Question about Compaq Computers & Internet
During boot got a blue screen telling me the harddrive had a virus,replaced h/d also ran disk sanitizer..when trying to reinstall xp get the same blue screen when the install gets to the "starting windows" part..? haylp! :]
    Master:
  • 525 Answers
Hi there. Sorry to hear you are having trouble. However this is a really simple fix. All you have to do is remove your ram sticks for 10 seconds and put them back in. Make sure there is no power when you are doing this. Then restart and run your setup again. There may be a chance that you can save your old hard drive as well. Good luck...
Posted on Apr 01, 2011
Windows XP did not start successfully. The screen gives me five opitions. Safe mode, safe mode w/networking, safe mode with command prompt, last known good configburation and start windows normally. All...
There are several methods to get a non-booting PC to work again. Because you don't have an XP disc I'd suggest select the option that says "Don't restart on boot failure" or something along those lines. Then when it goes to a blue screen, use this website to help you further diagnose the problem: http://aumha.org/a/stop.htm
Mar 14, 2011 | E-Machines T3410 (RBT3410) PC Desktop
Help, a friend got some virus on her machine. I cleaned off the virus but now we get the blue screen. She did not get OS disks with her computer. She is running MS XP Home Ed. SP2. I don't know what to...
I don't think the disk you have for the gateway will work due to the fact that is has a different serial number...if you try to load it, there will possibly be an error saying it's the wrong machine. try to boot the computer to safe mode. To accomplish this you need to start the computer as normal...then right after the bios screen(with the comp manufacturer logo) you want to press F8...there you will see a list of options...scroll through them till you get to safe mode and press enter...a screen may pop up telling you that you are running in safe mode, answer yes to this...while in safe mode, you can go to user accounts to see if the virus did something to your password(if you use passwords) and change it back. then you will want to shut it down properly and see if it will then boot...now if it won't go to safe mode then the virus probably corrupted your o/s and you will need to reinstall it. As for the operating system disk, you may be able to contact acer to see if they can send you a copy of the o/s disks...oh and also, there may be a partition on the hard drive that contains the recovery sector. Other than that...you may need to start from scratch and wipe the harddrive clean and do a clean install with a new set of o/s discs or a new o/s
Dec 21, 2010 | Acer Aspire 3000 Notebook
Please help! First power on, when boot up, my Dell 5150 goes directly to "Start Windows Normally" screen selection. Sometimes when boot up, screen goes to a blue with "A problem has been detected and...
Main cause of the problem is a corrupted operating system which can be cause by a virus or a defective hard disk or a defective memory module. First to try is to replace your memory with a certified good one. If the problem persists, Try to reinstall you windows using your CDRom. If there still the problem, replace hard disk.
Sep 11, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I have an Acer 3680 laptop and just now it was making with odd kricking noise, like it sounded like it may have been the fan or something. And then a blue screen came up so i shut it down like it told me...
The noise could have been the read/write mechanism inside the disk-drive grinding against the recording surfaces of the disk-drive.
So, your best plan:
* buy a new disk-drive
* reinstall Windows onto the new disk-drive
* copy all your "data" files from the old disk-drive to the new disk-drive, and do this *BEFORE* the old disk-drive *COMPLETELY* "dies".
Jan 13, 2010 | Acer Aspire 3680 Laptop
HP DV4 displays only a blue screen running vista
Shutdown the computer,disconnect external peripherials.
Turn on the computer and hit F8 key as soon as you restart the computer
You will get the windows advance options menu.
Select the Safe mode option and hit enter.
If the computer boots in safe mode, do a system restore to previous date.
If computer restore then issue is resolved.
If still unable to boot in safe mode.
Ran a harddrive diagnostic.If harddrive test passes. If harddrive test fails replace harddrive.
Boot the system using the windows xp or vista operating system disk. Try to repair the OS then reboot the system and check.
If still unable to boot possible issue with corrupt operating system.
Reinstall Operating system. / Recover System . Good Luck.
Aug 27, 2009 | HP Pavilion dv4-1140go Laptop
Blue Screen Issues
can nit be the motherboard cause you would not be able to boot at all ...probably it was just a real bad virus that affect something ..try to reinstall it clean...first remove the hdd and see it it boots to bios and if it sees the RAM memory ...and even so ..try to get from somewhere some suitable ram memory and replace teh old one ...just to see how it behaves....in most cases I run into when they blow me out and gave blue screen without explanations it was some issues with the ram memory ...so ...first just borrow some of the same size and frequency and see if it boots up ...it might surprise you in a positive way ...
Aug 18, 2009 | Dell Dimension 9100 PC Desktop
Cannot find operating system when booting
Could be your harddrive is out of the system. Check its connections first, then have it detected. If not still been detected try changing cables and power plugging(interchange if it can). Other done than maybe failed drive already.
And before I forgot remove any other booting disc, usb, or flash card. Maybe you left one. Or try to lessen your fan usage during fault finding.
Jun 02, 2009 | Microsoft Windows XP Home Edition
Unable to reinstall windows xp
try it again with the bootable floppy disk... if you have the option use fdisk /mbr and then format the computer and reinstall using the cd you have. the fdisk /mbr command will get rid of any virus residing in your master boot record.
May 24, 2009 | Microsoft Windows XP Home Edition
Harddrive corruption - Computer not booting-up
My friend....sorry to tell you this, but there is only one solution for your problem. And that is to a clean reinstallation of OS. Only that will kill all virus and trojans on the hdd.
And after that be sure that you ALWAYS have an updated virus protection program running.
Good luck M8
Nic
Mar 12, 2009 | Computers & Internet
Operating system & harddrive not found
Did you remember to enter the BIOS setup and change the boot drive so the system would look to the (optical) drive in which you have put your XP disk? In most cases, you must tell the system where to look for boot files and with a new hard drive, there are no files to find.
If you don't have any malware defense installed yet, and can again get it up and running enough to go on line, I would recommend all of the following:
- AVG Free Grisoft Home Page - Spybot S&D Spybot Home page - AdAware Lavasoft Home Page
Basic versions are either free or ask for donations.
Oct 26, 2008 | Gateway 4525GZ Notebook
Computers & Internet Logo
20 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
