Question about Refrigerators
I have a refrigerator of Westing House model no is RJ275M. It is old one. It is auto frost free fridge. My problem is top freezer working good but lower compartment of fridge not getting cold enough. And I found lots of frost deposited in freezer area. I think it's free frost system not working. So Can you please advise me how to fix this problem by myself? Thanks
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 01, 2011
I have a 16 year old fridge westinghouse frost free model RJ275M 275 ltr. The freezer is working great but the fridge head stopped. inside the actual fridge there is a leak. Any help would be great on...
what? do u speak english?
fridge head? stopped? what is that?
what leak inside the firdge? leak of what where?
any help would only help someone with a clue.
you need to CALL A PROFESSIONAL
Dec 26, 2014 | Refrigerators
Westing house frost free bottom coolling then eventually stop freezer alright
If the fridge still working check the fan for the freezer
Mar 21, 2013 | Refrigerators
12 yr old kenmore top freezer. Freezer get real cold but does not freeze. Fridge part does not get very cold. I cleaned all the dust from coils, fan runs and all the seetings are good.
Top of Form
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Sep 03, 2011 | Kenmore Top Freezer Refrigerator
My RJ275M top freezer works well. the fridge itself is only just cool.
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 14, 2011 | Westinghouse Refrigerators
Why are freezers usually present on the upper part of the fridge ?
The only reason is because the advent of the home refrigerator was a design that incorporated a "freezer section" that actually cooled the entire box. This design was expanded on to add fans for air flow and eventually a defrost circuit to make the first "frost free" models. Now today top freezer models actually only make up a very small portion of the retail industry with bottom freezer models being one of the biggest sellers followed by side by side models and lastly the good old top freezer models.
Jun 12, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice cream melted in freezer
Hello, There should be a temp adjustment for fridge & freezer adjust for colder setting. Check door sealant/gasket for cracks & seating. Next is bad news-call a BBB repair service. Good Luck.
May 12, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
I have a westing house BJ414 and dont seen to be getting much air flow into the fridge section? the fan is runnong aand the freezer is reaching temp?
maybe too much food in top part of fridge. Cold air comes from top of fridge near light. Can you feel cold air coming from there? Put a fridge thermometer in the top section-they only cost a few $ from kmart etc -the temp should be 2-4 deg C. My thermostat is turned to warmest setting and its still in that range. Does fridge cycle on and off every 1/2hr or so? If it runs nonstop, it may be the freezer section is all frosted up, probably coz the defrost timer has stopped working or else the defrost element has burned out. Both can be easily replaced by you.
Apr 23, 2010 | Westinghouse Refrigerators
SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Refrigerators Logo
205 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
