Question about HP DesignJet 130NR InkJet Printer
HP Designjet 130 ejects paper immediately from front, rear and tray. Pulls paper back and forth then ejects it from the tray or rejects it from the front. Printer printed the paper calibration sheet but then won't read it.
  • michaeldeg Apr 01, 2011
    The only sensor I see in the paper path is the OOPS, is this the sensor you are talking about
  • HP Master
  • 1,915 Answers
It sounds like you have a bad leading edge sensor. This causes the printer to not be able to track where the paper is. Replacement of this sensor requires a certain amount of technical confidence as you will need to disassemble a certain amount of the printer.
Posted on Apr 01, 2011
  • 1 more comment
  • Mark Schmit
    Mark Schmit Apr 01, 2011
    I just checked the HP tech database and they suggest the following for paper rejection. I know on the 110 series the oops sensor would cause the problems you are experiencing, however HP does not list this as an issue on the 130
    If the customer cannot load media through any path:
    If the paper is not detected or rejected, check the sensors in the cleanout and in the printer.
    If the paper does not move correctly inside the printer and is rejected due to skew, check that the Pick Roller Assembly and Feed Rollers are not worn out.
    I don't believe I have a sensor in the cleanout as I do not have the roll attachment. Pick Rollers seem to take paper from the front feed flawlessly. Is there some sensor that is reading the skew of the paper, and is used for calibrating the paper path?
  • Kunihiko Matsui Nov 03, 2011
    We are having the exactly the same problem. We just replaced OOps sensor but did not solve the problem. Any idea?
Hp designjet 130 color calibration fail
According to the error codes page, the only solution is to use the proper paper for the selected test and run another calibration test:
https://support.hp.com/us-en/product/hp-designjet-130-printer-series/352387/document/bpp03841#AbT1
Apr 22, 2018 | HP Office Equipment & Supplies
On the laser printer HP 3600n it says it needs paper in tray 2. where is tray 2?
The printer comes with one main tray which is referred to as tray 2. The bypass tray is labelled as tray 1.
Jun 01, 2014 | HP Laserjet P3015X Printer
Hp designjet 130 carriage moves to the left and will not stop
If the printer has ink cartridges, check to make sure one of them did not come "undone" and is stickup up slightly. If so, just press it back in place.
May 04, 2014 | HP Hewlett Packard C7791C - Designjet 130...
HP designjet 130NR won't pick up paper from the tray.
paper tray lift clutch failure is likely the cause - common for this machine - repair with new feeder assy ordered whole from HP/ or Partsurfer
Jan 28, 2014 | HP DesignJet 130NR InkJet Printer
Tell me please hp laserjet printer 2420 paper tray setting
    1. Remove the packing material from the printer.
      1. Remove the all orange tape from the outside of the printer.
    1. Load all paper trays.
      1. Pull the paper trays completely out of the printer.
    2. Press the blue tab on the rear paper length guide and adjust the rear guide so that the pointer matches the size of the paper to be loaded. c00318778.gif
    3. Move the side width guides outward to match the desired paper size. c00318779.gif
    4. Add the media to the paper trays, make sure that it is flat in the tray at all four corners. Keep the media below the height tabs on the sides and rear of the tray. Push down on the metal lift plate to lock it in place. c00318780.gif
    6. Install the print cartridge.
      1. Remove the print cartridge from the packaging.
    7. Rock the print cartridge back and forth several times to "mix" the toner. c00318783.gif
    8. Pull the sealing tape from the end of the print cartridge to remove the entire length of the tape. c00318784.gif
    12. Connect the LAN cable (optional). (HP LaserJet 2420n, 2420dn, 2430tn, and 2430dtn models only) c00318788.gif
    Jan 13, 2011 | HP LaserJet 2420 Printer
    HP DesignJet 430 rejecting media
    When you load the paper, the carriage edge detector measures exactly where the right edge of the paper is located. Then the paper is rolled forward and the edge is measured again. If there is a difference in the measurements, the printer assumes the paper is not loaded squarely and rejects the paper. After you load the paper and the printer asks you to align the paper, take your time, release the paper with the release lever, and line up the right edge of the paper with the right edge of the paper roll. You might have to do it more than once to get it to load. Some plotters are very sensitive and others are more forgiving.
    Sep 25, 2009 | HP DesignJet 430 InkJet Printer
    Kyocera Mita FS 3800 :I get one message:Open the rear unit and remove the paper. Then pull the green lever and remove the paper. Check for paper inside from the rear and remove the paper. So i just make...
    the green lever it is referring to is on the front if you pull out the tray. it is your conveying unit. sounds as if you have a paper bit bit stuck in a sensor or a broken sensor.do you have a rectangular piece on the back of the printer that pulls out? that would be your duplexing unit (there are a couple sensors there too) sensors are black and should move back and forth freely when touched with your fingers.
    Aug 04, 2009 | Kyocera Mita FS 3800 Laser Printer
    Hp designjet 110 is not printing. paper is spooling then stops, retracts. orange error light is blinking. can't find users manual
    check ur orange cartredge
    & check ur orange printer head & clean ur printer head
    ur problem is solve
    because this problem is only cartredge & prinater head
    Apr 22, 2009 | HP DesignJet 110 Plus InkJet Printer
    Laptop Disk Drive want reject.
    If you mean the CD or DVD drive,,,then you can take a paper clip and bend it straight,,then put the paper clip into the tiny hole in the front of the CD tray and gently push,,,this will open the tray enough for you to grip it by hand and pull it out the rest of the way.
    Jan 19, 2009 | Sony (DW-D56A-10/20) (DWD56A1020) DVD...
    HP DesignJet 130NR InkJet Printer Logo
    1,095 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
