Question about Vacuums
We lost are motorcycle wheel balancer and we are trying to set it up can u guys help us or no
    Master:
  • 403 Answers
What are you trying to do ? need more info please
Posted on Apr 01, 2011
One of my back wheels came off . How do I put it back on?
kirby lost a wheel!! - Vacuumland
www.vacuumland.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?13365
Jul 7, 2011 - 6 posts - ‎5 authors My mother has been using in her house three kirbies ( one G5 and two ... I saw this thread and had to do a slight lighten to give an "all about ... to use the extra wide wheelson the front and back (with hubcaps). ... service department he could not figure out why the wheels came off. ... Discuss-o-Vac Forums
Vacuum Cleaner Rear Wheels For Dyson DC01 Models ...
Nov 28, 2015 | Vacuums
My Neato XV-12 runs for only a few seconds and stop. The message says, please dust me off I cant see. I have dust and cleaned my neato and it still says the same thing. How do I fix this problem?
Hi Guys
I've fully dismantled my Neato XV-21 to locate the source of the "can't see" problem. (And also replaced a tight wheel Motor causing a "something is caught in my right wheel" message)
There several screws underneath the Neato XV-21 that must be undone to allow the top to be separated. A bit of a pain just to get into the visual sensor area. But not too hard with an electric screwdriver.
There is a Laser device & a Photo sensor mounted to a black plastic rotating wheel which is covered by a black cap with 2 holes in it. One hole for laser beam to exit & one to pick up return laser light return data. They are both rotated by a motor & pulley via a rubber "o" ring which could slip, break or get hairs caught in it.
These could be the source of problems. Once mine was cleaned & checked I had no more problems. Then the wheel motor got tight. Replacing the motor fixed the problem. This requires hoping the Motor Gear Box assembly out by poping the pivot shaft out of it's plastic holder. Then disconnect the spring & cable connector. But you bust be prepared to carefully remove the magnet off the motor shaft (vice & 2 flat blade screw drivers) then unsolder the small PCB at 2 points. With practice (twice) I can now replace a motor in 20-30 minutes.
Hope this Helps some Neato Users out there
Cheers
Trevor
neato-xv-12-runs-only-few-seconds-stop-qnpe3nojpvl4vx0tieerofmg-2-0.png Wheel Motors Here
Wheel and brush motor for Neato XV 11 XV 12 XV 14 XV 15 XV 21 XV Signature...
Apr 05, 2015 | Neato Robotics XV-12 Vacuum System - White
Miele lost suction
The thing about vacums is they all suck! Ok, now that I've completed my comedic exercise...You didn't provide a lot of detail. I'll assume it turns on...have the filters been changed lately because some models have filters that if not clean...will restrict air flow when dirty or clogged. You may have to take it apart and Vacuum cleaners are not overly complicated. If you go online you may find a maual on your model which show where all the important screws are that have to be removed to open the thing up. of course..make sure it's unplugged before you try opening it up. If the motor spins and the filters are OK, it could be the motor is just spinning freely and not actually turning the wheel that creates the vacuum. So you'll have to try and see if the blower wheel is spinning free or if it's solidly connected to the motor. If the blower wheel isn't connected to the motor solidly...there's your problem....the motor is spinning but not turning anything. Best thing to do is look up the model online and find the schecmatic/manual/parts manual for it. Seeing that will give you a better idea of how the thing is constructed and what might be causing the problem. Also, if you take it apart, mark the screws/bolts so you put them back in the right holes.
Oct 14, 2014 | Vacuums
I lost the instruction on how to reprogram Aldi DMV-7010S remote socket instructions
Try this... http://forums.moneysavingexpert.com/showthread.php?t=222072&page=1
Jul 02, 2014 | Vacuums
How to repair the front left wheel and height adjustment assembly on a Kirby G10 vacuum cleaner
The wheels are held on by a screw behind the wheel guard, i suspect your height adjuster has come loose off the spline, this can be simply tapped back onto the axle
Jul 21, 2017 | Kirby G10 Sentria Vacuum Cleaner...
DC 18 does not stand up - falls over
Hi Rich,
I'm sorry to hear you're having difficulties with your DC18. We'd appreciate the opportunity to provide further assistance, so I'd encourage you to call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US). Please have the machine to hand when you call, so we can run through some troubleshooting checks with you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com/
Jan 16, 2012 | Dyson Slim DC18 All Floors HEPA Bagless...
I need a copy of the users manual- I lost mine
I lost a user manual, then found these guys. They emailed it to me in about 2 hours and it only cost about £3, which i thought was very reasonable.
http://findmymanual.com/
Hope this helps.
Jane
Aug 31, 2010 | Tristar SB Steam Buggy Vacuum
Roomba stutters on one wheel causing it to quit
Try setting the Roomba on the floor, powering it up, pressing down hard on the front, just above the front wheel, and hitting "clean" or "spot." My Roomba had the same problem, and this seems to do the trick for it. I think it has something to do with the Roomba thinking the front wheel is extended (which would indicate a cliff) even though it's really not.
If this doesn't work, you might try pressing down over whichever wheel doesn't turn when you turn the Roomba on.
Mar 22, 2010 | iRobot 4150 Roomba Vacuum
Dirt Devil Model 5200
If there is a lot of vibration along with the noise, then unfortunately the impeller inside that creates the suction has probably lost a blade or two and is now out of balance. Sucking up coins and other hard objects will do that is a hurry. If not, then there may be something stuck in the impeller. In either case, you will need to get to the motor itself and either remove whatever is stuck there or break off an even number of blades on the opposite side of where they are missing to balance things out. Think of how your washing machine acts when it's out of balance. It the same idea, only 100 times faster.
Unfortunately, this is most likely something that requires someone to take it apart.
Hope this helps, and please rate my answer, good or bad.
Thanks, and good luck!
Feb 03, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Vacuums Logo
12 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
