Question about Onkyo Audio Players & Recorders
My older onkyo stereo system suddenly stopped producing sound.It turns on but usually when I press the power button it clicks once then about 5 seconds later another click puts power(and sound)to the speakers.Now there is no second click and no sound.
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Apr 01, 2011
How do you reset the system.
To reset the component Hi-Fi stereo system to factory settings.
  1. On the stereo system, on DECK B , press and hold the STOP button.
  2. While holding the STOP button, press and hold the TUNER ENTER button.
  3. While holding the STOP button and TUNER ENTER button, press the POWER button.
  4. Unplug the power cord from the electrical wall outlet.
  5. Plug the power cord back into the electrical wall outlet.
  6. Turn on the stereo system.
Sep 30, 2014 | Sony STR-DA3000ES Receiver
Why Onkyo HTS-9400THX: Front both and subwoofer not working.?
Try differnt speakers, if they do not produce sound, amp channels may be blown and then you need to take it to a shop.
Aug 01, 2014 | Audio Players & Recorders
I have a 2008 ford ranger xlt 4x4 4.0 truck. we changed the motor and sense the battery was disconnected the anti theft system locked down how do we unlock it.
follow this steps and fix it. God bless you
Turn the vehicle on. The engine does not need to be running but the ignition should be on to power the stereo.
  • 2 Press the "Source" or "Power" button to turn the unit off.
  • Sponsored Links
  • 3
    Press and hold down the "Minute" button (located to the left of the GM vehicle stereo's display. Some models require pressing and holding the left arrow button if no "Minute" button is present.) Release the button once the display shows "0000."
  • 4
    Press the "Minute" button (or left arrow) to set the value of the third and fourth digits of the anti-theft code. Release the button once the proper value for the last two digits is displayed.
  • 5
    Press the "Hour" button (or right arrow button) to set the first and second digits of the code. Release the button once the four-digit code is accurately displayed.
  • 6
    Press the "Mode" button to lock in the code you set. Turn the stereo deck on by pressing the "Source" or "Power" button to complete the reset.
  • Read more: http://www.ehow.com/how_6924001_reset-anti_theft-code-car-stereo.html#ixzz2gZHpH2aT
    Oct 02, 2013 | 2001 Ford Ranger Regular Cab
    No sound from back channels of my dtr-7 stereo receiver
    Do a Factory reset. it's most likely a speaker setting issue. press VCR and wille holding it press the Standby button. once you see clear on the screen it is done. try it now!
    Nov 09, 2011 | Onkyo DTR7 Receiver
    My amp stopped workin, when i turn the stereo on, the green light is on, then when the music starts to play it turns red and stops working,
    The red light on amplifier relates to power supply while the green light is indication of sound functionality. An amplifier that allows sound to generate should display both red and green lights. Howeever, some amplifiers would display only green as long as the sound is functioning.
    Solving the problem
    First, a red light still on means the power connections to the amplifier is fucntional least requirng repairs.
    Second, the green ligh should turn on once the stereo were tuned up to produce sound. If the stereo is still on only least produce sound on the amplifier, check on the connection wires between stereo to amplifier that may have disconnected due to woofing or dubbing sound generals with unfirm wiring.
    Third,
    Jan 28, 2011 | JVC KS-AR7501D Car Amp
    Garbled / feedback sounds from powered subwoofer
    The surround processing portion of the unit has a problem. In either stereo or direct mode, the digital procesing is bypassed. This could be just the surround processing IC, but that IC may not be available as a separate part. I would suggest that you bring this unit to an authorized Onkyo service center for an estimate.
    Dan
    Mar 18, 2009 | Onkyo TX-DS595 Receiver
    Getting Back Speakers for Onkyo tx 500 to work
    I had to turn my speaker B off in order to set up my 5 speaker system. Thanks for getting back to me though. I really appreciate it.
    Dec 09, 2008 | Audio Players & Recorders
    HELLLLPPPPP
    First Remove the UMD from PSP if any
    1. Switch ON the PSP 2. Press and Hold the Left arrow button until the Sound of "click" Stops. 3. Press and Hold the Up arrow button until the Sound of "click" stops. 4. Press the Down arrow button 4 times (so u will be in System Settings) 5. Press the Enter Button i.e X 6. Press the down arrow button 9 times so u will in "Restore Default Settings" 7. Press Enter button i.e X once 8. Press the Left arrow button once and then press X button once 9. Press the Left arrow button once and the press X button again 10. Press the X button
    See whether u r PSP restart and solves the problem
    Oct 19, 2008 | Sony PlayStation Portable (PSP) Console
    Sony FWD50PX2/S 50 in. Plasma Television power problem
    It does sound like a power supply problem but that can be misleading because a problem somewhere else in the TV can be "holding down" the power supply. This can usually be determined by using some isolation techniques.
    Aug 08, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
    No Sound
    Called Onkyo and here is the solution they gave me.
    1. Turn on unit.
    2. Press and hold VIDEO 1 button.
    3. While pressing VIDEO 1, press Speaker A button.
    4. You should see "CLEAR" on the display for a second and it will go on stand-by mode.
    5. Turn on the unit and check if sound is back.
    Hope this helps
    Mar 30, 2007 | Onkyo TX-DS575 Receiver
    117 people viewed this question
    Top Onkyo Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
