Question about 991 Responder LC3 SST Security/Remote Start System
I have a 2005 Subaru Outback with the Python 911 etc... the set of lights (front side yellow, and back red) that flash when you lock and unlock will not turn off even now that the car is off, locked, keys out of it. I've checked everything obvious with the car controls and nothing is different. Since these are the same lights as the alarm I thing the two are connected. Any ideas?
    Guru:
  • 257 Answers
Hello Ihemker,
I understand that you are having a problem with you Python 991 system. The problem is that you front and rear parking lights are not turning off when the alarm is set. Python does not have a suggestion as why this is happening. However, usually resting the system will revert the system to the last good setting.
The system needs to be rest. You can disconnect the car battery for five minutes. The security system has a back up battery that will save the settings of the alarm. If this does not work you will need to take it the a dealer and have them reset the unit.
Thank you for choosing FixYa.com
Justin
Posted on Apr 01, 2011
Subaru outback 2005 remote only unlocks
there is a theft locking module in the center consel next to the dash
Jan 28, 2013 | Subaru Outback Cars & Trucks
Need a stereo color code diagram for 2005 subaru outback Problems
Check this information about 2005 Subaru Outback Wagon Car Stereo Wire Guide:
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Brown/White
Left Front Speaker Negative Wire (-): Green/Black
Right Front Speaker Positive Wire (+): Red/Yellow
Right Front Speaker Negative Wire (-): White/Black
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Red
Left Rear Speaker Negative Wire (-): Red/Green
Right Rear Speaker Positive Wire (+): Blue/Green
The 2005 Subaru Outback Wagon radio wire color information above is updated as it is submitted by the Modified Life community.
Hope helps (remeber to rated ans leave an testimoanial about this free answer).
Sep 29, 2011 | 2005 Subaru Outback
Subaru 2005 legacy outback wagon driver's side
Check for a blown fuse for the lock system.
Mar 22, 2010 | 2005 Subaru Outback
2009 Subaru Outback front and back marker lights will not shut off. Security light is flashing... Help?
Hello, Ok, first... If you can still lock and unlock the car with your remote normally, the security system is working normally, when the car is off and the key is out of the ignition, door open, closed, locked, or unlocked, that security light will blink every 3 seconds or so. Second, look on top the steering column cover to find a small rocker switch, that is your park lamp override switch that allows you to turn on your park lamps with the key off because Subaru's cut all accessory light power once the key is off, they just wanted you to have that choice. This is most likely your problem, I hope this info helps...(subyguru)...
Feb 21, 2010 | 2005 Subaru Outback
Need wiring schematics for 2004 Subaru Outback wagon- installing after market stereo
2004 Subaru Outback Wagon Radio Stereo Wiring Diagram
Right Rear Speaker Negative Wire (-): Red
Jan 31, 2010 | Car Audio & Video
Disconected my battery cables.......lights flash
Regulator is bad or alternator is going out.
Sep 28, 2009 | 1997 Subaru Outback
Drivers side door is stuck in the lock position
door handle probably broken ,usually the part of the handle that houses the rod that moves latch breaks,see if the outside handlehas less resistance than others when lifting it this is a pretty good indicator
Jun 15, 2009 | 2004 Subaru Outback
'99 subaru legacy gets 2 flashes from LED and
try opening door and holding unlock button ,it sounds like its in valet mode
Jun 15, 2009 | 2001 Subaru Outback
Open Questions:
See all 991 Responder LC3 SST Security/Remote Start System Questions
991 Responder LC3 SST Security/Remote Start System Logo
Top Python Vehicle Parts & Accessories Experts
rjivaro
Kevin Daniels
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
