My Window unit A/C has started leaking at the bottom onto my window seal and hard wood floors. I have this A?C for about 5 years and this has never happened before?? Any Sugestions???
  • 6,487 Answers
What is the brand and model of your A/C? This can be cause by some rust and small opening on your A/C that will be better for your to do a complete clean and inspection on this unit to make sure no damage parts of the A/C is causing this..
Posted on Aug 05, 2008
    Guru:
  • 1,894 Answers
Condensation of water on the evaporator coils in the front of an air conditioner is normal. This water collects in a pan where it is evaporated. On a really humid day, you may notice some is dripping off the unit. A properly installed unit will be tipped slightly back to allow any excess water to drip out the back.
Whirlpool GX2SHBXVY05 refrigerator leaking from bottom freezer onto floor.
if it has an ice maker check the water feed hose for leaks.
also I have a freezer that ices up twice a year. poor design. have to defrost every now and then.
Jun 09, 2015 | Refrigerators
My Bottom pull out freezer is leaking water onto the floor from on top of both feet of the unit. The freezer also has frozen water in the bottom of the unit. I have removed the frozen water in hopes that...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 15, 2011 | Whirlpool GI5FSAXVY Stainless Steel ...
Water leaks onto pass side floor only when it rains. the area under yhe cowel is clean and water runs by the wheel well like it should. leaks when car isnt running
First I would check and see if its leaking for the front window.take a water hose and spray water around the seal of the window and see if it leaks. If it don't then I would take do the same test around door seal and the passanger side window.
May 26, 2011 | Dodge Stratus Cars & Trucks
Rain water leak
Did you have the windshield replaced recently? This is typically caused by faulty installation of a windshield. Sometimes it can be fixed by adding windshield sealant (polyurethene, not silicone) where the windshield is adhered to the subframe - most likely along the bottom edge.
Jun 28, 2009 | 2003 Dodge Dakota Club Cab
Back sliding window leaks arond the seal onto the back seat, how can I stop this without replacing the whole unit?
Gary, I had the same problem with my 1999 F150 xcab. I first ran water from a hose over the roof toward the back window. Start at one side and look for water trickles at the top of the window. Don't stop at one place but do the whole window. I found mine leaking at the upper corners and a small trickle at the slider window ends.
I removed my headliner to gain access to the nuts that hold in the window. There are two sets of nuts, one set for the windows molding outside and the other for the window itself. The factory seal was shrinking on the upper corners allowing the water to pour in. The window had to be removed. If you take off the nuts slide a utility knife between the body metal and the window frame, it will release. Be careful not to push too hard on the glass when removing (it may crack the frame and / or the glass itself) just use a steady push and make sure you cut the seal well with your knife.
After you have the window out, clean off the old seal with a plastic scraper so as not to damage the window frame surface, then clean with rubbing alcohol. Do the same with the tucks cab metal where the window seals to the cab. Be sure NOT to scratch the paint. If you so you will need to touch it up before you reinstall the window. Check your window for stress cracks in the frame. You can seal them with the butyl tape you will get at the parts store. If you cna't seal the stress cracks you will have to replace the window. You can also seal sround the outer edge of the window frame between the glass and the inner edge of the window frame that mounts against the truck body. The butyl tape should work for that as well, it is self adhesive.
Go to your local autoparts store and get new sealing material (butyl tape 1/4" or smaller). It comes in a roll. Place the seal around the edge of the window frame, making sure the tape is on the outside edge of the studs, and place the window back in the opening. (hold the window in by opening the slider) and replace the nuts on the inside. Snuggly tighten the nuts starting from the closest to the centers and working your way to the outside corner nuts. Once you have the window reinstalled you can water test your window right away, the sealer is waterproof immediately. If the window is sealed you may reinstall the headliner and any panels you had to remove.
May 25, 2009 | 1999 Ford F150 Regular Cab
Water on my floor
Is it the bottom or coming out the door at the bottom? When your seal is bad it will leak, mine leaks only on handwashables and delicates. I have had to have my seal replaced twice in the three years i have had one, and the last seal was not put on right and leaks.
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
There is a water leak somewhere in my 98 toyota camry that leaks into my passenger side floor. There is no sun roof and no visible leaks from the windows or doors. Any thoughts? A/C leak maybe? water...
I am the original owner of camry xle 1998 with wet floors. In 2000 I had drivers side door seal leaking at welt. Removed old door seal and new weather strip on drivers side installed. The door panel was never wet, but wet at bottom of door where there are drain holes...slowly leaking under carpet.
In 2001 later water again. Coming from overflowing A/C evaporator-drain plugged/ tank full of debris. Removed evaporator, cleaned + drain cleaned.
In 2003, driver door seal against window rotted. Removed door panel and found leak at window belt molding at the mirror joint inside + out. Lots of mold under carpet needed to replace! Made a fuss at dealers for reacurring problem and they replaced the carpet for free.
Sep 07, 2008 | 1999 Toyota Camry
Sub-Zero 550 water dripping on right side of freezer forming ice on draw
I had a similar issue that started about a year ago with my Sub-Zero 550. My freezer gasket actually tore after several times of freezing closed. I thought that a new gasket would solve it, but a second but related problem developed where I was getting alot of condensation under the left side of the unit, with the water dripping onto the floor...eventually staining the hardwood floor in front of the unit.
I traced the problem to a clogged condensation drain pipe in the refrigerator. It is a corrugated pipe that drains a trough behind the crisper drawers. My pipe was clogged with black sludge and frozen down below. The condensation in the fridge would overflow out of the trough and leak below the crisper drawers, down out through the gasket.
To resolve, I used a piece of solid thin wire folded in half and twisted with a small loop at the end to fish out as much sludge as I could. Then squirted hot water into the pipe until it totally unclogged. I believe this will solve the problem without any need for a heater underneath the unit. The 550 worked fine for 4-5 years before this happened.
Jan 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
