Question about GE WBSE3120B Top Load Washer
Fill light is blinking and no water is coming into tub. Model # G131
SOURCE: HOT WATER WON'T FILL TUB
hi there, you have an air locked warm water pipe, put a hose from the cold tap to the hot tap,turn on hot tap,then turn on cold tap, the force of the cold water will clear the air lock,turn off cold tap and remove hose. let hot tap run for a few min. [cheers]
Posted on Mar 30, 2009
  • 686 Answers
SOURCE: water still in tub water level light blinking
GO TO www.repairclinic.com AND LOOK FOR PART 541811 IT MAY BE CLOGGED AND NEEDS CLEANED OUT THIS IS A LINT CATCHER FOR WASHERS
Posted on Apr 17, 2009
localwonder
  • 6784 Answers
SOURCE: Washer not holding water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
Posted on Jul 11, 2009
  • 14 Answers
SOURCE: water runs but doesn't fill tub and wont spin if put on spin cycl
The drain hose must be higher than the tub of the washer so many times I get called to find the hose on the ground to the drain an this will not let the tub fill.
Posted on Jan 28, 2010
  • 343 Answers
SOURCE: The water will not fill tub. The hose connection
If the hose to the machine is clear then you probably have a faulty water valve. However you should make sure that the filter on the watervalve ian't blocked....Take the hose off at the back of the machine and check there as well...A water valve is not a big job, but should be done by a tech or a very competent handyman.....Nomess
Posted on Apr 18, 2010
My dishwasher(samsung DW7933LRABB) wont fill, it will drain if i put water in the tub. supply is on.
You either have a bad water valve, or a bad case-brake assembly (in which case you should have an error code or blinking light on your console).
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Mar 06, 2015 | Samsung Appliance DW7933LRABB 24" Tall Tub...
Where would the water come from if it is draining from the bottom of the washer when trying to fill tub
more than likely the pump is cracked and as it fills its leaking out. If I had the model number off the machine I could give you a better answer
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 05, 2012 | Washing Machines
Ice maker not producing any ice.
Pour about 1/2 cup of water into icemaker . Squeeze the black fill tub which is above the icemaker cup . If ice apears to be in it , this indicates that the weter valve is not completely closing , letting a drip ocasionally go thru and freezing inside the tube , ( water valve bad ) . that will be a different solution . If the icemaker dumps the cubes after freezing . and black tube is not frozen , replace the water inlet valve . If the icemaker does not dump the ice after frozen , replace the icemaker ( only 1 screw holds the icemaker in , located on rear portion on right , faceing down . Also check the icemaker rake , which should be about the 2:30 position . To thaw out the black tube (which runs thru the top of the refrig ) a 1/4 push on connector will be needed . Remove the icemaker and use a hairdryer aimed up into the hole . Cut the tubing to the fill tub behind the fridge about 9 inches from where it enters the top of the fridge . This will let warm air inside the top fill line to help thaw . Ocassionally blow thru the 9 inch tube until you can blow thru it . May take a day or 2 , depending how frozen the line is . Once air will go thru , install the push on connector to couple the cut lines back togather .
The blinking red light on the right side , is the receiver for the electric eye for cutting off the icemaker when the door bin is full , This blinking is normal . 2 blinks ...pause...2 blinks..etc .
Do not replace the filter if water flow is good thru the dispensor .
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Cold h20 not going into tub, and LF light comes on when tub empty
Is the cold water valve on if so your water valve screen is probably clogged . disconnect your hoses from the machine and clean out the sediment. LF is long fill the rinse is usually cold water .that you do not have. good luck let me know what you find.
Jan 13, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Ice maker not making ice
Sounds likw the water fill tubs is frozen shut, look where the tube comes into the freezer compartment and take a hair drier and thaw it out. Good Luck
Jan 07, 2009 | Kenmore 53642 / 53644 Side by Side...
GE WBSE3120B Top Load Washer Logo
322 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
