would be stunned at the labor cost. If you have the time to do it right it really is worth the effort.
I recommend you check all bearings you have access too for roughness also. Everything could be fine for 3 or 4 days and then you start having bearing failures.
Thanks for choosing FixYa,
Kelly
Posted on Apr 01, 2011
Does the hour meter in a toro tractor lx 420 show Tenths?
Best way to check that out is to run it for six or seven minutes and see it the number changes by .1 and if it takes an hour of running to move the nkmber you will know that it reads hours nit tenths.
Sep 21, 2014 | Garden
I have a John Deere garden tractor 420 I was mowing the engine stopped I check the 25 amp fuse it was blown. I replaced it turned the key there is absolutely no power
Im gonna first assume that the 420 you have is the 1986 model and not the 68 model , second this model has hydraulic lift on mower , this model has a electric clutch on pto , I assume that you dissengauged the deck drive before trying to restart , but now if you forgot to do so before replacing fuse it would go again if it's what i think it is , so first disengauge deck second ck fuse again replace if nessacary , start engine attempt to engauge deck if engine dies or it does a short time later, ck your wiring to your pto clutch Look for what looks like a chewed up wire finding none replace pto clutch magnet (or entire clutch if lots of hours on it) also ck out my youtube video on finding electrical faults on lawn tractors this might help ya .
Jun 05, 2014 | Garden
Electrical problem on a john deere 420 lawn tractor
remove the upper engine cover and inspect for a build up of grass and or a mouse nest that would over heat the coil and the engine
Jun 19, 2012 | John Deere 420,1020,2010,2020,2510,2520...
B &S 16hp engine on a riding lawn mower. Engine model #303777 Type 0015-02. 420 hours on tach. Under load engine hestates and dies. Will restart immediately, run a few minutes and die again. Without...
check the fuel cap too,, it needs to be venting for better fuel flow, also,, when was the last time it got plugs,, it may be flooding out due to weak spark
Jul 07, 2011 | Garden
How do I shift my John Deere 420 garden tractor from high to low speed? I can't budge the shifter. Is there a trick to it?
With engine not running,pull lever towards rear of machine then move from one side to the other.If this does not work your linkage is locked up externally.
Jun 19, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Electric starter won't work on snowblower, replaced it once
If this is a briggs & Stratton engine no the starters are easy to get and replace usually just 2 bolts hold them in. Depending on how long ago you replaced the last one I would check out the system for problems before I installed a new one as starters usually last for yrs. Things that would ruin a starter are excessive heat or power staying on the starter after startup as this would cause excessive wear. Hope This Helps Don
Dec 08, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
JD 420 PTO works fine when cold/newly started. after warming up, if i turn off PTO, the PTO will not re-engage. is this a switch problem? other problem? if a switch problem, it looks like it's somewhat...
I used a neighbors 420 while mowing and there were times that I tried to restart the blades after turning them off for a bit. I found, I think, that you had to have the brake depressed to make them turn back on.
Oct 17, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Pto spis all the time on my 1989 john deere 420
Are the blades turning? If they are not, this is normal. The PTO is an electro magnetic clutch that engages when you apply electricity via the PTO switch. When it is disengaged, the bearings and top portion of the clutch will turn because it is coupled to the engine. If the blades ARE turning then you have a bad clutch and will need to repair or replace it
Sep 18, 2009 | Garden
Is the pto of a john deere 420 garden tractor run all the time
My 420 with an onan runs great at half throttle, then bogs down.
Are you sure you did not get the jets in the wrong places when you cleaned that carburetor.
Aug 23, 2009 | John Deere Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
56 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
