On the back of the 7750 toner there is a metal piece you can push in near the end that goes in to the machine first, this will tell the printer that the toner you put in has not been installed until now. I would not suggest doing this unless the toner is full and is using geniune xerox 7750 toner.. If you refill it with generic or non-7750 toner it can damage the machine and will void any warrenty you may have left on the machine.
If you switch machines with the 7750 toner the machine will not know how much toner is remaining in that toner. Xerox changed this method on the 7760 to use a toner chip to fix this.
Hope this helps, thanks
