Question about Toshiba Audio Players & Recorders
The remote will not work replaced batt. with new ones clear line to sensor
    Brigadier General:
  • 8,546 Answers
Try this advice:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12954406270641
"Dead" Remotes Can Be Saved
How to Re-Start Your "Dead" Remote Control
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. If you do then the problem might not be the remote but the sensor on the unit.
If it works, Great!
If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Find new or replacement remotes:
http://remotes.com/store/codes_original.html
or eBay: search for "(model) remotes", check the 'include description
Posted on Apr 01, 2011
Model #3217. Why doesn't remote work?
Try removing batteries and pressing all buttons in case one is stuck. Reinstall batteries and try again.
Apr 09, 2016 | Televison & Video
Lg3d 55la6200 Remote stopped working all new
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Be sure about the polarity of the battery when you insert it in its compartment. If any one among it gets reversed, the remote control won't work.
Sep 15, 2014 | Televison & Video
Remote or infra red sensor in tv
Many times remotes just need cleaning. Take it apart an if you feel a clear liquid under the keypads, clean it off an it will work. The silicone used on remotes ages an leaves a film that stops it from working
Mar 23, 2014 | Logitech Televison & Video
Colby lcd with short remote range
first replace the battery of the remote with a new one then clean the remote sensor clean any dust accumulation.clean also the remote reciever sensor wipe it with a soft cloth
Apr 08, 2012 | Coby TF-TV3208 32 in. LCD Television
My remote control has stopped working ,i have tried new batteries but it not work
good day... well you said you already replace w/ new battery..try to check the batt. terminals if still intact...if you can disassemble it to clearly check the wires.. if still good I suggest that you replace the infra red LED...goodluck
Feb 12, 2011 | Abt Television 1745 Remote Control
Remote quit working, batts new and no obstruction to IR signal?
A remote wears out far more faster than the device it controls (the sweat from your palms is highly corrosive). Nothing you can do, just buy a new one.
Jun 08, 2010 | Televison & Video
Remote control not working
It could be either remote is bad or remote sensor located at tv front is not working.
You can test remote with help of any digital camera, watch remote front through camera and press few buttons on remote, you will see infra red led blinking at remote front, that means remote is good and working. Remote sensor in tv is defective and need to be replaced by qualified tech.
If infra red led of remote does not blink pressing any button while watching through digital camera then problem is remote, buy new one to solve the issue.
Thanks.
May 05, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Need to reset the tv/remote on a sony trinitron
Make sure you have fresh new batteries and installed correct,point the remote at the tv,make sure nothing is blocking the view of the IR sensor,get close to tv,but not to close,press power.If it still dont work, try the tv itself,press power,you may need to replace the remote,or the IR sensor, hope this helps.....
Mar 08, 2010 | Sony Televison & Video
Remote control dosnt work on this tv
I have the same plasma Pioneer tv. I also tried a replacement remote and no fix. I replaced the infrared receiver module (~$4 from Radio Shack) on the TV, yes it involved taking the tv apart. Voila, now I have two working remotes.
May 12, 2009 | Pioneer Televison & Video
2nd Wii remote not working this is the 2nd one
press the sync button on both the wii and the wii remote through the batt door on the remote and the button behind a door like thing next to the disk slot the blue lights flash then press wii red sync button again while pointing remote two at the sensor this should bring it on line !!!!!
Jan 01, 2009 | Nintendo Wii Console
698 people viewed this question
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Electro Med Services...
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
