Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Leak my washer has gone through all the error codes at one time or another, we have had socks stuck in the bottom of the washer so many times that the sears repair man showed my husband how to fix it. Now we have water leak all over the laundry room every couple of weeks with no reason that we can find. No socks, money, toys etc...Help this washer has been the worst purchase I have ever made.
    Novelist:
    Champion:
  • 261 Answers
Ok Let us look at everything that can leak on the machine, get a good light and check the following.
Hoses on the back of the pump
The bellows, grey seal at door
The boot were it attachs to the tub
Look at the tub for water dripping off of center where the seam is
Posted on Sep 15, 2008
W10158202A Washer shows F29 Error code.What is this and how it can fix?
Could be the machine is not level.
Unplug the machine
Remove the lower panel on the bottom front of the machine (3 number torx screws). There should be a technical information panel giving error codes etc.
You can manually open the door by reaching up and pulling on the door release tab located below the door switch
May 02, 2016 | Washing Machines
I have received an f25 error code. tachometer problem. I've replaced mcu, checked all connections a million times, checked proper resistances across tach and motor. what next?
Check to see if there is a sock or underwear stuck outside of the drum. Your hand can separate and fit between the rubber rings around the door. On the upper left side where the intake tube is, I had a sock stuck that gave a F25 error. Once I removed it the error code was gone. Also check the bottom valve for objects. Just put a tray under it before you unscrew it because there might still be some water left in there. And while you are at it check the outlet tube if there is anything plugging it.
May 03, 2014 | Whirlpool Duet GHW9150P Front Load Washer
When we turn our washer elite on it gives us a error of sud?
susds error is a an fault error ....the machine has detected excessive tub pressure could be from not using "HE Soap ....if your are good but you might be using to much.... whens the last clean cycle you have ran to clean excess inner tub buildup on your washer .....
1 #drain all water out of filter sump behind lower front axcess panel make sure washer is unpluged
2# reinsert filter sump and and leave axcess panel off u make have to do this several times...
3# now check black rubber hose that goes from pump to bottom of tub remove clamp check for any obstructions in bottom of tub clean float ball of debris and reinstall and reconnect clamp to buttom of tub..
4# now pour 1 cup of vinegar directly in the tub where your clothes go and shut door( dosent mater what kind of vinegar or an affresh tablet
5# plug washer back in now lets run a clean cycle or any cycle that usues hot water ....
6# if unit suds code again this could happen a few times we need to flush out the buildup you may have to repeat steps 1-6 a couple of times....
Jan 26, 2011 | Kenmore Elite HE5t Washer
F 21 error code on whirlpool front loading washer. What is it?
Check your filter screen under the bottom panel. Things like socks get stuck in there. Unscrew bottom cover remove screw top cover located right in the center of the bottom. Might want to grab a towel! Screw it back on. Restart. Good luck.
Aug 22, 2010 | Whirlpool WFW8300SW
MACHINE NOT DRAINING ERROR CODE E:04
check the hose it's clogged or the stainer it's clogged too
Jan 15, 2010 | Bosch WFMC 3200 Front Load Washer
Mildew odour from Whirlpool Duet washer.
I've had this problem a couple of times over the years I've had this washer. What caused the odour in my machine was one (or more) of my kids' socks getting stuck in the machine. With the door open, gently reach in and bend the grey rubber door seal back and feel for clothes that have slipped between the drum and the rubber. If there's nothing there and it has been smelling bad for a while, then it's likely that the socks have been sucked into the drain. To clear this without paying a $150 service charge (I did that the first time and watched him fix it in 10 minutes), you'll need to remove the bottom front plate of the washer (there are only three or four Torx -or star head- screws holding it on). Once that plate is off, you'll see a white plastic knob that is the cap of the drain trap. Unscrew the cap and a couple of cups of water will leak out so shove a couple of towels under it beforehand. You should find some long-lost now-rotting socks. The last time I had to do this, I found FOUR socks in there. This also contributes to the 'suds' error message as it prevents proper drainage. I've only had this problem with kids' socks, everything else is too big to get stuck, I guess. Maybe try a laundry bag for the smaller stuff.
Apr 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Unbelievable...leaking again!!!
take panel off at bottom rear. you will see a large diameter pipe going from bottom of machine to pump. undo pipe at machine end - carefull lots of water will come out. sock was probably in this pipe which also holds the filter
Jun 17, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Whirlpool Duet Washer-error code "sud"
Just take off the bottom kickplate (3 screws on the bottom). You'll see the pump front and center. Twist the front face of the pum slowly to the left. All the trapped water will flow right out towards you. There could be a sock or some other debris there. Unclog, screw that faceplate back in and start it up.
Sep 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
F02 what does it mean
I have had this issue more than once. It was an easy fix for me (maybe a 20 minute job and best of all no money). For my F 02 error it was my 4 year olds socks that some how got down the drain line and stuck in the clean out. Here is what you do. There are 3 screws bottom of the front access plate. Remove these and the lower access plate will pop right off. Right in front you will see the pump and the drain line. It has a clean out right there. Unscrew the cap (be ready for alot of water to rush out, so have alot of towels ready). Once the water is drained remove the cap. The cap has a trap so that larger items do not get to the pump. This is where I find the socks stuck. Clean it out, tighten the cap back into place, put the access panel back on, and hit run. Has worked for me at leaste 3 times. Those pesky kid socks every time.
Apr 28, 2007 | Kenmore Elite 45986 Front Load Washer
E20 error message
The E20 error code means - not draining It seems more as an issue of a clogged drain line or malfunction pump.
Dec 11, 2006 | Zanussi ZWF1440 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
Sal De
fordexpert
Robert Rankin
