Question about Maytag 30" Built-In Single Electric Wall Oven - Black
I have a Maytag oven Model # mer5755qab and the bake pushbutton is not working. Do I need to replace the whole circuit board and if so where can i get one or is there easy fix
  • Maytag Master
  • 3,053 Answers
Hello, natural
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and even farther back. It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this Informational site may not have your exact model or brand, this site will help you a lot. Here is a site link about everything you want to know about ovens and possibly yours, from
repair to trouble shooting it. Now go easy on me, I am just trying to help. If it does great if not, I am sorry.
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help , I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
Kenmore electric range model 911.95875790, no heat to either baking and broiler elements.
Hello. I looked carefully at the service manual for your unit--surprisingly, there is no thermal switch inline with the bake/broil elements. Usually, if the bake or broil elements pop, this blows out the thermal switch, killing power to the elements for safety. The main control board can get damaged due to the high current draw during a short-circuit. The part number for the main board is WB27T10008. The overlay(the decorative sticker with the button/names on it) numbers are as follows: almond WB27T10022, black WB27T10023, and white WB27T10021. I hope this helps you!
Sep 18, 2015 | Kenmore Ovens
Maytag Model MEW6530 Baking Element
Theck the thermostate, the thermostat is the circuit that activates the heating, and power the baking element , when this is faulty there is no heat or low it, give it a check.
If you need to buy the replacement part, or to locate the thermostat, check on this website, they provide exploded view, so that you can locate the part.
Oct 29, 2008 | Maytag 30" Built-In Single Electric Wall...
Broiler comes on on top oven every time you turn bake on and won't go off. Recently replaced temp sensor for similar sporadic problem and worked for a while but now happens every time
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
: I offer free advice bcuz God is so good!
May 20, 2015 | Ovens
Thermador smw 272 not heating via bake or convection. Light and fan work as well as broil and clean (microwave fine too). If I switch from broil and then to bake after heated, it will hit right temp and...
see if there is a bad solder connection on the bottom (underside) of the board just below one or more of the small black relay boxes. re-solder if you can or replace the whole board.
Jan 04, 2015 | Thermador Ovens
Maytag electric wall oven model #CWE4800ACB
Try shutting off the breaker and turning it back on after a few minutes.
Sep 05, 2014 | Ovens
I just replaced my baking element in my oven, and when i turned the breaker back on, now the new element automatically heats up by itself and stays on....with everything off. The only way I can get it to...
If the only wires you disconnected and reconnected were the 2 on the element itself, the bake relay is fused. Depending on the brand and model, the bake relay can be located on either a realy board or the electronic oven controller. Either the controller or the relay board (if present), will also need to be replaced.
Apr 16, 2011 | Stoves Ovens
GE Profile Wall Oven Circuit Board
http://www.searspartsdirect.com/partsdirect
I HAVE QUESTIONS. THIS THERE 240 VOLTS AC TO OVEN. YOU MAY HAVE A BREAKER PROBLEM. FLIP THE BREAKER BACK AND FORTH 3-5 TIMES FAST TO GET IT TO RESET. IF THE LAST THING YOU DID WAS A SELF CLEAN THEN YOU MAY HAVE A SAFETY THERMOSTAT PROBLEM. IF YOU CANNOT FIND THE WHOLE MODEL NUMBER ON THIS SITE CALL 1-800-GECARES THEY WILL HELP YOU WITH PARTS
Apr 25, 2010 | GE Profile JTP18 Electric Single Oven
Temp control stopped working properly
replace the electronic control board.the power surge may have damaged the boards circuits.
Jan 29, 2010 | Maytag Appliances 27" Electric Double Wall...
Bake button and numbers on the keypad have stopped working
HI, this is a touch pad issue but, due to the integrated design of the control board and touch membrane, you will have to replace the entire control board in order to fix this issue. you can purchase this board at the link below.
CLICK HERE
May 20, 2009 | Maytag MEW6530DDS Stainless Steel Electric...
ALL BUTTONS ARE WORKING, BUT SUDDENLY MY "BAKE" BUTTON QUIT. EVERYTHING ELSE WORKING.
I would Have it Checked. It Sounds like a Transistor or the Circuit Board Needs to be Replaced.
May 12, 2009 | Ovens
Maytag 30" Built-In Single Electric Wall Oven - Black Logo
50 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
