Question about Samsung Televison & Video
Samsung model # HLN5065W the front panel lights temp and lamp are blinking and TV will not turn on
  • Samsung Master
  • 2,098 Answers
Hi rex_630,
The main reasons of your problem is the bulb which is already came to its end. The unit will automatically shuts off when it sense a bulb failure. But before you replace the bulb I would advice you to work first on itspower supply. Look for open fuse/fusible resistor and spot some bad solder joints. This will do the same symptoms like what it showing now. If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored electricity enough to hurt you with a little mistake only.
Hope I helped you.
Have a nice day!
Thanks for using Fixya
Posted on Apr 01, 2011
I have the Samsung HLN5065W DLP television, and if I press the power button the TV will act like it is going to power on but won't. The lamp light will blink but I never get a picture. It seems like it...
It seems tv needs lamp replacement, please check lamp in tv and if lamp has not been replaced in last 2-3 years or lamp is broken, replace it to solve tv problem.
Thanks.
Jan 22, 2011 | Samsung HLN5065W 50" Rear Projection...
When i turned it on screen went black...3 lights started to blink on front of screen
The "LAMP"LED light indication flashes or stay lite?The projection lamp life is over.Replaced the projection lamp.Tv require a new projection lamp.
Oct 19, 2010 | Samsung HLN5065W 50" Rear Projection...
My tv turns on for about 30sec but will not stay on first it blanks out but you can still hear what is coming on then all 3light blink and the sound goes away then I have to turn it back on
The"LAMP"LED light indication stay lite or flashes on the tv front of the screen bazel panel?This is tv has not been replaced the projection lamp like 1 1/2 or 2 years,tv been on,an in used like 4 or 5 hours a day.The projection lamp life is over.
Oct 03, 2010 | Samsung HLN5065W 50" Rear Projection...
Last week , my 6-7 yr old Samsung hln5065w dlp tv went blank. When I turned the tv back on after trying to reset it there was a winding noise but no picture. I replaced the lamp and still no picture. The...
Sounds like the old lamp blew and took out the ballast. I believe that you need a new ballast for your unit. The other possiblity would be a problem in the low voltage power supply but if the indicator lights are blinking the most likely problem is the ballast.
I have a tip at http://www.fixya.com/support/r4977572-when_change_ballast_in_dlp_tv which explains the problem, how to repair it and where to get the parts. If you need more help let me know.
Thanks for using FixYa and the generous rating.
hardrocko
May 28, 2010 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W..no picture, TV won't stay on, 3 flahsing LEDs.
Lamp Fan, make sure all fans are running if they run for alittle while and stop Fan is defective.
May 01, 2010 | Samsung HLN5065W 50" Rear Projection...
Samsung DLP TV time, temp and lamp lights blinking... won't turn
Les,
I'm not a TV repair guy but my owners manual states that when all three LED's or lights on the front of the TV are flashing, that the lamp needs to be replaced. Might want to look into this. Good luck!
Greg
Aug 30, 2009 | Samsung DLP HL-P5663W 56" TV
HLN5065W
there are 3 leds on the front that blink the error code. which leds blink gives you the error. if its just the standby/temp red led blinking, it has overheated for some reason. there are a couple other fans you could clean but check your ventilation. many people put too close to the wall or close it up in a cabinet. it needs atleast 4" from the wall and someway to vent out hot air and get cool air in. a different model had the temp sensor cause this issue, it is the silver thing right atop the lamp. you will have to pull the whole back panel possibly, there are two wires that hook to it and two screws holding it to the engine (lamp housing). if you get lamp and temp leds blinking, reseat the lamp door. timer and temp leds is a fan error, all 3 leds is a lamp error (lamp, ballast, colorwheel, dmd)
Dec 05, 2008 | Samsung HLN5065W 50" Rear Projection...
Issues with replacing Ballast
The flash code indicates that the lamp cover is not installed correctly. There are safety switches built into the housing that require the cover be installed correctly for the set to work. If the cover is actually in place correctly, there may be a broken switch. Check for this and update this if you can not resolve the problem.
Dan
May 08, 2008 | Samsung HLN5065W 50" Rear Projection...
Televison & Video Logo
141 people viewed this question
Henry  Thomas
Henry Thomas
