Question about Samson Technology Zoom H1 Recording Bundle with Zoom H1 APH1 Accesory Pack and Samson RH300 Headphones
I just bought a Zoom H1 and the SD card won't format. What should I do?
  • Samson Techn... Master
  • 5,603 Answers
OK... first thing is to make sure the SD card is 2 Gb or less as larger won't work.
Many of the SD card has a protect switch that prevents writing to the card... it is a real tiny littl thing to move with your fingernail. You might need a magnifier to see it.
Posted on Apr 01, 2011
Zoom h1 handy recorder
Have you tested the Micro SD card? Check it with your computer and load an MP3 to it. Play the recording in the Zoom to check the Zoom
May 27, 2014 | Music
Why a low remain record time on zoom h1 handy recorder when .wav setting in use?
when you record in .wav format, the files ARE better quality, however, they are ALOT larger than a standard .mp3...if you can't tell the 'loss in quality', i would suggest to keep recording as .mp3...but if a .wav is preferred, then i would suggest upgrading the SD card. ..hope this helps.
May 23, 2014 | Music
H1 won't connect via USB
This page has a download for a driver........ https://www.zoom-na.com/products/field-video-recording/field-recording/zoom-h1-handy-recorder
Also try a different cable....... Good Luck!
Mar 25, 2017 | Zoom H4 Handy Recorder
Download the H1 driver for windows & try different usb cable........
Mar 09, 2017 | Music
H4n zoom wont record says card protected
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 23, 2013 | Samson Technology Zoom H1 Recording Bundle...
My new Zoom H1 will not connect to computer through USB.
Hi did you get it sorted,got the same problem,dont want to have to send it back only got it today, saving for ages,can you help
Oct 28, 2012 | Samson Technology Zoom H1 Recording Bundle...
H1 wont power on
I just discovered the same problem with my H1. When plugged to computer, nothing happens neither. It turns out it may be just the contact issue. You will have to carefully disassemble it (you'll need one small screw driver. watch for the small wires). There are two PCB boards one on top of the other, and between them there is the contact that I believe came loose or dirty causing the issue. Play with that, and with battery in, try to turn it on.
Apr 03, 2012 | Samson Technology Zoom H1 Handy Recorder
I've bought a SDHC card 32 GB but Handy Recorder H4 do not recognize the card. I've tried to format it at the pc, but no way, the message is "no card"
Verify the device and card reader support SDHC. Try a 2g card and see if that works, typically anything 4g or larger is SDHC, older devices can not read such cards. It is quite possible that the card is bad.
Oct 14, 2011 | Zoom H4 Handy Recorder
When I turn on my Zoom H4n, it says "no card" even though I have a card in it. Why is this? How can I fix this problem?
My zoom h4 will not turn on at all....not with new batteries or the AC adapter.....any suggestions? Worked fine last time used.
Feb 13, 2010 | Zoom H4 Handy Recorder
Samson Technology Zoom H1 Recording Bundle with Zoom H1 APH1 Accesory Pack and Samson RH300 Headphones Logo
2,893 people viewed this question
Top Samson Technology Music Experts
Michial Gueffroy
Chris Larocque
Are you a Samson Technology Music Expert? Answer questions, earn points and help others
