Question about Magic Chef CTB1722 Top Freezer Refrigerator
We moved our magic chef frig on the deck-plugged it into an outlet with too many thing running. The breaker tripped.Not the frig light comes on but the frig does not work. Is there a reset button? If so, where?
  • 132 Answers
There is no reset button.
Firstly turn the fridge off at the wall switch. Wait 5 minutes then switch the power back on. If the fridge still does not start then you have a problem with either the fridge electrical circuit has a fault or the circuit board fuse has blown.
Posted on Apr 01, 2011
Magic Chef MCBR415S when I plug it up the breaker flips in the breaker box. What is wrong
is voltage select switch on back near power cord entry set for proper voltage ? 120 for usa and 240 for Europe and Canada also check light bulbs inside they could have gotten broken to cause a shortage
Aug 09, 2016 | Magic Chef Microwave Ovens
QWhy won't magic chef 6 cubic chest freeze freeze anything after I defrosted it?
Try plugging something else in the outlet. A lamp would work to make sure you did not trip a circut breaker when you plugged back in after defrost.
Apr 23, 2014 | Magic Chef 5 cu. ft. / 142 liter Chest...
My Magic Chef microwave tripped a breaker,I found a melted door switch and replaced it, the other three test ok.With the door closed everything works like new. When the door is opened the breaker blow
The only thing I can think of is check to make sure all switches are aligned correctly otherwise you will keep tripping the breaker, I'am certain that one of your switches are not properly in position.
Jul 07, 2012 | Magic Chef Microwave Ovens
Frig is intermittently tripping GFI outlet.
To be short, the only thing in the machine that really has the capability of causing that is the compressor. Its got a floating short in and when it makes contact it trips the outlet/breaker. Check for any exposed wires just to be sure but I'm pretty certain that the compressor is the culprit and either it or the machine needs to be replaced.
Apr 21, 2012 | Kenmore Refrigerators
Oven will not light
check to see if both sides of the 220 are hot , had the same thing happen and found one side had come loose , which caused the breaker to trip in thr frist place
Mar 05, 2012 | Magic Chef Kitchen Ranges
Magic Chef refigerator/freezer stopped running
if you said stop running id assume that there is no power?? even with good electrical input..
for that instance, better check.charred cables.. if not there maybe a problem with timer itself..
Nov 05, 2009 | Magic Chef CTB1922 Top Freezer...
Not cooling
From my earlier post, our compact Magic Chef 'frig was not running at all.  It still looks perfect, so decided to check on the repair.  It turned out to be the "starter switch," I think is what the switch was called.  The repairman said this is a very common problem, so he had the switch we needed in his truck.  It was repaired quickly and is running great.
Cost was about $140, part plus labor.  A replacement would have been only a few dollars more, but would take more time and effort.  FYI, the compressor on these Magic Chef refrigerators has a 5-yr warranty.
Hope that helps someone. Jaci
Mar 01, 2009 | Magic Chef MCBR440 Compact Refrigerator
Magic Chef Over the Range, MicroOven, model MCO153UBF
I tried the usual things, then checked the outlet in the cupboard where the unit is plugged in.....It was okay, but then I noticed a separate electrical cable going into the wall at the outlet. I went to the breaker box downstairs, found a breaker marked "Microwave Oven", flicked it off and on and away the microwave oven went....It is now okay. I guess the thermostat had turned everything off when it became too hot....
anyway all okay now....thx Janet
Jul 22, 2008 | Magic Chef CMV1000B Microwave Oven
Pilot lights
you need to plug the oven in; pull it out and you should locate the pwr cord or you may already have it plugged in and have a breaker turned off or a gfi tripped
Jun 19, 2008 | Magic Chef Kitchen Ranges
Microwave stopped working completely
Fan turned on after cooking because a thermostat got to hot and tripped turning on the fan to try to cool the unit.  The unit went completely dead when thermal fuse tripped which is located above the cavity on the left side.
Oct 30, 2007 | Magic Chef CMV1000B Microwave Oven
Magic Chef CTB1722 Top Freezer Refrigerator Logo
480 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
