Question about Zenith E44W48LCD 44" Rear Projection HDTV
I have blue shadow starting at the top of picture, in the middle and goes down about 1/4 of the length of TV. It is shaped somewhat like a tornado. How do I get rid of it?
2 Suggested Answers
SOURCE: Top, middle of screen there is a constant flicker.
I have a blue line about 3/4 inch wide from the top right to the middle bottom. ( not a straight line ) I replced thr projection lamp with no fix to the problem. I added an additipnal fan and cleared up the problem. On furthe investigation I replaced the air filter and kept only the original fan and the problem was solved. Can you explain this.
Posted on Dec 18, 2009
I have small blue dots and a yellow shadow in the middle of my screen
The model indicated uses what is called a Optical Light Engine, it is a very expensive part and likely is your problem---not much else will cause this trouble.
Let me know if you have questions.
Dec 02, 2011 | Sony Grand WEGA KF42WE610 42" Rear...
How do you make a buttonhole with a Bernina 830?
Hey, I have a Bernina 830 Record. If it's the same machine, set your stitch length at 0 then back it off about 1 to 2 turns. The middle button is your button hole. Got to one and it goes down the left side, #2 is the bottom cross bar, #3 goes backwards up to form the right side of the buttonhole and $4 is the tack across the top, #5 stitches it into place. I have my original manual if you have any other questions!
Donna/Portland OR
Apr 06, 2010 | Sewing Machines
Weird blue flash when tv turns on or off
TV will need service soon, blue CRT is on its way out, will need replacing
Mar 25, 2009 | Sony KP-51HW40 51" Rear Projection...
The 3 colors are off, i have shadows and arches in the screen
It is failure of convergence ICs and these two ICs will be replaced on D board.
If you are comfortable with TV repair and know good soldering skills then can do the job easily.
Convergence ICs are mounted with sliver heat-sink on D Board of TV and part number will start with letter STK...
Get back to me if you need further info.
Jan 17, 2009 | Sony KP-57WS500 57" Rear Projection...
Blue "shadows" on my picture?
if you take the front bottom panel off, you will see 6 little nobs, look like this ::: the midle 2 should be blue, middle top is the focus, middle botton is intencity, turn the middle bottom nob down about a quarter to half turn, should solve prob
Jan 08, 2009 | Samsung HCM4215W 42" Rear Projection...
Shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Jan 04, 2009 | Sylvania 6626LCT 26 in. LCD Television
Picture has a blue shadow
Seems convergence out IC is fried in TV so it gives blue shadow.
Check out Convergence Out IC which you need to replace in TV, if you have enough experience of repair of big TV, necessary tools and know basic electronics.
Dec 18, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Shadow on screen
your vertical ciruit is malfunctioning
May 26, 2008 | Protron PLTV-32 Television
Green and red color problem on bottom left to a little past the middle of the bottom of screen
the convergence ic's are breaking down and require replacement should cost under $ 250 depending on your service shop.
Nov 18, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Zenith E44W48LCD 44" Rear Projection HDTV Logo
145 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
