Question about Indesit W 123 Front Load Washer
How/where can i get a door frame (without glass) for indesit w1235 washing machine? thanks
    Scholar:
  • 79 Answers
Assuming you're looking just for the outer door frame, this should do the trick:
http://www.appliancespartsdirect.com/indesit/9292-door-part.html
Good luck, and if this works for you, please rate my answer!
Posted on Apr 01, 2011
  • redpaint82 Apr 01, 2011
    thanks for suggestion, i am guessing its the whole frame i need, as the door handle broke off, as well as small piece of frame that surrounded spiral coil.
The message flashing says 'door' what do I do?
You have a problem with the door switch interlock.
Indesit WIDE 146 (DE) Washing Machine Spares ' eSpares
www.espares.co.uk > Home > Washers & Dryers > Washing Machines > Indesit
  1. Cached
Items 1 - 10 of 60 - Universal stacking kit suitable for most washers and dryers measuring 60cm across More information. In Stock. Stock Number ES187394.
Get Indesit Washing Machine Spare Parts ' eSpares
  1. Cached
  2. Similar
Genuine Indesit washing machine spares including Drum lifters, Indesit ... Start your Indesit parts search by selecting your washing machine model number from ...
Indesit Washing Machine WIDE 146 (DE) Spares - indesitspares
www.indesitspares.co.uk/washing-machine/wide-146-de.../catalogue.pl?path...
  1. Cached
Indesit WIDE 146 (DE) Washing Machine Spares ... Fits models with serial number from 30127.0001 Please Note the above serial number changes does not ...
Indesit Washing Machine IWDE 146 UK Spares - indesitspares
www.indesitspares.co.uk/washing-machine/iwde-146-uk-f084074/catalogue.pl?...
  1. Cached
Indesit IWDE 146 UK Washing Machine Spares ... This part fits the following models: WIL133UK, WIL133UKCO, WIXE127UKV & Does Not Fit Mod. .... If you have just replaced the door seal on your appliance then you may need this retainer ...
Indesit Ecotime IWDE 146 Built-in Washer Dryer - White
www.indesit.co.uk/appliances_i/Washer_Dryer_IWDE_146/pid_F084074UK/42.do
  1. Cached
  2. Similar
Rating: 8.5/10 - ‎19 votes Indesit Ecotime IWDE 146 Built-in Washer Dryer - White, ... News & Offers; Service & Spares. Service · Spare Parts ... IWDE 146 reviews · Ask-an-owner ...
Washer dryer no wide 146 Google Search
Mar 24, 2017 | Washing Machines
Model wm0642hw front load. it leaks by door frame.rubber seal with clamp.only 2 years old. do i need to change the door frame outer part a151? thanks for your response in advance
Hi, If the door isnt loose or broken? Its more likely to be the rubber door seal if its leaking between the seal and the door glass. Check the edge of the seal where it touches against the glass for damage or ware if its ok clean any soap residue or bits from the glass.If it still leaks change the door seal.
Regards Elect App
Jul 13, 2011 | LG WM-2277HW Front Load Washer
How to put on new handle on indesit washing machine w133s
the spring will go so that it pushes the latch part in towards the outside edge of the door. the pin goes through the door frame, then through the spring's 'holes', through the latch, and back into the frame of the door. the spring ends should sit in a couple of grooves in the door part which may be marked/scratched by the previous one.
Feb 05, 2009 | Indesit W 123 Front Load Washer
Indesit washer wont run
the door lock light flashing indicates that the door has not locked or not shut correctly,is the appliance is under 5 yrs old open the door and check the door catch,there are two gaps either side of the catch,if you look into the gaps you should see a metal pin,if the one at the bottom is not there then thats why the door wont catch,there are some screws around the door frame if you take them out and just pry apart the door frame by the catch you will see the pin at the top,push it down till you see it at the bottom gap,refit and test.
Jan 24, 2009 | Indesit W 123 Front Load Washer
Washing power drawer, the fabric softner section
Pull the drawer out as far as it will come and then grasping it firmly, give it a good tug towards you, this will free the drawer to enable you to thoroughly clean every piece of it, particularly the conditioner parts of it.
Get a piece of wire with a bend on the end, and poke it in to all the holes in the top of the dispenser compartment, this will clera any blockages there.
Plz rate my solution, and feel free to leave any comment.
Thanks.
Jan 09, 2009 | Indesit W 123 Front Load Washer
Change grip/handle on a indesit washing machine w105tx
Undo any screw that you can see on the inside of the door frame, and then prize the two halves apart,
This should give you access to the door handle assy.
Hope this helps.
Dec 02, 2008 | Indesit WA 125 Front Load Washer
New glass door into frame
usually only avaliabel as compleate door.
Oct 04, 2008 | Indesit W 123 Front Load Washer
Indesit washing machine w1235
could be the bearings or heater/heater may of lifted or spider sometimes a coin can get trapped
May 20, 2008 | Indesit W 123 Front Load Washer
Door jammed
take the top off the machine,put your hand down to the reigon of the door lock and by using a small screw driver the catch on the door can be forced open without doing any damage.
Jul 24, 2006 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
94 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
